Artem Gerasimenko
Родной блок утоплен, вытянуть ничего не удалось, может есть у кого то кодировка под купе? машина кабриолет WDD2054841F862147, SA877
да, именно такоеhw 222 901 41 03
sw 222 902 66 17
у вас такое железо и софт сейчас?
У меня разница в значения,..и много,...если хотите поиграйтесь,..к код 891 может и получится[Description]
Title=DTS Monaco additional ECU data
ProductVersion=8.14.016
Schema=7.01
Creator=Softing
Date=06/06/2023
Time=20:56:21
Author=
Comment=
NoOfConfigurations=1
[Configuration_001]
NoOfDomains=17
Title=205.484_WDDWK8EB5KF862147_01.2019
Comment=
VCD_ALC_Szenarien_und_Effekte_Control_VC=02,00,40,00,16,B2
VCD_ALC_Szenarien_und_Effekte_Parameter_VC=3E,00,00,02,3E,00,00,3E,01,01,00,17,01,00,1C,1E,1E,32,00,0A,1E,00,01,00,1F,3E,00,01,3E,00,7A,00,0F,00,17,00,00,28,00,0A,00,05,3E,00,0F,14,1E,05,01,00,17,00,00,0A,00,05,0A,00,28,05,3E,00,3C,1E,64,64,3E,00,02,00,01,32,14,0A,0A,00,0A,02,0A,02,C8,0A,64,0A,0A,0A,00,01,00,02,14,14,05,3E,14,3E,3E
VCD_ALC_Szenarien_und_Effekte_Arrays=01,C8,00,B6,00,01,00,01,00,02,03,C3,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,01,02,03,04,05,00,00,00,00,00,00,00,00,00,00,00,17,00,7A,00,7D,00,80,00,83,00,86,00,89,00,8C,00,8F,00,93,00,96,00,99,00,9C,00,9F,00,A3,00,A7,00,17,00,00,00,00,00,00,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,00,03,00,03,00,A2,00,A8,00,03,00,35,00,02,00,5A,00,01,00,02,00,03,00,01,00,02,00,03,00,17,01,58,00,7F,00,03,00,3B,00,3B,00,08,00,48,00,62,00,17,00,17,00,17,00,A8,00,48,00,72,00,08,3E,19,25,2F,32,3E,3E,3E,3E,3E,3E,3E,19,25,2F,32,3E,3E,3E,3E,3E,3E,3E,19,25,2B,32,3E,3E,3E,3E,3E,3E,3E,0C,19,25,2B,32,3E,3E,3E,3E,3E,3E,00,0C,19,25,2B,32,3E,3E,3E,3E,00,08,00,1C,00,72,01,26,00,35,00,3B,00,08,00,08,00,08,00,08,00,08,00,35,00,1C,00,72,01,26,00,35,00,3B,00,08,00,08,00,08,00,08,00,08,01,26,00,1C,00,1C,00,72,01,26,00,35,00,08,00,08,00,08,00,08,00,08,03,AD,00,1C,00,1C,00,72,01,26,00,35,00,08,00,08,00,08,00,08,00,08,00,72,00,1C,00,1C,00,1C,00,72,01,26,00,35,00,3B,00,3B,00,3B,00,3B,01,05,0A,0A,0A,0A,0A,04,01,01,01,01,0A,0A,0A,0A,0A,0A,04,01,01,01,01,05,06,0A,0A,0A,0A,0A,01,01,01,01,0A,07,07,0A,0A,0A,04,01,01,01,01,0A,04,06,06,0A,0A,04,01,01,01,00,03,00,03,00,A2,00,A8,00,03,00,35,00,02,00,5A,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,03,07,00,00,00,00,00,3E,3E,3E,3E,3E,01,26,00,3B,02,0D,00,62,03,C3,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,03,00,03,00,03,00,03,00,03,00,03,00,03,00,03,00,03,00,03,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01
VCD_ALC_System_Control=00
VCD_ALC_System_Parameter=1E,00,01,00,00,00,3C,00,03,1F,00,04,02,0C,18,24,30,3E,00,00,00,00,00,01,05,01,05,06,01,03,01,04,04,01,04,04,05,00,04,00,0A,00,02,0A,00,32,00,32,00,50,FF,FF,07,08
VCD_ALO_System_Arrays_01=00,0F,F0,00,03,01,C0,70,1C,07,00,05,F0,00,03,00,00,00,1C,07,00,0A,00,00,00,01,C0,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
VCD_ALO_System_Arrays_02=00,00,00,00,00,00,00,00,00,00,00,04,A0,00,00,00,00,00,08,02,00,0A,00,00,00,00,80,20,00,00,00,0B,F0,00,00,00,40,10,04,01,00,00,30,00,01,00,00,00,0C,00
VCD_ALO_System_Arrays_03=00,01,C0,00,02,00,00,00,00,03,00,08,00,00,00,00,00,30,00,00,00,02,00,00,00,00,C0,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
VCD_ALO_System_Arrays_04=00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,01,50,00,03,00,40,10,04,01,00,0E,A0,00,00,01,80,60,18,06,00,00,00,00,00,00,00,00,00,00
VCD_ALO_System_Arrays_05=00,00,00,00,00,00,00,00,00,00,00,01,50,00,00,00,40,10,04,01,00,00,00,00,03,00,80,20,08,02,00,0E,A0,00,00,01,00,40,10,04,00,01,50,00,03,00,40,10,04,01
VCD_ALO_System_Arrays_06=00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
VCD_ALO_System_Arrays_10=0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,0A,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27,28,29,2A,2B,2C,2D,2E,2F,30,31,32,33,34,35,36,37,38,39,3A,3B,3C,3D,3E,3F,40,41,42,43,44,45,46,47,48,49,4A,4B,4C,4D,4E,4F,50
VCD_ALO_System_Arrays_07=00,00,00,00,00,00,00,02,00,74,00,00,00,00,00,00,00,20,0C,01,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,01
VCD_LIN_predefined_network_configuration_1=03,03,03,03,02,00,08,00
VCD_ECU_HW_configuration=17,F0
VCD_ECU_SNPD_Bus_Shunt_Timings=00,00,00,00,00,00
VCD_ECU_SNPD_Bus_Switch_Timings=00,00,00,00,00,00
толку только, это с седана блок
да не совсе там плафоны, яркость, цвета, режимы температуры, мертвой зоны, приветствия, и тд.. на данный момент я уперся в проблему, что не меняется цвет через Comand, из ошибок только неверное количество участников на lin7 ( центральная консоль)физически есть только 4 из 8, но кодировкой не могу убрать эту ошибку, Lin 3 & 4 отсутствует вообще, так как это кабриолет, и подсветки задних дверей нету. С активации все светит и работает, с борта не работает ничегоА что рукам не как настроить плафоны ))))
вопрос был в наличии кодировок под купе у кого либо, а руками мы все тут можем всеДа все делаеться там в ручную и без проблем
вот и искал купе, чтоб сравнить..Руками там можно только готовый конфиг загрузить. А кастомные конфигурации - это надо сначала разобраться как они задаются в битах.
Файл коряво сохранен, часть строк дублирует...Coupe C205 6.3 Lift
Руками поправил все, все работает, благодарю, плюсовать не могу, позже накину.Coupe C205 6.3 Lift
NoOfDomains=17
Title=205.484
Comment=CABRIO_work
VCD_ALC_Szenarien_und_Effekte_Control_VC=02,00,40,00,00,A0
VCD_ALC_Szenarien_und_Effekte_Parameter_VC=3E,00,00,02,3E,00,00,3E,01,01,00,17,01,00,1C,1E,1E,64,00,0A,1E,00,01,00,00,3E,00,01,3E,00,7A,00,0F,00,17,00,00,28,00,0A,00,05,3E,00,0F,14,1E,05,01,00,17,00,00,0A,00,05,0A,00,28,05,3E,00,3C,1E,64,02,3E,00,02,00,01,32,14,0A,0A,00,0A,02,0A,02,C8,0A,64,0A,0A,0A,00,01,00,02,14,14,05,1F,1F,1F,1F
VCD_ALC_Szenarien_und_Effekte_Arrays=01,C8,00,B6,01,C8,00,B6,00,01,00,02,00,74,03,C3,00,01,00,01,00,01,00,01,00,01,00,01,00,01,01,02,03,04,05,00,00,00,00,00,00,00,00,00,00,00,17,00,7A,00,7D,00,80,00,83,00,86,00,89,00,8C,00,8F,00,93,00,96,00,99,00,9C,00,9F,00,A3,00,A7,00,17,00,00,00,00,00,00,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,3E,00,03,00,03,00,A2,00,A8,00,03,00,35,00,02,00,5A,00,01,00,02,00,03,00,01,00,02,00,03,00,17,01,58,00,7F,00,03,00,3B,00,3B,00,08,00,48,00,62,00,17,00,17,00,17,00,A8,00,48,00,72,00,08,3E,19,25,2F,32,28,3E,3E,3E,3E,3E,3E,19,25,2F,32,3E,3E,3E,3E,3E,3E,3E,19,25,2B,32,3E,3E,3E,3E,3E,3E,3E,0C,19,25,2B,32,3E,3E,3E,3E,3E,3E,00,0C,19,25,2B,32,3E,3E,3E,3E,00,08,00,1C,00,72,01,26,00,35,00,3B,00,08,00,08,00,08,00,08,00,08,00,35,00,1C,00,72,01,26,00,35,00,3B,00,08,00,08,00,08,00,08,00,08,01,26,00,1C,00,1C,00,72,01,26,00,35,00,08,00,08,00,08,00,08,00,08,03,AD,00,1C,00,1C,00,72,01,26,00,35,00,08,00,08,00,08,00,08,00,08,00,72,00,1C,00,1C,00,1C,00,72,01,26,00,35,00,3B,00,3B,00,3B,00,3B,01,05,0A,0A,0A,0A,0A,04,01,01,01,01,0A,0A,0A,0A,0A,0A,04,01,01,01,01,05,06,0A,0A,0A,0A,0A,01,01,01,01,0A,07,07,0A,0A,05,04,01,01,01,01,0A,04,06,06,0A,0A,04,01,01,01,00,03,00,03,00,A2,00,A8,00,03,00,35,00,02,00,5A,02,0D,01,26,01,F4,02,26,02,58,02,8A,02,BC,07,03,00,07,03,00,00,00,3E,3E,3E,3E,3E,01,26,00,3B,02,0D,00,62,03,C3,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,1C,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01,00,01
VCD_ALC_System_Control=08
VCD_ALC_System_Parameter=1E,00,01,00,00,00,3C,00,03,03,01,00,02,0C,18,24,30,3E,00,00,00,00,00,01,05,05,05,06,01,03,01,04,04,01,04,04,05,00,04,00,0A,00,02,0A,00,32,00,32,00,50,FF,FF,07,08
VCD_ALO_System_Arrays_01=00,01,F0,0C,03,00,00,00,1C,07,00,01,F0,0C,00,00,00,00,1C,07,00,00,00,00,03,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
VCD_ALO_System_Arrays_02=00,00,00,00,00,00,00,00,00,00,00,01,00,0C,00,00,00,00,08,02,00,00,00,00,03,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
VCD_ALO_System_Arrays_03=00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
VCD_ALO_System_Arrays_04=00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
VCD_ALO_System_Arrays_05=00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
VCD_ALO_System_Arrays_07=00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
VCD_LIN_predefined_network_configuration_1=03,03,00,00,02,02,05,00
