Как снять задний диван W167?
kslavik
Как снять/ поднять нижний диван заднего сидения W167? Если можно с фотками. Срочно.
Если он фиксированный, то как на легковых. Перед вверх , потом зад назад и вверх.
AR91.12-P-1021MERemove/install rear seat cushion17.06.2019
Model167.1
except code 567 (Vario rear seat)
Model167.3
P91.12-4286-09
1 Seat cushion 4 Pilot bushing 6 Electrical connectors
2 ISOFIX mounts 5 Wire hoop 7 Retaining bracket
3 Wire hoop
Remove/install
1 Move driver's and front passenger seat forward.
2 Pull seat cushion (1) on wire hoops (5) upward out of pilot bushings (4). Installation: Ensure that wire hoop (5) is seated correctly in pilot bushings (4).
3 Release and disconnect electrical connectors (6).
4 Press seat cushion (1) at left toward rear and unhook upward out of safety hooks. A wire hoop (3), which is hooked into the safety hook, is embedded in the seat cushion (1) on the rear left.
Installation: Ensure that wire hoops (3) are correctly seated into safety hooks.
5 Press seat cushion (1) at right toward rear and unhook upward out of safety hooks. A wire hoop (3), which is hooked into the safety hook, is embedded in the seat cushion (1) on the rear right.
6 Unhook mounting frame bows (7) at seat cushion (1) from ISOFIX mounts (2) and remove seat cushion (1).
Carefully remove the seat cushion (1) from vehicle.
Otherwise, component parts of the vehicle may be damaged.
Installation: Ensure that belt buckles are correctly positioned.
7 Install in the reverse order.
