Ошибка обновления программного обеспечения W166 PTS218 с Vediamo | benzpro
Mercedes w166bt
Hello,
After updating a total of 11 ECUs with Vediamo and successfully using the VX Diag, the only one I failed to do was the PTS218. For some reason, I only found two cbf files for this ECU, one dated 2013 and the other dated 2019, and both give the "ECU firmware interrupted" error and error 10011. I tried both cbf files with both the engine running and the ignition on, and the problem remained the same. I know the latest firmware is supported on 12.10. Since thanks to the forums I found encoding dumps from w166 with the same hw number and sw 12.10. I know it won't bring anything new, but now it's a matter of curiosity. I installed DTS Monaco, do you think the attempt with DTS can be successful? Thank you.
Error: Service execution failed: Reason: CAESAR:Masterinterpreter 10011:runtime bad opcode: CAESAR:MasterInterpreter: 10011 runtime bad opcode.
From several encodings from W166/X166 with the same hardware number, I found that they were flashed by dealers after March 2012, and as a result I tried to flash again with CBF from 11/20/2011 and the following error appeared in the log:
Ecu flashing is broken off
Error: Service execution failed. Reason: CAESAR:ProgBlock: 20052: FLASH - Error during execution of >TransferData<: CAESAR:ProgBlock: 20052: FLASH -
Error during execution of >TransferData<.
Do you think trying to upgrade via CBF from 2012 might help, given that the error code has changed in an older version of CBF?
Has anyone managed to update the PTS218, and if so, how?
проблема с вашим адаптером и его ПО. попробуйте использовать DTS
Проблема с адаптером, как вы думаете, связана с ошибкой 20052 или 10011? Спрашиваю, потому что когда я пытался прошить с помощью CBF от 2011 года, когда я подключил Vediamo, он показал 3 раза, что соединение осталось, так как лицензия адаптированного требовала обновления. Я обновил позже, но не пробовал после обновления лицензии. VX Diag отлично сработал с обновлением 11 ЭБУ, так что это странно с pts218.
Решено, не гладко. Прошил через DTS, но он не сработал, и модуль перешел в режим загрузки. Не стал заморачиваться и нашел обновленную часть, которая уже имеет последнюю прошивку. Она была plug and play, поэтому пришлось просто восстановить сохраненные кодировки старого модуля. Я уверен, что старый PN не принимает ни одну из обновленных прошивок, как подтверждено в файлах ETN, но я хотел поэкспериментировать с ней. Поделюсь, если это поможет кому-то в будущем.
