вот фрагмент лога:
[2020-10-01 16:15:28,923] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.openLogBlock] >>>>> job started {
[2020-10-01 16:15:28,925] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.logManifestInfo] JobVersion: 4.0.1
[2020-10-01 16:15:28,925] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.logManifestInfo] JobName: GenericRenaultKwpFlashjob
[2020-10-01 16:15:28,926] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.logManifestInfo] TemplateVersion: 1.0.2
[2020-10-01 16:15:28,926] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.logManifestInfo] TemplateName: RenaultKwpFlashjob
[2020-10-01 16:15:28,927] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.logManifestInfo] VM-Version:1.8.0_232 os:Windows 10
[2020-10-01 16:15:28,927] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.logManifestInfo] classpath:C:\TesterUpdate\Data\mnt\active\Xentry\bin\plugins\org.eclipse.equinox.launcher_1.5.0.v20180512-1130.jar
[2020-10-01 16:15:28,927] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.logManifestInfo] JavaHome:C:\TesterUpdate\Data\mnt\active\Xentry\bin\java
[2020-10-01 16:15:28,927] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Jobclass: com.daimler.odxjobs.flash.renaultKwp.flash.MCD3_GenericRenaultKwpFlashjob
[2020-10-01 16:15:28,928] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Inputparameter:
[2020-10-01 16:15:28,928] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] ECUBaseVariant = ESP453
[2020-10-01 16:15:28,928] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] ECUVariant = ESP453_Boot_Variante
[2020-10-01 16:15:28,928] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Protocol = RENAULTB_CAN_D
[2020-10-01 16:15:28,928] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] JobQualifier = WVC_FlashProg
[2020-10-01 16:15:28,931] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.openLogBlock] >>>>> ReadingConfigFile {
[2020-10-01 16:15:28,979] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.closeLogBlock] }
[2020-10-01 16:15:28,981] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.checkInputParameters] "ignoreOdxSignature" not found in InputParameters. Value false assumed
[2020-10-01 16:15:28,983] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.openLogBlock] >>>>> Initialization {
[2020-10-01 16:15:28,984] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.initComParams] -----Initializing communication parameters-----
[2020-10-01 16:15:28,984] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.prepareGlobalComParams] Preparing global communication parameters...
[2020-10-01 16:15:28,984] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.initComParams] Setting prepared communication parameters...
[2020-10-01 16:15:29,013] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.initDepartment] ----Initialize Department-----
[2020-10-01 16:15:29,014] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.initDepartment] Department is AfterSales
[2020-10-01 16:15:29,014] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.initFlashwareParser] ----Initialize Flashware-----
[2020-10-01 16:15:29,016] INFO [com.daimler.odxjobs.flash.renaultKwp.FlashwareParser.getSegmentByIndex] Available number of Flash Segments: 1
[2020-10-01 16:15:29,018] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.initFlashwareParser] Flashware type: KWP
[2020-10-01 16:15:29,019] WARNING [com.daimler.odxjobs.flash.renaultKwp.FlashwareParser.getSignatureForBlock] Flashware-Signature was found but could not be read
[2020-10-01 16:15:29,020] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] ------Identification Logzone Data (all from kwp file)-----
[2020-10-01 16:15:29,021] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] PartNumber: 0x3433353752
[2020-10-01 16:15:29,021] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] DiagIndex: 0x04
[2020-10-01 16:15:29,021] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] SupplierNumber: 0x303337
[2020-10-01 16:15:29,021] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] HardwareNumber: 0x3233323852
[2020-10-01 16:15:29,022] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] SoftwareNumber: 0x4826
[2020-10-01 16:15:29,022] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] VersionNumber: 0x153B
[2020-10-01 16:15:29,022] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] CalibrationNumber: 0x0024
[2020-10-01 16:15:29,022] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] ReserveAndCM: 0x02010088
[2020-10-01 16:15:29,022] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] --Reprogramming and other Logzone Data--
[2020-10-01 16:15:29,023] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] ApprovalNumber (kwp file): 0x3030303030
[2020-10-01 16:15:29,023] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] Programming Site Reference (parameter): 0x0000000000
[2020-10-01 16:15:29,023] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] Programming Tool Reference (parameter): 0x0000000000
[2020-10-01 16:15:29,023] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] LogicalMarker (kwp file / parameter): 0x82
[2020-10-01 16:15:29,023] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.printAllLogzoneEntryInfoToDebugFile] BlockType: Application and Calibration
[2020-10-01 16:15:29,023] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.closeLogBlock] }
[2020-10-01 16:15:29,024] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.executeJobTask] Department is AfterSales. PreProgrammingSequence will NOT be executed.
[2020-10-01 16:15:29,024] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.startMajorProgrammingSequence] ----Start Major Programming Sequence-----
[2020-10-01 16:15:29,024] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.openLogBlock] >>>>> SetComparameter {
[2020-10-01 16:15:29,049] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Set Com Parameter CP_Cs = 0 ?µs (original value: 0 ?µs)
[2020-10-01 16:15:29,049] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Set Com Parameter CP_P2Min = 1000 µs (original value: 25000 µs)
[2020-10-01 16:15:29,050] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Set Com Parameter CP_P3Min = 1000 µs (original value: 0 µs)
[2020-10-01 16:15:29,050] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Set Com Parameter CP_P2Max = 1010000 µs (original value: 900000 µs)
[2020-10-01 16:15:29,107] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.closeLogBlock] }
[2020-10-01 16:15:29,107] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.openLogBlock] >>>>> ReadReprogrammingCounter {
[2020-10-01 16:15:29,108] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.startMajorProgrammingSequence] Read Reprogramming Counter
[2020-10-01 16:15:29,167] INFO [com.daimler.odxjobs.common.ComObject.logTx] HexService = [21 FF]
[2020-10-01 16:15:29,209] INFO [com.daimler.odxjobs.common.ComObject.sendRequest] Positive Response from ECU. [61 FF 30 30 30 30 30 50 4C 41 4E 54 45 43 4F 53 5F 02 15 10 27 08 29 5C B8 E4]
[2020-10-01 16:15:29,209] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.extractNofReprogrammingsFromResponse] Value of current reprogramming counter: 0x2 (2)
[2020-10-01 16:15:29,210] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.closeLogBlock] }
[2020-10-01 16:15:29,210] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.openLogBlock] >>>>> Erase {
[2020-10-01 16:15:29,210] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.startMajorProgrammingSequence] Erase Memory
[2020-10-01 16:15:29,211] INFO [com.daimler.odxjobs.common.ComObject.logTx] HexService = [31 81 82 F0 5A]
[2020-10-01 16:15:29,217] INFO [com.daimler.odxjobs.common.ComObject.sendRequest] Positive Response from ECU. [71 81 01]
[2020-10-01 16:15:29,220] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.demandEraseMemory] Erasing in progress
[2020-10-01 16:15:29,221] INFO [com.daimler.odxjobs.common.ComObject.logTx] HexService = [31 81 01]
[2020-10-01 16:15:29,229] INFO [com.daimler.odxjobs.common.ComObject.sendRequest] Positive Response from ECU. [71 81 01]
[2020-10-01 16:15:29,229] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.requestEraseMemoryStatusPolling] ECU Erasing is still in Progress. Message: Erasing in progress
[2020-10-01 16:15:29,430] INFO [com.daimler.odxjobs.common.ComObject.logTx] HexService = [31 81 01]
[2020-10-01 16:15:29,436] INFO [com.daimler.odxjobs.common.ComObject.sendRequest] Positive Response from ECU. [71 81 02]
[2020-10-01 16:15:29,437] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.requestEraseMemoryStatusPolling] ECU Erasing is still in Progress. Message: Erasing completed and OK
[2020-10-01 16:15:29,638] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.closeLogBlock] }
[2020-10-01 16:15:29,638] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.openLogBlock] >>>>> DownloadDataBlock {
[2020-10-01 16:15:29,638] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.startMajorProgrammingSequence] Download Flash Data
[2020-10-01 16:15:29,638] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.downloadFlashData] Download of Segment 1
[2020-10-01 16:15:29,749] INFO [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.downloadFlashSegment] Number of Frames to send: 9984
[2020-10-01 16:15:53,065] SEVERE [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.startMajorProgrammingSequence] MajorProgramming Sequence failed. Aborting Flashjob
[2020-10-01 16:15:53,066] SEVERE [com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.executeJobTask] FlashJob was aborted
[2020-10-01 16:15:53,095] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Reset Com Parameter CP_Cs = 0 ?µs
[2020-10-01 16:15:53,096] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Reset Com Parameter CP_P2Min = 25000 µs
[2020-10-01 16:15:53,096] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Reset Com Parameter CP_P3Min = 0 µs
[2020-10-01 16:15:53,096] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Reset Com Parameter CP_P2Max = 900000 µs
[2020-10-01 16:15:53,117] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.closeLogBlock] }
[2020-10-01 16:15:53,118] SEVERE [com.daimler.odxjobs.common.logging.LoggingHelper.openLogBlock] >>>>> Exception {
[2020-10-01 16:15:53,118] SEVERE [com.daimler.odxjobs.common.logging.LoggingHelper.logException] Error in Downlaod Data > Negative response received HexService PDU [34 82 01 FF F0 80 BA 5E 2E 6B ... ] Condition Not Correct
[2020-10-01 16:15:53,119] SEVERE [com.daimler.odxjobs.common.logging.LoggingHelper.logException] com.daimler.odxjobs.common.JobException: Error in Downlaod Data > Negative response received HexService PDU [34 82 01 FF F0 80 BA 5E 2E 6B ... ] Condition Not Correct
at com.daimler.odxjobs.common.ComObject.createNegResponseError(ComObject.java:402)
at com.daimler.odxjobs.common.ComObject.sendRequest(ComObject.java:162)
at com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.downloadFlashSegment(AbstractRenaultKwpFlashjob.java:1064)
at com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.downloadFlashData(AbstractRenaultKwpFlashjob.java:990)
at com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.startMajorProgrammingSequence(AbstractRenaultKwpFlashjob.java:550)
at com.daimler.odxjobs.flash.renaultKwp.AbstractRenaultKwpFlashjob.executeJobTask(AbstractRenaultKwpFlashjob.java:370)
at com.daimler.odxjobs.flash.renaultKwp.flash.MCD3_GenericRenaultKwpFlashjob.executeJobTask(MCD3_GenericRenaultKwpFlashjob.java:49)
at com.daimler.odxjobs.common.AbstractSingleEcuJob.execute(AbstractSingleEcuJob.java:279)
at com.daimler.odxjobs.flash.AbstractFlashJob.execute(AbstractFlashJob.java:104)
at JobProcessor.JobThread.run(Unknown Source)
[2020-10-01 16:15:53,119] SEVERE [com.daimler.odxjobs.common.logging.LoggingHelper.closeLogBlock] }
[2020-10-01 16:15:53,143] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Reset Com Parameter CP_Cs = 0 ?µs
[2020-10-01 16:15:53,144] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Reset Com Parameter CP_P2Min = 25000 µs
[2020-10-01 16:15:53,144] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Reset Com Parameter CP_P3Min = 0 µs
[2020-10-01 16:15:53,144] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Reset Com Parameter CP_P2Max = 900000 µs
[2020-10-01 16:15:53,156] SEVERE [com.daimler.odxjobs.common.logging.LoggingHelper.logMCDError] Severity: eERROR
Code: 53315, CodeDescription: An internal error occurred in the MVCI diagnostic Server. See vendor specific code for details.
VenderCode: 21868, VendorCodeDescription: jobError:21868 > position:DownloadDataBlock > Error in Downlaod Data > Negative response received HexService PDU [34 82 01 FF F0 80 BA 5E 2E 6B ... ] Condition Not Correct
[2020-10-01 16:15:53,156] SEVERE [com.daimler.odxjobs.common.AbstractSingleEcuJob.error] Error occurred during job execution!
[2020-10-01 16:15:53,157] SEVERE [com.daimler.odxjobs.common.AbstractSingleEcuJob.error] Severity: eERROR
[2020-10-01 16:15:53,157] SEVERE [com.daimler.odxjobs.common.AbstractSingleEcuJob.setExecutionState] Execution State = eALL_FAILED
[2020-10-01 16:15:53,157] INFO [com.daimler.odxjobs.common.AbstractSingleEcuJob.info] Job duration: 0h 0m 24s 234ms
[2020-10-01 16:15:53,158] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.closeLogBlock] }
[2020-10-01 16:15:53,158] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.removeHandlers] removing loggers
[2020-10-01 16:15:53,158] INFO [com.daimler.odxjobs.common.logging.LoggingHelper.removeHandlers] removing loggers1
