W221 неработосопособен DISTRONIC PLUS SA233 | benzpro
  • Автор темы Автор темы bynow3
bynow3
Всем привет,
Имеется WDD2210221A модельный год 2010 (SA code 800) c такими событиями в блоках тормозов и радаре соответственно -
ABR_XT 742300 SSM Fehler: EIS nicht verfьgbar signalisiert durch TxPkPosn_Rq_SBC_Enbl
OCCURRENCE_FAULT: Ereignis;
WARNING_INDICATOR: none;
READINESS_INDICATOR: ---;
PRIORITY: 2;
ENGINEERING_NOTES: In case of an active SBC-H, ADTR or PAS system and vehicle speed below 3km/h,
a CLOSE request is send to EPB. SBC-H, ADTR and PAS are disabled as long as EIS is signalizing failure status.;
CUSTOMER_PERCEPTION_SYMPTOM: deactivated control function(s): none
available control function(s): EBD ABS EDC BTC ETC AYC DDS ACC PML HSA HBA DBF APIA ECO;
POSSIBLE_CAUSES: a) EIS detected internal failure
b) Communication failure
Failure entry conditions:
- any assistant function is active
- manual activation of any assistant function
- no communication error detected;
REPAIR_ACTION: - Check EIS for defects by reading failures.;
ENABLE_CONDITIONS: once per loop;
MATURE_THRESHOLD: see ENGINEERING_NOTES;
MATURE_TIME_VALUE_UNIT: 500ms;
MONITOR_TYPE: see ENABLE_CONDITIONS;
MONITOR_RATE_VALUE_UNIT: -;
NUMBER_OF_TRIPS_ACTIVE: 0;
DE_MATURE_CRITERIA: t.b.d.;
DE_MATURE_TIME_VALUE_UNIT: -;
LIMP_IN_ACTION: -;
STORED_DTC_SELF_HEALING_CRITERIA: t.b.d.
RDU_212 727C00 CAN ABR: Stillstandskoordinator deaktiviert AS
DTC_OCCURRENCE_FLAG: Occurrence;
DTC_WARNING_INDICATOR_FLAG: active;
READINESS_INDICATOR: supported;
DTC_PRIORITY_VALUE: 2;
ENGINEERING_NOTES: DEM_DCLRG_SPCR_AS_OFF;
CUSTOMER_PERCEPTION_SYMPTOM: Funktion steht nicht mehr zur VerfГјgung;
POSSIBLE_CAUSES: tbd;
REPAIR_ACTION: ESP_ABR ГјberprГјfen/CAN-Kommunikation ГјberprГјfen;
ENABLE_CONDITIONS: Motordrehzahl > 400 U/min, DISTRONIC Plus aktiv;
MATURE_THRESHOLD: Signal SPCR_AS_Off_Rq=1 oder 2;
MATURE_TIME_VALUE_UNIT: 0ms;
MONITOR_TYPE: zyklisch;
MONITOR_RATE_VALUE_UNIT: 20ms;
DE_MATURE_CRITERIA: ZГјndungsneustart;
DE_MATURE_TIME_VALUE_UNIT: 0 ms;
LIMP_IN_ACTION: non;
STORED_DTC_SELF_HEALING_CRITERIA: 100
Как бы из контекста понятно, что вроде замок не шлет что-то, связанное с паркингом. В замке ошибок нет (и кодировок тоже нет). В тормозах кодировок с SSK - StillStandKoordinator нет. Кто-то может сталкивался или может подсказать?
Предистории нет, машина была куплена уже с таким дефектом.
Возможно пытались выключить опцию и чего то накодировали. Нужно сверять с кодингом с такой же машины и далее уже смотреть и разбираться
В CAN матрице для EIS 2007 г.в. сигнал >> TxPkPosn_Rq_SBC_Enbl отсутствует во фрейме EIS_A1, в отличии от EIS 2010 г.в.
