Помогите пожалуйста кодировками ESP909 для Sprinter Classic сборки РФ.
Такой есть
Код:
CBF-Version ESP909.cbf SGML- Version:03.02.06 CBF- TRANSLATOR- VERSION:04.00.01
TARGET- RELEASE:3.0
DATE:30.01.2017
GPD- TRANSLATOR- VERSION:V3.78
FINGERPRINT:117.134.200.166
CBF:ESP909
LANGUAGE:ORIGINAL, TEXT- ID
ECU: ESP909
Diagnostic ID: 70 01
Diagversion: Diag_T1N_7001
 Partnumber      Version         Supplier        Status      flashed   by
Hardware 0009013202      11/11.00        Bosch           -           -         -
SW Block #0 9099021100      13/03.00        Bosch           valid       00-00-00  Bo 00000000
ECU is Gateway No
ECU Mode: Normal
ECU Bootversion 12/21.00
ECU serial number 000901320210851302280010610260
ECU serial number(hex) 30 30 30 39 30 31 33 32 30 32 31 30 38 35 31 33 30 32 32 38 30 30 31 30 36 31 30 32 36 30
Chassis number AAAAAAAAAAAAAAAAA  (AAAAAAAAAAAAAAAAA)
Comment:
Date: 27.01.2020
Time: 16:06:59
Varcoding of: ESP909 (16)
Coding service: 1.VCD_BS_VAR
Fragments Values
BS_VAR BS_VAR_01_Standard   00BG
Coding string Hex.: 01
Coding service: 2.VCD_Bremsassistent
Fragments Values
Empfindlichkeit normal (2500 bar/s)
Coding string Hex.: 00
Coding service: 3.VCD_Bremse_Entwicklung
Fragments Values
CP HA 70.019997
CP VA 51.020000
Codierwerte Bremse 05 07 07 03 E9 03 E9 05 05 61 A9 61 A9 61 A9 61 A9 61 A9 00 00 00 00 00 08 08 08 08 03 00 03 E9 03 E9
Kennlinie x HA 00 0A 00 14 00 28 00 50 00 A0 01 18 01 90 02 D0
Kennlinie x VA 00 0A 00 14 00 28 00 50 00 A0 01 18 01 90 02 D0
Kennlinie y HA 01 1C 01 6F 01 D8 02 5B 02 F7 03 86 03 E8 04 90
Kennlinie y VA 00 C1 01 10 01 7B 02 08 02 BC 03 6B 03 E8 04 CB
Skalierungsfaktor HA 1.434500
Skalierungsfaktor VA 2.075500
Coding string Hex.: 04 1B 00 0A 00 14 00 28 00 50 00 A0 01 18 01 90 02 D0 00 C1 01 10 01 7B 02 08 02 BC 03 6B 03 E8 04 CB 0F 6F 07 D1 00 0A 00 14 00 28 00 50 00 A0 01 18 01 90 02 D0 01 1C 01 6F 01 D8 02 5B 02 F7 03 86 03 E8 04 90 0A 6D 05 07 07 03 E9 03 E9 05 05 61 A9 61 A9 61 A9 61 A9 61 A9 00 00 00 00 00 08 08 08 08 03 00 03 E9 03 E9
Coding service: 4.VCD_Bremsencodierung
Fragments Values
Werte Bremsencodierung default   00BU
Coding service: 5.VCD_Bremslicht_fuer_TSM
Fragments Values
Bremslicht fьr TSM aktiviert ja   00B3
Coding service: 6.VCD_Field_Load_Measurement_Coding
Fragments Values
Field Load Measurement aktiv
Coding service: 7.VCD_Getriebe_Neutral_Schalter
Fragments Values
Getriebe Neutral Schalter Status kein Getriebe Neutral Schalter vorhanden 3   01C6
Coding string Hex.: 03
Coding service: 8.VCD_ICP_Lastindex
Fragments Values
Hydraulik Lebenszyklusschwelle(1) ?
Coding string Hex.: 00 00 00 04
Coding service: 9.VCD_ICP_Lastindex_Schwelle
Fragments Values
Hydraulik Lebenszyklusschwelle(2) 0xFFFFFFFF = aus
Coding string Hex.: FF FF FF FF
Coding service: 10.VCD_Karosseriedaten
Fragments Values
Karosseriedaten Kennlinie ?
Coding string Hex.: 7D A0 7D 7D 7D 7D 00 96 32 7D 13 88 FA 01 07 D0 D2 F0 23 28 A1 A1 A1 A1 02 01 02 01 02 01 02 01 A1 A1 A1 A1 02 01 02 01 02 01 02 01 28 01 28 01 28 01 28 01 FA 00 FA 00 FA 00 FA 00 75 31 75 31 7D 00 7D 00 75 31 75 31 7D 00 7D 00 75 31 75 31 7D 00 7D 00 75 31 75 31 7D 00 7D 00 28 01 28 01 28 01 28 01 0A 00 0A 00 0A 00 0A 00 28 01 28 01 28 01 28 01 0A 00 0A 00 0A 00 0A 00 20 01 20 01 1F 40 1F 40 02 59 02 59 1F 40 1F 40 27 11 27 11 64 00 64 00 41 02 59 00
Coding service: 11.VCD_Leergewicht
Fragments Values
Leergewicht ?
Coding string Hex.: F8 71
Coding service: 12.VCD_Loser_Untergrund_Logik
Fragments Values
Loser Untergrund Logik aktiviert ja
Coding service: 13.VCD_Retarder
Fragments Values
Retarder vorhanden deaktiviert   00AW
Coding service: 14.VCD_Road_Rail_Status
Fragments Values
Road Rail Status deaktiviert   00AM
Coding service: 15.VCD_System_Status_Degradierung
Fragments Values
Degradation Status ESP System vollstдndig
Coding service: 16.VCD_Variantencodierung
Fragments Values
Antrieb Heck   009H
Fahrzeuggewicht 4.6t   0098
Fahrzeugklasse T1N
Getriebe Schaltgetriebe   00A1
Karosserie Normal   009L
Konfiguration Rдder Twin   0095
Motor OM646   009V
Radstand Status lang   009E
Coding string Hex.: 02 02 02 00 00 1B 04 02
Спасибо. HW совпадает, софты разные. У меня:
0009020911 12/27.00
Но появилась проблема, блок разблокирую для кодинга, но он не дает менять кодировки. В логе ведьмы кодинг меняется, а по факту остается прежним. Перепробовал все cbf. Пробовал через smr-d. Такая же проблема.
из за разного софта допускаю, что длина кодировочной строки разная. А если попробовать софт такой же поставить?
традиционно - вывод трейса давай... что там меняется, что там не даёт.....
при чём тут софт и длина строки, если он пишет, что кодировки тут меняются, а там не меняются.... как он видит, что там что-то в одном месте меняется - не понятно.
да фиг его знает. Внизу после запсии ведиама показывает что пишет и потом считывает, там совпадают строки?
Вот именно так. В логе ведьмы, при изменении кодировки и принятия кодинга, пишет старую строку и новую, уже измененную. Типо успешно поменяла. Но по факту ничего не меняется.
Буду у тачки через пару часов. Сделаю скрины.
Все получилось.
Monaco -> Sessions -> Extended Start. Далее Allgemeine Jobs -> DJ_Entriegeln_SCN
Далее все как обычно.
Если эта команда решила вопрос, не понятно как у вас до этого проходила кодировка)!
Приветствую.
Расширенная сессия не дает полный доступ к кодировкам.
Допустим я не могу сменить грузоподъемнось на 4.6 вместо 3.5. Как тут быть? Может кто пнет в нужное направление?
Как обмануть судьбу в данном решении я знаю но хотелось бы в сток сделать!
разумеется! сессия не даёт ничего, но только в расширенной сессии можно ввести разблокировку нужного уровня для открытия кодирования. так как без этого будет
0x7EsubFunctionNotSupportedInActiveSessionThis response code indicates that the requested action will not be taken because the server does not support the requested sub-function in the session currently active. Within the programmingSession negative response code 0x12 (subFunctionNotSupported) may optionally be reported instead of negative response code 0x7F (subFunctionNotSupportedInActiveSession). This response code shall only be used when the requested sub-function is known to be supported in another session, otherwise response code 0x12 (subFunctionNotSupported) shall be used. This response code shall be supported by each diagnostic service with a sub-function parameter, if not otherwise stated in the data link specific implementation document, therefore it is not listed in the list of applicable response codes of the diagnostic services.
0x7FserviceNotSupportedInActiveSessionThis response code indicates that the requested action will not be taken because the server does not support the requested service in the session currently active. This response code shall only be used when the requested service is known to be supported in another session, otherwise response code 0x11 (serviceNotSupported) shall be used. This response code is in general supported by each diagnostic service, as not otherwise stated in the data link specific implementation document, therefore it is not listed in the list of applicable response codes of the diagnostic services.
Меня смутило наличие seed key.
Иными словами установив расширенную сессию и разблокировав scn мне нужно еще рассчитать ответный пароль для того чтобы получить доступ к изменениям оставшихся функций?
Ибо 99 % кодировок я могу поменять через расширенное и scn. Но 1 % просто закрыт.
Или все таки можно. И я что-то делаю в неправильной последовательности.
Стараюсь вникнуть в то что вы прислалию
Не пробовал, только готовлюсь.
Сделано, помогла ранее выложенная.
