c:\ProgramData\Mercedes-Benz\logs\Xentry\logstore\
По крайней мере, в 2020 там лежат логи
Зипованные xml-файлы
сообщение было автоматически прилеплено: Дек 1, 2023
вот например фрагмент
- <ECU>
<ECU_Name>CR60LS</ECU_Name>
+ <ErrorCodes rcisVisible="true" ecIsVisible="true" ecMIL="false" ecSelection="errorCode" ecType="Aftersales" ecStatus="stored" ecValue="
11B800 " ecKnown="true">
+ <ECU_environmentData>
<ECU_envData evName="ENV_CoEng_st_UB3_e" evType="eA_FLOAT32" evUnit="N/A" occurence="first">Zustands-Konverter4</ECU_envData>
<ECU_envData evName="ENV_CoEng_st_UB3_a" evType="eA_FLOAT32" evUnit="N/A" occurence="last">Zustands-Konverter4</ECU_envData>
<ECU_envData evName="ENV_Epm_nEng_UB1_e" evType="eA_FLOAT32" evUnit="1/min" occurence="first">3120</ECU_envData>
<ECU_envData evName="ENV_Epm_nEng_UB1_a" evType="eA_FLOAT32" evUnit="1/min" occurence="last">3120</ECU_envData>
<ECU_envData evName="ENV_FlTnkQnt_UB9_e" evType="eA_FLOAT32" evUnit="L" occurence="first">16.50</ECU_envData>
<ECU_envData evName="ENV_FlTnkQnt_UB9_a" evType="eA_FLOAT32" evUnit="L" occurence="last">16.50</ECU_envData>
<ECU_envData evName="ENV_FPdc_UB15_e" evType="eA_FLOAT32" evUnit="%" occurence="first">83.50</ECU_envData>
<ECU_envData evName="ENV_FPdc_UB15_a" evType="eA_FLOAT32" evUnit="%" occurence="last">83.50</ECU_envData>
<ECU_envData evName="ENV_FTP_Actl_UB14_e" evType="eA_FLOAT32" evUnit="bar" occurence="first">4.45</ECU_envData>
<ECU_envData evName="ENV_FTP_Actl_UB14_a" evType="eA_FLOAT32" evUnit="bar" occurence="last">4.45</ECU_envData>
<ECU_envData evName="ENV_FuelT_t_UB8_e" evType="eA_FLOAT32" evUnit="°C" occurence="first">36.00</ECU_envData>
<ECU_envData evName="ENV_FuelT_t_UB8_a" evType="eA_FLOAT32" evUnit="°C" occurence="last">36.00</ECU_envData>
<ECU_envData evName="ENV_InjCtl_qCurr_UB2_e" evType="eA_FLOAT32" evUnit="mm^3/hub" occurence="first">84.40</ECU_envData>
<ECU_envData evName="ENV_InjCtl_qCurr_UB2_a" evType="eA_FLOAT32" evUnit="mm^3/hub" occurence="last">84.40</ECU_envData>
<ECU_envData evName="ENV_MeUn_iActVal_UB12_e" evType="eA_FLOAT32" evUnit="A" occurence="first">0.616</ECU_envData>
<ECU_envData evName="ENV_MeUn_iActVal_UB12_a" evType="eA_FLOAT32" evUnit="A" occurence="last">0.616</ECU_envData>
<ECU_envData evName="ENV_MeUn_iSet_UB10_e" evType="eA_FLOAT32" evUnit="A" occurence="first">0.660</ECU_envData>
<ECU_envData evName="ENV_MeUn_iSet_UB10_a" evType="eA_FLOAT32" evUnit="A" occurence="last">0.660</ECU_envData>
<ECU_envData evName="ENV_PCV_iActVal_UB13_e" evType="eA_FLOAT32" evUnit="A" occurence="first">1.419</ECU_envData>
<ECU_envData evName="ENV_PCV_iActVal_UB13_a" evType="eA_FLOAT32" evUnit="A" occurence="last">1.419</ECU_envData>
<ECU_envData evName="ENV_PCV_iSet_UB11_e" evType="eA_FLOAT32" evUnit="A" occurence="first">1.408</ECU_envData>
<ECU_envData evName="ENV_PCV_iSet_UB11_a" evType="eA_FLOAT32" evUnit="A" occurence="last">1.408</ECU_envData>
<ECU_envData evName="ENV_Rail_pSetPoint_UB4_e" evType="eA_FLOAT32" evUnit="bar" occurence="first">1621</ECU_envData>
<ECU_envData evName="ENV_Rail_pSetPoint_UB4_a" evType="eA_FLOAT32" evUnit="bar" occurence="last">1621</ECU_envData>
<ECU_envData evName="ENV_Rail_stCPC_UB7_e" evType="eA_FLOAT32" evUnit="N/A" occurence="first">7.00</ECU_envData>
<ECU_envData evName="ENV_Rail_stCPC_UB7_a" evType="eA_FLOAT32" evUnit="N/A" occurence="last">7.00</ECU_envData>
<ECU_envData evName="ENV_Rail_stCtlLoop_UB6_e" evType="eA_FLOAT32" evUnit="N/A" occurence="first">Zustands-Konverter2</ECU_envData>
<ECU_envData evName="ENV_Rail_stCtlLoop_UB6_a" evType="eA_FLOAT32" evUnit="N/A" occurence="last">Zustands-Konverter2</ECU_envData>
<ECU_envData evName="ENV_RailP_pFlt_UB5_e" evType="eA_FLOAT32" evUnit="bar" occurence="first">1183</ECU_envData>
<ECU_envData evName="ENV_RailP_pFlt_UB5_a" evType="eA_FLOAT32" evUnit="bar" occurence="last">1183</ECU_envData>
<ECU_envData evName="ENV_Haeufigkeitszaehler" evType="eMULTIPLEXER" evUnit="N/A" occurence="last">1.00</ECU_envData>
<ECU_envData evName="ENV_Betriebszykluszaehler" evType="eTEXTTABLE" evUnit="N/A" occurence="last">Seit 4 Betriebszyklen nicht aufgetreten</ECU_envData>
<ECU_envData evName="ENV_Kilometerstand_Erstes_Auftreten" evType="eMULTIPLEXER" evUnit="km" occurence="first">99186.00</ECU_envData>
<ECU_envData evName="ENV_Kilometerstand_Letztes_Auftreten" evType="eMULTIPLEXER" evUnit="km" occurence="last">99186.00</ECU_envData>
</ECU_environmentData>
- <Name id="11324">
<Text localized_text="
Отклонение регулировки при регулировании давления в рампе через дозирующий клапан слишком велико ." />
</Name>
</ErrorCodes>
</ECU>
<Clear_Error_Code>false</Clear_Error_Code>
Тобишь сама ошибка и все сопутствующие, которые выводятся в Xentry
