Не шьётся блок фары HLI_FL247 - A Signature error occured while checking the just flashed block | Страница 3 | benzpro
Messages in Flash Control created at 14:00:30  on 05.07.2023
Software Version 8.16.015
2023-07-05 13:47:58  Flash process in progress. Currently flashing session: 2479020201_001_172900_SW_HLI
2023-07-05 13:47:58   ODX version: 0.6.7
2023-07-05 13:47:58  >>>>> JobPosition: job started job started {
2023-07-05 13:47:58  JobVersion: 1.0.17
2023-07-05 13:47:58  JobName: HLI_Fx247
2023-07-05 13:47:58  TemplateVersion: 9.2.4
2023-07-05 13:47:58  TemplateName: DaimlerUDSFlashjob
2023-07-05 13:47:58  Inputparameter:
2023-07-05 13:47:58      debug = NORMAL_MODE
2023-07-05 13:47:58      jobState = PREPTRANSFIN
2023-07-05 13:47:58  ECUBaseVariant = HLI_FL247
2023-07-05 13:47:58  ECUVariant     = HLI_FL247_Boot_Variante_R7_1
2023-07-05 13:47:58  Protocol       = UDS_CAN_D
2023-07-05 13:47:58  JobQualifier   = WVC_FlashProg (com.daimler.odxjobs.flash.uds.MCD3_GenericUdsFlashjob)
2023-07-05 13:47:58  >>>>> JobPosition: ReadingConfigFile reading the xml file to retrive ECU information {
2023-07-05 13:47:58  }
2023-07-05 13:47:58  Using debug state NORMAL_MODE
2023-07-05 13:47:58  WARNING null
2023-07-05 13:47:58  >>>>> JobPosition: Initialization Initialization of Dlls {
2023-07-05 13:47:58  Logical block ID: 0
2023-07-05 13:47:58  Department = Development
2023-07-05 13:47:58  TesterID: 0x1
2023-07-05 13:47:58  executing service ReadFingerprint_Read
2023-07-05 13:47:58  RQ_ReadFingerprint_Read [22 F1 5B]
2023-07-05 13:47:58      Positive Response from ECU [62 F1 5B 56 00 04 17 07 05 00 00 00 01]
2023-07-05 13:47:58  Software_Programmed_and_Valid: Software invalid
2023-07-05 13:47:58  Software_Software_Mismatch: mismatch occurred
2023-07-05 13:47:58  Software_Hardware_Mismatch: mismatch occurred
2023-07-05 13:47:58  Memory_Status_Information: Memory Programmed
2023-07-05 13:47:58  Reprogramming_Process_State_1: Memory check unsuccessful
2023-07-05 13:47:58  Supplier_Identification: MB
2023-07-05 13:47:58  SW_Programming_year: 23
2023-07-05 13:47:58  SW_Programming_month: 7
2023-07-05 13:47:58  SW_Programming_day: 5
2023-07-05 13:47:58  Diagnostic_Tool_Serial_Number: 00 00 00 01
2023-07-05 13:47:58
2023-07-05 13:47:58  executing service BootSoftwareVersion_Read
2023-07-05 13:47:58  RQ_BootSoftwareVersion_Read [22 F1 53]
2023-07-05 13:47:58      Positive Response from ECU [62 F1 53 11 26 00]
2023-07-05 13:47:58  Boot_SW_year: 17
2023-07-05 13:47:58  Boot_SW_week: 38
2023-07-05 13:47:58  Boot_SW_patch_level: 0
2023-07-05 13:47:58
2023-07-05 13:47:58  executing service HardwareVersion_Read
2023-07-05 13:47:58  RQ_HardwareVersion_Read [22 F1 50]
2023-07-05 13:47:58      Positive Response from ECU [62 F1 50 11 14 00]
2023-07-05 13:47:58  HW_year: 17
2023-07-05 13:47:58  HW_week: 20
2023-07-05 13:47:58  HW_patch_level: 0
2023-07-05 13:47:58
2023-07-05 13:47:58  executing service SoftwareVersion_Read
2023-07-05 13:47:58  RQ_SoftwareVersion_Read [22 F1 51]
2023-07-05 13:47:58      Positive Response from ECU [62 F1 51 11 27 00]
2023-07-05 13:47:58  SEVERE  Severity: eERROR Severity: eERROR
2023-07-05 13:47:58  SEVERE         Code: 49192, CodeDescription: The interpretation of a Service failed.
2023-07-05 13:47:58  SEVERE         VendorCode: 54179, VendorCodeDescription: Error: MaxLength violation (PDU is too long), Required bytes: 32, available: 48.
2023-07-05 13:47:58  executing service Reprogramming_Attempt_Counter_Read
2023-07-05 13:47:58  RQ_Reprogramming_Attempt_Counter_Read [22 01 00]
2023-07-05 13:47:58      Positive Response from ECU [62 01 00 00 15 10 00]
2023-07-05 13:47:58  Number_of_Reprogramming_Attempts_Counter_0: 21
2023-07-05 13:47:58  Max_Number_of_Reprogramming_Attempts_Counter_0: 4096
2023-07-05 13:47:58
2023-07-05 13:47:58  current Monitoring state:true
2023-07-05 13:47:58  Using Jobstate PREPTRANSFIN
2023-07-05 13:47:58  Build-Date:Release <07.12.2018 12:17:09,72>
2023-07-05 13:47:58  Global Flashstate: Flash state not set
2023-07-05 13:47:58  RequestId: 0x650
2023-07-05 13:47:58  ResponseId: 0x5d0
2023-07-05 13:47:58  P2Max:2100000
2023-07-05 13:47:58  RC78CompletionTimeout:60000000
2023-07-05 13:47:58  >>>>> JobPosition: VarIdentification identifying the FBL Version with the Active Diagnostic Information service {
2023-07-05 13:47:58  executing service ActiveDiagnosticInformation_Read
2023-07-05 13:47:58  RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-07-05 13:47:58      Positive Response from ECU [62 F1 00 01 05 06 03]
2023-07-05 13:47:58  >>>>> JobPosition: StartSessionProgramming setting ECU into programming Session {
2023-07-05 13:47:58  WARNING unable to find service via shortcut qualifier
2023-07-05 13:47:58  Exception of StartSecureDiagSessionservice not found in database > Could not find serivce 'StartSecureDiagSession' by ShortName or interal service list.
2023-07-05 13:47:58  executing service Programming_Start
2023-07-05 13:47:58  RQ_Programming_Start [10 02]
2023-07-05 13:47:58      Positive Response from ECU [50 02 00 14 00 C8]
2023-07-05 13:47:58  wait for 3100 ms for PDU api to get internal state ready
2023-07-05 13:47:58  Waiting 0 of 3 s
2023-07-05 13:47:59  Waiting 1 of 3 s
2023-07-05 13:48:00  Waiting 2 of 3 s
2023-07-05 13:48:01  Waiting2 for 3100ms
2023-07-05 13:48:01  Start waiting for ECU availabilty in session 2 for max. of 30000ms
2023-07-05 13:48:01  executing service ActiveDiagnosticInformation_Read
2023-07-05 13:48:01  RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-07-05 13:48:01      Positive Response from ECU [62 F1 00 01 05 06 02]
2023-07-05 13:48:01  Session change successful
2023-07-05 13:48:01  ProgSession change:3s
2023-07-05 13:48:01  }
2023-07-05 13:48:01  DiagnosticStatusOfEcu: 0x1
2023-07-05 13:48:01  DiagnosticVariant: 0x5
2023-07-05 13:48:01  DiagnosticVersion: 0x6
2023-07-05 13:48:01  DiagnosticSession: 0x2
2023-07-05 13:48:01  Active DiagnosticVariant: 0x506
2023-07-05 13:48:01  Used variant: Development
2023-07-05 13:48:01  Bootloader Revision: REV_G Security Class: CLASS_CCC Signature Key Type: DEVELOPMENT sendCrc = true key length = 4
2023-07-05 13:48:01  Use data compression: false
2023-07-05 13:48:01  jobstate set to PREPTRANSFIN but ecu does not support stateflash therefore switching to classic mode
2023-07-05 13:48:01  >>>>> JobPosition: SetComparameter setting comunication parameters {
2023-07-05 13:48:01  >>>>> JobPosition: SecurityAccessViaJar calculating the security key with Jar {
2023-07-05 13:48:01  loading secure jar HLI_Fx247_16_03_03.jar.pgp
2023-07-05 13:48:01  ISeedKey plugin successfully loaded
2023-07-05 13:48:01  requesting seed for sa
2023-07-05 13:48:01  HexService [27 11]
2023-07-05 13:48:01      Positive Response from ECU [67 11 39 B0 97 3F 9E 76 6E C0]
2023-07-05 13:48:01  Security Access - Calculating Key from Seed
2023-07-05 13:48:01  GenerateKeyExOpt returned: KGRE_Ok
2023-07-05 13:48:01  HexService [27 12 1A 04 3A AC]
2023-07-05 13:48:01      Positive Response from ECU [67 12]
2023-07-05 13:48:01  Security Access Successful
2023-07-05 13:48:01  Block size and STmin parameter not set.
2023-07-05 13:48:01  >>>>> JobPosition: WriteFingerPrint writing date and tester information {
2023-07-05 13:48:01  Programming Date: Wed Jul 05 13:48:01 MSK 2023 used BlockId: 0
2023-07-05 13:48:01  HexService [2E F1 5A 00 04 17 07 05 00 00 00 01]
2023-07-05 13:48:01      Positive Response from ECU [6E F1 5A]
2023-07-05 13:48:01  Baudrate parameter not set
2023-07-05 13:48:01  >>>>> JobPosition: ProgrammingState getting programmingstate of logical block {
2023-07-05 13:48:01  blockstate of block 0 is Memorycheckunsuccessful
2023-07-05 13:48:01  >>>>> JobPosition: DownloadSwil1 download of swil1 {
2023-07-05 13:48:01  com.daimler.odxjobs.flash.Swil@68280b
2023-07-05 13:48:01  >>>>> JobPosition: DownloadSwilBlockStartTransfer start transfer of swil data {
2023-07-05 13:48:01  HexService [34 00 44 FE DF 80 00 00 00 20 00]
2023-07-05 13:48:01      Positive Response from ECU [74 20 0F 02]
2023-07-05 13:48:01  maxNumberOfBlockLength: 3840 bytes:8192
2023-07-05 13:48:01  >>>>> JobPosition: DownloadSwilBlockTransfer transfering swill data {
2023-07-05 13:48:01  Will download: 8192 bytes
2023-07-05 13:48:02  }
2023-07-05 13:48:02  >>>>> JobPosition: DownloadSwilBlockTransferExit ending swil data transfer {
2023-07-05 13:48:02  HexService [37]
2023-07-05 13:48:02      Positive Response from ECU [77]
2023-07-05 13:48:02  >>>>> JobPosition: CheckMemSwil1 checkmemory of swil1 {
2023-07-05 13:48:02  HexService [31 01 02 02 00 04 31 EF 3F 53 00 80 44 74 39 DD BD 01 83 69 38 C2 53 28 7D FC 8C E4 0E F3 00 9D EC 00 91 E9 38 49 D2 37 6F 89 19 A3 C1 95 6B D5 3B 0A 43 A3 0D 90 12 85 73 E7 96 58 0A 55 44 79 5A 93 DA 89 30 81 77 B2 1D 38 4D E1 91 69 03 54 86 B4 42 3B E0 A6 86 AA 7F 7B 49 2D 42 71 82 67 3D F1 08 17 DE D2 E9 BD 6D D7 DD 85 F4 F2 A2 8B 38 F1 CE 90 6A 89 7F DB 87 3E C3 23 D2 14 4E 65 76 50 63 B0 A3 26 FA D0 49 A6 E2 13]
2023-07-05 13:48:02      Positive Response from ECU [71 01 02 02 00 00]
2023-07-05 13:48:02  >>>>> JobPosition: Erase erase of the flash memory {
2023-07-05 13:48:02  HexService [31 01 FF 00 01 00]
2023-07-05 13:48:06      Positive Response from ECU [71 01 FF 00 00 00]
2023-07-05 13:48:06  }
2023-07-05 13:48:06  >>>>> JobPosition: DownloadDataBlock Download of application data {
2023-07-05 13:48:06  Flashing DataBlock _2479020201_001_172900_SW_HLI
2023-07-05 13:48:06  DataBlockType: CODE
2023-07-05 13:48:06  Partnumber: 2479020201_002
2023-07-05 13:48:06  Available number of Flash Segments: 1
2023-07-05 13:48:06  Will download totalNoBytes: 1032192
2023-07-05 13:48:06  start segment: 0 block offset:0
2023-07-05 13:48:06  Downloading segment 0
2023-07-05 13:48:06  Segment_0x00004000_0x000FFFFF Size uncompressed:1032192 start:16384
2023-07-05 13:48:06  >>>>> JobPosition: DownloadDataBlockStartTransfer initiating data transfer of application {
2023-07-05 13:48:06  HexService [34 00 44 00 00 40 00 00 0F C0 00]
2023-07-05 13:48:06      Negative Response from ECU [7F 34 31] (Request Out Of Range)
2023-07-05 13:48:06  SEVERE >>>>> NrcException {
2023-07-05 13:48:06  SEVERE  Severity: eERROR Severity: eERROR
        Code: 51712, CodeDescription: JobError occured
        VendorCode: 21910, VendorCodeDescription: Position: DownloadDataBlockStartTransfer > Negative response received HexService PDU [34 00 44 00 00 40 00 00 0F C0 ... ]  > [7F 34 31] Request Out Of Range > error while sending downloadrequest
2023-07-05 13:48:06  SEVERE com.daimler.odxjobs.exception.NrcException: Negative response received HexService PDU [34 00 44 00 00 40 00 00 0F C0 ... ]  > [7F 34 31] Request Out Of Range > error while sending downloadrequest
    at com.daimler.odxjobs.common.ComObject.sendRequest(ComObject.java:98)
    at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.sendRequestDownload(AbstractUdsFlashJob.java:2114)
    at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.downloadFlashSegment(AbstractUdsFlashJob.java:1902)
    at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.downloadFlashData(AbstractUdsFlashJob.java:1664)
    at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.startMajorProgrammingSequence(AbstractUdsFlashJob.java:628)
    at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.executeJobTask(AbstractUdsFlashJob.java:282)
    at com.daimler.odxjobs.flash.uds.MCD3_GenericUdsFlashjob.executeJobTask(MCD3_GenericUdsFlashjob.java:79)
    at com.daimler.odxjobs.common.AbstractSingleEcuJob.execute(AbstractSingleEcuJob.java:268)
    at com.daimler.odxjobs.flash.AbstractFlashJob.execute(AbstractFlashJob.java:127)
    at JobProcessor.JobThread.run(Unknown Source)
2023-07-05 13:48:06  SEVERE }
2023-07-05 13:48:06  SEVERE         Code: 51712, CodeDescription: Unknown error code
2023-07-05 13:48:06  SEVERE         VendorCode: 21910, VendorCodeDescription: JobError occured .21910 Position: DownloadDataBlockStartTransfer > Negative response received HexService PDU [34 00 44 00 00 40 00 00 0F C0 ... ]  > [7F 34 31] Request Out Of Range > error while sending downloadrequest
2023-07-05 13:48:06  SEVERE Execution State = eALL_FAILED
2023-07-05 13:48:06  SEVERE Error occurred during job execution!
2023-07-05 13:48:06  Job duration: 0h 0m 8s 123ms
2023-07-05 13:48:06  Total number of bytes transferred: 8 192
2023-07-05 13:48:06  Transfer rate: 12281byte/s
2023-07-05 13:48:06  Transfer time: 0 s
2023-07-05 13:48:06  Uncompressed transfer Time: 0 s
2023-07-05 13:48:06  Erase time: 3s
2023-07-05 13:48:06  Checkmemory time: 0s
2023-07-05 13:48:06  Checkdependency time: 0s
2023-07-05 13:48:06  WARNING Erasetime differs significantly from Tested time, expected time:9
2023-07-05 13:48:06  Flash process stopped due to error!
2023-07-05 13:57:42  Flash process in progress. Currently flashing session: 2479026401_001_181700_SW_HLI
2023-07-05 13:57:42   ODX version: 0.6.7
2023-07-05 13:57:42  >>>>> JobPosition: job started job started {
2023-07-05 13:57:42  JobVersion: 1.0.17
2023-07-05 13:57:42  JobName: HLI_Fx247
2023-07-05 13:57:42  TemplateVersion: 9.2.4
2023-07-05 13:57:42  TemplateName: DaimlerUDSFlashjob
2023-07-05 13:57:42  Inputparameter:
2023-07-05 13:57:42      debug = NORMAL_MODE
2023-07-05 13:57:42      jobState = PREPTRANSFIN
2023-07-05 13:57:42  ECUBaseVariant = HLI_FL247
2023-07-05 13:57:42  ECUVariant     = HLI_FL247_Boot_Variante_R7_1
2023-07-05 13:57:42  Protocol       = UDS_CAN_D
2023-07-05 13:57:42  JobQualifier   = WVC_FlashProg (com.daimler.odxjobs.flash.uds.MCD3_GenericUdsFlashjob)
2023-07-05 13:57:42  >>>>> JobPosition: ReadingConfigFile reading the xml file to retrive ECU information {
2023-07-05 13:57:42  }
2023-07-05 13:57:42  Using debug state NORMAL_MODE
2023-07-05 13:57:42  WARNING null
2023-07-05 13:57:42  >>>>> JobPosition: Initialization Initialization of Dlls {
2023-07-05 13:57:42  Logical block ID: 0
2023-07-05 13:57:42  Department = Development
2023-07-05 13:57:42  TesterID: 0x1
2023-07-05 13:57:42  executing service ReadFingerprint_Read
2023-07-05 13:57:42  RQ_ReadFingerprint_Read [22 F1 5B]
2023-07-05 13:57:43      Positive Response from ECU [62 F1 5B 0E 00 04 17 07 05 00 00 00 01]
2023-07-05 13:57:43  Software_Programmed_and_Valid: Software invalid
2023-07-05 13:57:43  Software_Software_Mismatch: mismatch occurred
2023-07-05 13:57:43  Software_Hardware_Mismatch: mismatch occurred
2023-07-05 13:57:43  Memory_Status_Information: Memory Erased
2023-07-05 13:57:43  Reprogramming_Process_State_1: Block valid
2023-07-05 13:57:43  Supplier_Identification: MB
2023-07-05 13:57:43  SW_Programming_year: 23
2023-07-05 13:57:43  SW_Programming_month: 7
2023-07-05 13:57:43  SW_Programming_day: 5
2023-07-05 13:57:43  Diagnostic_Tool_Serial_Number: 00 00 00 01
2023-07-05 13:57:43
2023-07-05 13:57:43  executing service BootSoftwareVersion_Read
2023-07-05 13:57:43  RQ_BootSoftwareVersion_Read [22 F1 53]
2023-07-05 13:57:43      Positive Response from ECU [62 F1 53 11 26 00]
2023-07-05 13:57:43  Boot_SW_year: 17
2023-07-05 13:57:43  Boot_SW_week: 38
2023-07-05 13:57:43  Boot_SW_patch_level: 0
2023-07-05 13:57:43
2023-07-05 13:57:43  executing service HardwareVersion_Read
2023-07-05 13:57:43  RQ_HardwareVersion_Read [22 F1 50]
2023-07-05 13:57:43      Positive Response from ECU [62 F1 50 11 14 00]
2023-07-05 13:57:43  HW_year: 17
2023-07-05 13:57:43  HW_week: 20
2023-07-05 13:57:43  HW_patch_level: 0
2023-07-05 13:57:43
2023-07-05 13:57:43  executing service SoftwareVersion_Read
2023-07-05 13:57:43  RQ_SoftwareVersion_Read [22 F1 51]
2023-07-05 13:57:43      Positive Response from ECU [62 F1 51 11 27 00]
2023-07-05 13:57:43  SEVERE  Severity: eERROR Severity: eERROR
2023-07-05 13:57:43  SEVERE         Code: 49192, CodeDescription: The interpretation of a Service failed.
2023-07-05 13:57:43  SEVERE         VendorCode: 54179, VendorCodeDescription: Error: MaxLength violation (PDU is too long), Required bytes: 32, available: 48.
2023-07-05 13:57:43  executing service Reprogramming_Attempt_Counter_Read
2023-07-05 13:57:43  RQ_Reprogramming_Attempt_Counter_Read [22 01 00]
2023-07-05 13:57:43      Positive Response from ECU [62 01 00 00 16 10 00]
2023-07-05 13:57:43  Number_of_Reprogramming_Attempts_Counter_0: 22
2023-07-05 13:57:43  Max_Number_of_Reprogramming_Attempts_Counter_0: 4096
2023-07-05 13:57:43
2023-07-05 13:57:43  current Monitoring state:true
2023-07-05 13:57:43  Using Jobstate PREPTRANSFIN
2023-07-05 13:57:43  Build-Date:Release <07.12.2018 12:17:09,72>
2023-07-05 13:57:43  }
2023-07-05 13:57:43  Global Flashstate: Flash state not set
2023-07-05 13:57:43  RequestId: 0x650
2023-07-05 13:57:43  ResponseId: 0x5d0
2023-07-05 13:57:43  P2Max:2100000
2023-07-05 13:57:43  RC78CompletionTimeout:60000000
2023-07-05 13:57:43  >>>>> JobPosition: VarIdentification identifying the FBL Version with the Active Diagnostic Information service {
2023-07-05 13:57:43  executing service ActiveDiagnosticInformation_Read
2023-07-05 13:57:43  RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-07-05 13:57:43      Positive Response from ECU [62 F1 00 01 05 06 03]
2023-07-05 13:57:43  >>>>> JobPosition: StartSessionProgramming setting ECU into programming Session {
2023-07-05 13:57:43  WARNING unable to find service via shortcut qualifier
2023-07-05 13:57:43  Exception of StartSecureDiagSessionservice not found in database > Could not find serivce 'StartSecureDiagSession' by ShortName or interal service list.
2023-07-05 13:57:43  executing service Programming_Start
2023-07-05 13:57:43  RQ_Programming_Start [10 02]
2023-07-05 13:57:43      Positive Response from ECU [50 02 00 14 00 C8]
2023-07-05 13:57:43  wait for 3100 ms for PDU api to get internal state ready
2023-07-05 13:57:43  Waiting 0 of 3 s
2023-07-05 13:57:44  Waiting 1 of 3 s
2023-07-05 13:57:45  Waiting 2 of 3 s
2023-07-05 13:57:46  Waiting2 for 3100ms
2023-07-05 13:57:46  Start waiting for ECU availabilty in session 2 for max. of 30000ms
2023-07-05 13:57:46  executing service ActiveDiagnosticInformation_Read
2023-07-05 13:57:46  RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-07-05 13:57:46      Positive Response from ECU [62 F1 00 01 05 06 02]
2023-07-05 13:57:46  Session change successful
2023-07-05 13:57:46  ProgSession change:3s
2023-07-05 13:57:46  }
2023-07-05 13:57:46  DiagnosticStatusOfEcu: 0x1
2023-07-05 13:57:46  DiagnosticVariant: 0x5
2023-07-05 13:57:46  DiagnosticVersion: 0x6
2023-07-05 13:57:46  DiagnosticSession: 0x2
2023-07-05 13:57:46  Active DiagnosticVariant: 0x506
2023-07-05 13:57:46  Used variant: Development
2023-07-05 13:57:46  Bootloader Revision: REV_G Security Class: CLASS_CCC Signature Key Type: DEVELOPMENT sendCrc = true key length = 4
2023-07-05 13:57:46  Use data compression: false
2023-07-05 13:57:46  jobstate set to PREPTRANSFIN but ecu does not support stateflash therefore switching to classic mode
2023-07-05 13:57:46  >>>>> JobPosition: SetComparameter setting comunication parameters {
2023-07-05 13:57:46  >>>>> JobPosition: SecurityAccessViaJar calculating the security key with Jar {
2023-07-05 13:57:46  loading secure jar HLI_Fx247_16_03_03.jar.pgp
2023-07-05 13:57:46  ISeedKey plugin successfully loaded
2023-07-05 13:57:46  requesting seed for sa
2023-07-05 13:57:46  HexService [27 11]
2023-07-05 13:57:46      Positive Response from ECU [67 11 7E 09 3E D9 30 FE D4 E3]
2023-07-05 13:57:46  Security Access - Calculating Key from Seed
2023-07-05 13:57:46  GenerateKeyExOpt returned: KGRE_Ok
2023-07-05 13:57:46  HexService [27 12 D0 CF 21 FF]
2023-07-05 13:57:46      Positive Response from ECU [67 12]
2023-07-05 13:57:46  Security Access Successful
2023-07-05 13:57:46  Block size and STmin parameter not set.
2023-07-05 13:57:46  >>>>> JobPosition: WriteFingerPrint writing date and tester information {
2023-07-05 13:57:46  Programming Date: Wed Jul 05 13:57:46 MSK 2023 used BlockId: 0
2023-07-05 13:57:46  HexService [2E F1 5A 00 04 17 07 05 00 00 00 01]
2023-07-05 13:57:46      Positive Response from ECU [6E F1 5A]
2023-07-05 13:57:46  Baudrate parameter not set
2023-07-05 13:57:46  >>>>> JobPosition: ProgrammingState getting programmingstate of logical block {
2023-07-05 13:57:46  blockstate of block 0 is Blockvalid
2023-07-05 13:57:46  >>>>> JobPosition: DownloadSwil1 download of swil1 {
2023-07-05 13:57:46  com.daimler.odxjobs.flash.Swil@639ce6
2023-07-05 13:57:46  >>>>> JobPosition: DownloadSwilBlockStartTransfer start transfer of swil data {
2023-07-05 13:57:46  HexService [34 00 44 FE DF 80 00 00 00 20 00]
2023-07-05 13:57:46      Positive Response from ECU [74 20 0F 02]
2023-07-05 13:57:46  maxNumberOfBlockLength: 3840 bytes:8192
2023-07-05 13:57:46  >>>>> JobPosition: DownloadSwilBlockTransfer transfering swill data {
2023-07-05 13:57:46  Will download: 8192 bytes
2023-07-05 13:57:46  >>>>> JobPosition: DownloadSwilBlockTransferExit ending swil data transfer {
2023-07-05 13:57:46  HexService [37]
2023-07-05 13:57:46      Positive Response from ECU [77]
2023-07-05 13:57:46  >>>>> JobPosition: CheckMemSwil1 checkmemory of swil1 {
2023-07-05 13:57:46  HexService [31 01 02 02 00 04 31 EF 3F 53 00 80 44 74 39 DD BD 01 83 69 38 C2 53 28 7D FC 8C E4 0E F3 00 9D EC 00 91 E9 38 49 D2 37 6F 89 19 A3 C1 95 6B D5 3B 0A 43 A3 0D 90 12 85 73 E7 96 58 0A 55 44 79 5A 93 DA 89 30 81 77 B2 1D 38 4D E1 91 69 03 54 86 B4 42 3B E0 A6 86 AA 7F 7B 49 2D 42 71 82 67 3D F1 08 17 DE D2 E9 BD 6D D7 DD 85 F4 F2 A2 8B 38 F1 CE 90 6A 89 7F DB 87 3E C3 23 D2 14 4E 65 76 50 63 B0 A3 26 FA D0 49 A6 E2 13]
2023-07-05 13:57:47      Positive Response from ECU [71 01 02 02 00 00]
2023-07-05 13:57:47  }
2023-07-05 13:57:47  >>>>> JobPosition: Erase erase of the flash memory {
2023-07-05 13:57:47  HexService [31 01 FF 00 01 00]
2023-07-05 13:57:47      Positive Response from ECU [71 01 FF 00 00 00]
2023-07-05 13:57:47  >>>>> JobPosition: DownloadDataBlock Download of application data {
2023-07-05 13:57:47  Flashing DataBlock _2479026401_001_181700_SW_HLI
2023-07-05 13:57:47  DataBlockType: CODE
2023-07-05 13:57:47  Partnumber: 2479026401_001
2023-07-05 13:57:47  Available number of Flash Segments: 1
2023-07-05 13:57:47  Will download totalNoBytes: 999424
2023-07-05 13:57:47  start segment: 0 block offset:0
2023-07-05 13:57:47  Downloading segment 0
2023-07-05 13:57:47  Segment_0x00004000_0x000F7FFF Size uncompressed:999424 start:16384
2023-07-05 13:57:47  >>>>> JobPosition: DownloadDataBlockStartTransfer initiating data transfer of application {
2023-07-05 13:57:47  HexService [34 00 44 00 00 40 00 00 0F 40 00]
2023-07-05 13:57:47      Positive Response from ECU [74 20 0F 02]
2023-07-05 13:57:47  maxNumberOfBlockLength: 3840 bytes:999424
2023-07-05 13:57:47  >>>>> JobPosition: DownloadDataBlockTransfer transfering data of application {
2023-07-05 13:59:08  }
2023-07-05 13:59:08  >>>>> JobPosition: DownloadDataBlockTransferExit ending data transfer of application {
2023-07-05 13:59:08  HexService [37]
2023-07-05 13:59:08      Positive Response from ECU [77]
2023-07-05 13:59:08  Download of data block finished in 80s
2023-07-05 13:59:08  >>>>> JobPosition: CheckMemData checkmemory of data or applikation {
2023-07-05 13:59:08  1 flash securities found!
2023-07-05 13:59:08  Using security class CLASS_CCC
2023-07-05 13:59:08  HexService [31 01 02 02 00 04 DD 3E 0D F0 00 80 24 15 AB AB AB 31 45 CE 22 FD 34 3E 2B 83 D4 99 C5 22 D2 DB 6E A0 B1 02 A3 D2 29 51 84 73 24 21 7E 17 48 15 5B 05 C8 F6 75 DF DF 54 4E D9 FF EB DA A3 6F 61 B3 FE 19 DA CC 32 83 E7 BE 6E 81 58 D4 3A 92 D8 78 E8 0D F8 7E 13 23 2F 4F 79 DE 61 AB 27 AE 2E 6A BC 21 19 70 C4 7D 3F 78 D8 D1 A4 FE 90 19 34 0E FF FA 66 CC 8B 27 8C 4B 07 BD AB AC F0 F2 44 01 9D 44 21 23 B9 1B 8F 84 56 13 EF]
2023-07-05 13:59:08      Positive Response from ECU [71 01 02 02 00 04]
2023-07-05 13:59:08  SEVERE >>>>> InternalJobException {
2023-07-05 13:59:08  SEVERE  Severity: eERROR Severity: eERROR
        VendorCode: 21781, VendorCodeDescription: Position: CheckMemData > A Signature error occured while checking the just flashed block
2023-07-05 13:59:08  SEVERE com.daimler.odxjobs.exception.InternalJobException: A Signature error occured while checking the just flashed block
    at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.checkMemoryRoutine(AbstractUdsFlashJob.java:2237)
    at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.downloadFlashData(AbstractUdsFlashJob.java:1691)
2023-07-05 13:59:08  SEVERE }
2023-07-05 13:59:08  SEVERE         Code: 51712, CodeDescription: Unknown error code
2023-07-05 13:59:08  SEVERE         VendorCode: 21781, VendorCodeDescription: JobError occured .21781 Position: CheckMemData > A Signature error occured while checking the just flashed block
2023-07-05 13:59:08  SEVERE Execution State = eALL_FAILED
2023-07-05 13:59:08  SEVERE Error occurred during job execution!
2023-07-05 13:59:08  Job duration: 0h 1m 25s 517ms
2023-07-05 13:59:08  Total number of bytes transferred: 1 007 616
2023-07-05 13:59:08  Transfer rate: 12364byte/s
2023-07-05 13:59:08  Transfer time: 81 s
2023-07-05 13:59:08  Uncompressed transfer Time: 80 s
2023-07-05 13:59:08  Erase time: 0s
2023-07-05 13:59:08  Checkmemory time: 0s
2023-07-05 13:59:08  Checkdependency time: 0s
2023-07-05 13:59:08  Flash process stopped due to error!
Software_Programmed_and_Valid: Software invalid 2023-07-05 13:47:58 Software_Software_Mismatch: mismatch occurred 2023-07-05 13:47:58 Software_Hardware_Mismatch: mismatch occurred
Что-то с софтом
зачем вы постоянно разные логи постите? до этого одна проблема была, потом другая... выкладывайте то, что было изначально.
тот, что шили 2479023401
Я ответил по другому софту. Там указан номер прошивки в логе. Тут появилось мнение, что флеш мертвый в блоке. Есть ещё идеи у кого-то, что можно попробовать?
Какой вывод можно из этого сделать? )))
Софт родной, я не понимаю, в чем дело. Просто не ложится. Или надо что-то блоку рассказать перед прошивкой.
залить то, что было. если не льётся - смотреть лог.
Сейчас еще раз сделаю. Крымчанин приговорил блок.
Готово, залил родной софт. В конце ошибка. Сейчас говорил по блокам с поставщиками, есть версия, что блоки могут не отсюда быть. Кто может проверить? Фото с ЕПЦ сейчас скину. Там нет таких номеров.
Messages in Flash Control created at 15:45:30  on 05.07.2023
2023-07-05 15:43:23  Flash process in progress. Currently flashing session: 2479023401_001_173900_SW_HLI
2023-07-05 15:43:23   ODX version: 0.6.7
2023-07-05 15:43:23  >>>>> JobPosition: job started job started {
2023-07-05 15:43:23  JobVersion: 1.0.17
2023-07-05 15:43:23  JobName: HLI_Fx247
2023-07-05 15:43:23  TemplateVersion: 9.2.4
2023-07-05 15:43:23  TemplateName: DaimlerUDSFlashjob
2023-07-05 15:43:23  Inputparameter:
2023-07-05 15:43:23      debug = NORMAL_MODE
2023-07-05 15:43:23      jobState = PREPTRANSFIN
2023-07-05 15:43:23  ECUBaseVariant = HLI_FL247
2023-07-05 15:43:23  ECUVariant     = HLI_FL247_Boot_Variante_R7_1
2023-07-05 15:43:23  Protocol       = UDS_CAN_D
2023-07-05 15:43:23  JobQualifier   = WVC_FlashProg (com.daimler.odxjobs.flash.uds.MCD3_GenericUdsFlashjob)
2023-07-05 15:43:23  >>>>> JobPosition: ReadingConfigFile reading the xml file to retrive ECU information {
2023-07-05 15:43:23  }
2023-07-05 15:43:23  Using debug state NORMAL_MODE
2023-07-05 15:43:23  WARNING null
2023-07-05 15:43:23  >>>>> JobPosition: Initialization Initialization of Dlls {
2023-07-05 15:43:23  Logical block ID: 0
2023-07-05 15:43:23  Department = Development
2023-07-05 15:43:23  TesterID: 0x1
2023-07-05 15:43:23  executing service ReadFingerprint_Read
2023-07-05 15:43:23  RQ_ReadFingerprint_Read [22 F1 5B]
2023-07-05 15:43:23      Positive Response from ECU [62 F1 5B 56 00 04 17 07 05 00 00 00 01]
2023-07-05 15:43:23  Software_Programmed_and_Valid: Software invalid
2023-07-05 15:43:23  Software_Software_Mismatch: mismatch occurred
2023-07-05 15:43:23  Software_Hardware_Mismatch: mismatch occurred
2023-07-05 15:43:23  Memory_Status_Information: Memory Programmed
2023-07-05 15:43:23  Reprogramming_Process_State_1: Memory check unsuccessful
2023-07-05 15:43:23  Supplier_Identification: MB
2023-07-05 15:43:23  SW_Programming_year: 23
2023-07-05 15:43:23  SW_Programming_month: 7
2023-07-05 15:43:23  SW_Programming_day: 5
2023-07-05 15:43:23  Diagnostic_Tool_Serial_Number: 00 00 00 01
2023-07-05 15:43:23
2023-07-05 15:43:23  executing service BootSoftwareVersion_Read
2023-07-05 15:43:23  RQ_BootSoftwareVersion_Read [22 F1 53]
2023-07-05 15:43:23      Positive Response from ECU [62 F1 53 01 02 10]
2023-07-05 15:43:23  Boot_SW_year: 1
2023-07-05 15:43:23  Boot_SW_week: 2
2023-07-05 15:43:23  Boot_SW_patch_level: 16
2023-07-05 15:43:23
2023-07-05 15:43:23  executing service HardwareVersion_Read
2023-07-05 15:43:23  RQ_HardwareVersion_Read [22 F1 50]
2023-07-05 15:43:23      Positive Response from ECU [62 F1 50 11 14 00]
2023-07-05 15:43:23  HW_year: 17
2023-07-05 15:43:23  HW_week: 20
2023-07-05 15:43:23  HW_patch_level: 0
2023-07-05 15:43:23
2023-07-05 15:43:23  executing service SoftwareVersion_Read
2023-07-05 15:43:23  RQ_SoftwareVersion_Read [22 F1 51]
2023-07-05 15:43:23      Positive Response from ECU [62 F1 51 11 27 00]
2023-07-05 15:43:23  SEVERE  Severity: eERROR Severity: eERROR
2023-07-05 15:43:23  SEVERE         Code: 49192, CodeDescription: The interpretation of a Service failed.
2023-07-05 15:43:23  SEVERE         VendorCode: 54179, VendorCodeDescription: Error: MaxLength violation (PDU is too long), Required bytes: 32, available: 48.
2023-07-05 15:43:23  executing service Reprogramming_Attempt_Counter_Read
2023-07-05 15:43:23  RQ_Reprogramming_Attempt_Counter_Read [22 01 00]
2023-07-05 15:43:23      Positive Response from ECU [62 01 00 00 1F 10 00]
2023-07-05 15:43:23  Number_of_Reprogramming_Attempts_Counter_0: 31
2023-07-05 15:43:23  Max_Number_of_Reprogramming_Attempts_Counter_0: 4096
2023-07-05 15:43:23
2023-07-05 15:43:23  current Monitoring state:true
2023-07-05 15:43:23  Using Jobstate PREPTRANSFIN
2023-07-05 15:43:23  Build-Date:Release <07.12.2018 12:17:09,72>
2023-07-05 15:43:23  Global Flashstate: Flash state not set
2023-07-05 15:43:23  RequestId: 0x650
2023-07-05 15:43:23  ResponseId: 0x5d0
2023-07-05 15:43:23  P2Max:2100000
2023-07-05 15:43:23  RC78CompletionTimeout:60000000
2023-07-05 15:43:23  >>>>> JobPosition: VarIdentification identifying the FBL Version with the Active Diagnostic Information service {
2023-07-05 15:43:23  executing service ActiveDiagnosticInformation_Read
2023-07-05 15:43:23  RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-07-05 15:43:23      Positive Response from ECU [62 F1 00 01 05 06 03]
2023-07-05 15:43:23  >>>>> JobPosition: StartSessionProgramming setting ECU into programming Session {
2023-07-05 15:43:23  WARNING unable to find service via shortcut qualifier
2023-07-05 15:43:23  Exception of StartSecureDiagSessionservice not found in database > Could not find serivce 'StartSecureDiagSession' by ShortName or interal service list.
2023-07-05 15:43:23  executing service Programming_Start
2023-07-05 15:43:23  RQ_Programming_Start [10 02]
2023-07-05 15:43:23      Positive Response from ECU [50 02 00 14 00 C8]
2023-07-05 15:43:23  wait for 3100 ms for PDU api to get internal state ready
2023-07-05 15:43:23  Waiting 0 of 3 s
2023-07-05 15:43:24  Waiting 1 of 3 s
2023-07-05 15:43:25  Waiting 2 of 3 s
2023-07-05 15:43:26  Waiting2 for 3100ms
2023-07-05 15:43:26  Start waiting for ECU availabilty in session 2 for max. of 30000ms
2023-07-05 15:43:26  executing service ActiveDiagnosticInformation_Read
2023-07-05 15:43:26  RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-07-05 15:43:26      Positive Response from ECU [62 F1 00 01 05 06 02]
2023-07-05 15:43:26  Session change successful
2023-07-05 15:43:26  ProgSession change:3s
2023-07-05 15:43:26  }
2023-07-05 15:43:26  DiagnosticStatusOfEcu: 0x1
2023-07-05 15:43:26  DiagnosticVariant: 0x5
2023-07-05 15:43:26  DiagnosticVersion: 0x6
2023-07-05 15:43:26  DiagnosticSession: 0x2
2023-07-05 15:43:26  Active DiagnosticVariant: 0x506
2023-07-05 15:43:26  Used variant: Development
2023-07-05 15:43:26  Bootloader Revision: REV_G Security Class: CLASS_CCC Signature Key Type: DEVELOPMENT sendCrc = true key length = 4
2023-07-05 15:43:26  Use data compression: false
2023-07-05 15:43:26  jobstate set to PREPTRANSFIN but ecu does not support stateflash therefore switching to classic mode
2023-07-05 15:43:26  >>>>> JobPosition: SetComparameter setting comunication parameters {
2023-07-05 15:43:26  >>>>> JobPosition: SecurityAccessViaJar calculating the security key with Jar {
2023-07-05 15:43:26  loading secure jar HLI_Fx247_16_03_03.jar.pgp
2023-07-05 15:43:26  ISeedKey plugin successfully loaded
2023-07-05 15:43:26  requesting seed for sa
2023-07-05 15:43:26  HexService [27 11]
2023-07-05 15:43:26      Positive Response from ECU [67 11 29 F1 80 F9 32 7F 8C FB]
2023-07-05 15:43:26  Security Access - Calculating Key from Seed
2023-07-05 15:43:26  GenerateKeyExOpt returned: KGRE_Ok
2023-07-05 15:43:26  HexService [27 12 CC 65 E8 C7]
2023-07-05 15:43:26      Positive Response from ECU [67 12]
2023-07-05 15:43:26  Security Access Successful
2023-07-05 15:43:26  Block size and STmin parameter not set.
2023-07-05 15:43:26  >>>>> JobPosition: WriteFingerPrint writing date and tester information {
2023-07-05 15:43:26  Programming Date: Wed Jul 05 15:43:26 MSK 2023 used BlockId: 0
2023-07-05 15:43:26  HexService [2E F1 5A 00 04 17 07 05 00 00 00 01]
2023-07-05 15:43:26      Positive Response from ECU [6E F1 5A]
2023-07-05 15:43:26  Baudrate parameter not set
2023-07-05 15:43:26  >>>>> JobPosition: ProgrammingState getting programmingstate of logical block {
2023-07-05 15:43:27  blockstate of block 0 is Memorycheckunsuccessful
2023-07-05 15:43:27  }
2023-07-05 15:43:27  >>>>> JobPosition: DownloadSwil1 download of swil1 {
2023-07-05 15:43:27  com.daimler.odxjobs.flash.Swil@68280b
2023-07-05 15:43:27  >>>>> JobPosition: DownloadSwilBlockStartTransfer start transfer of swil data {
2023-07-05 15:43:27  HexService [34 00 44 FE DF 80 00 00 00 20 00]
2023-07-05 15:43:27      Positive Response from ECU [74 20 0F 02]
2023-07-05 15:43:27  maxNumberOfBlockLength: 3840 bytes:8192
2023-07-05 15:43:27  >>>>> JobPosition: DownloadSwilBlockTransfer transfering swill data {
2023-07-05 15:43:27  Will download: 8192 bytes
2023-07-05 15:43:27  >>>>> JobPosition: DownloadSwilBlockTransferExit ending swil data transfer {
2023-07-05 15:43:27  HexService [37]
2023-07-05 15:43:27      Positive Response from ECU [77]
2023-07-05 15:43:27  >>>>> JobPosition: CheckMemSwil1 checkmemory of swil1 {
2023-07-05 15:43:27  HexService [31 01 02 02 00 04 31 EF 3F 53 00 80 44 74 39 DD BD 01 83 69 38 C2 53 28 7D FC 8C E4 0E F3 00 9D EC 00 91 E9 38 49 D2 37 6F 89 19 A3 C1 95 6B D5 3B 0A 43 A3 0D 90 12 85 73 E7 96 58 0A 55 44 79 5A 93 DA 89 30 81 77 B2 1D 38 4D E1 91 69 03 54 86 B4 42 3B E0 A6 86 AA 7F 7B 49 2D 42 71 82 67 3D F1 08 17 DE D2 E9 BD 6D D7 DD 85 F4 F2 A2 8B 38 F1 CE 90 6A 89 7F DB 87 3E C3 23 D2 14 4E 65 76 50 63 B0 A3 26 FA D0 49 A6 E2 13]
2023-07-05 15:43:27      Positive Response from ECU [71 01 02 02 00 00]
2023-07-05 15:43:27  >>>>> JobPosition: Erase erase of the flash memory {
2023-07-05 15:43:27  HexService [31 01 FF 00 01 00]
2023-07-05 15:43:31      Positive Response from ECU [71 01 FF 00 00 00]
2023-07-05 15:43:31  }
2023-07-05 15:43:31  >>>>> JobPosition: DownloadDataBlock Download of application data {
2023-07-05 15:43:31  Flashing DataBlock _2479023401_001_173900_SW_HLI
2023-07-05 15:43:31  DataBlockType: CODE
2023-07-05 15:43:31  Partnumber: 2479023401_001
2023-07-05 15:43:31  Available number of Flash Segments: 1
2023-07-05 15:43:31  Will download totalNoBytes: 999424
2023-07-05 15:43:31  start segment: 0 block offset:0
2023-07-05 15:43:31  Downloading segment 0
2023-07-05 15:43:31  Segment_0x00004000_0x000F7FFF Size uncompressed:999424 start:16384
2023-07-05 15:43:31  >>>>> JobPosition: DownloadDataBlockStartTransfer initiating data transfer of application {
2023-07-05 15:43:31  HexService [34 00 44 00 00 40 00 00 0F 40 00]
2023-07-05 15:43:31      Positive Response from ECU [74 20 0F 02]
2023-07-05 15:43:31  maxNumberOfBlockLength: 3840 bytes:999424
2023-07-05 15:43:31  >>>>> JobPosition: DownloadDataBlockTransfer transfering data of application {
2023-07-05 15:44:53  }
2023-07-05 15:44:53  >>>>> JobPosition: DownloadDataBlockTransferExit ending data transfer of application {
2023-07-05 15:44:53  HexService [37]
2023-07-05 15:44:53      Positive Response from ECU [77]
2023-07-05 15:44:53  Download of data block finished in 82s
2023-07-05 15:44:53  >>>>> JobPosition: CheckMemData checkmemory of data or applikation {
2023-07-05 15:44:53  1 flash securities found!
2023-07-05 15:44:53  Using security class CLASS_CCC
2023-07-05 15:44:53  HexService [31 01 02 02 00 04 21 25 AA DB 00 80 2A 20 CF 11 C3 AF 38 1B 0A F2 82 8B C3 52 A0 3C 0A 1C 3C F3 3F 2B 0C 59 FF C3 6B 62 1E 7E 1D 97 AA 0D 33 76 F1 1D 9D BF B2 0B B7 34 0D CB CB 38 B6 E2 FA CA EF 97 BB 02 B8 3F 06 8D 3B 27 10 E6 59 EF 72 75 CC 9E 17 0B 70 DD 3F A0 EA E7 3F 95 5C D3 5B F1 49 90 B0 41 3B 60 5F 24 C2 97 58 F6 18 F6 08 E2 2D 10 85 E9 33 BB C3 4C 33 95 56 A1 CF 33 1F CC B3 64 E7 C0 2B B3 FC 5A EB 27 10 7C]
2023-07-05 15:44:53      Positive Response from ECU [71 01 02 02 00 04]
2023-07-05 15:44:53  SEVERE >>>>> InternalJobException {
2023-07-05 15:44:53  SEVERE  Severity: eERROR Severity: eERROR
2023-07-05 15:44:53  SEVERE com.daimler.odxjobs.exception.InternalJobException: A Signature error occured while checking the just flashed block
2023-07-05 15:44:53  SEVERE }
2023-07-05 15:44:53  SEVERE         Code: 51712, CodeDescription: Unknown error code
2023-07-05 15:44:53  SEVERE         VendorCode: 21781, VendorCodeDescription: JobError occured .21781 Position: CheckMemData > A Signature error occured while checking the just flashed block
2023-07-05 15:44:53  SEVERE Execution State = eALL_FAILED
2023-07-05 15:44:53  SEVERE Error occurred during job execution!
2023-07-05 15:44:53  Job duration: 0h 1m 30s 450ms
2023-07-05 15:44:53  Total number of bytes transferred: 1 007 616
2023-07-05 15:44:53  Transfer rate: 12162byte/s
2023-07-05 15:44:53  Transfer time: 82 s
2023-07-05 15:44:53  Uncompressed transfer Time: 82 s
2023-07-05 15:44:53  Erase time: 3s
2023-07-05 15:44:53  Checkmemory time: 0s
2023-07-05 15:44:53  Checkdependency time: 0s
2023-07-05 15:44:53  WARNING Erasetime differs significantly from Tested time, expected time:9
2023-07-05 15:44:53  Flash process stopped due to error!
Фото с ЕПЦ. Но я встречал, что там может не быть деталей, которые с завода ставили.
Это я уже устал. Номер тот.
У вас блок зашился, но ошибка при проверке подписи. Как вариант- битое файло.
https://race-tun.com/europa/cffsmr-fmercedes/pkw/hlifl247/ брал отсюда, сам качал с Flash & Software finder. проверил в Хешредакторе - они одинаковые. Что-то не то. Может есть связь с тем, что софт сменился на 3600?
Попробуй другую фару прошить) может проблема в блоке
Нее, ну ее. Я могу предположить, что блок пострадал в результате перестановке в другую фару. Может и еще что делали с ним ремонтники
Зачем качать прошивки с каких то всратых сайтов
Файлы с моими совпали. Сайт норм.
и нежелании читать.
Я все прочитал. Не понимаю проблему в софте. Где взять норм софт тогда? Я тысячу блоков прошил файлами Flash & Software finder. Все работает отлично.
лечение опытными специалистами
Есть такие знакомые?
мы видели всратые фото без какой либо информации полезной. вдруг там не разблокирован файрволл? вдруг там блок не определяется верно? покажите как у вас подключено.
blin, скришотом... подключитесь к блокам, выберите флэш галочками - покажите что у вас там, старт не нажимайте...
Попробовал еще раз. Замок открыл, потом закрыл коммуникацию, открыл с HLI-FL и залил. Все то же самое. Вот скрины.
