722.9 - P179D85 ISM The redundancy system for DIRECT SELECT was activated. There is a signal above the permissible limit value. | benzpro
722.9 P179D85 ISM The redundancy system for DIRECT SELECT was activated. There is a signal above the permissible limit value.
  • Автор темы Автор темы HBP
7G Tronic
HBP
Hello, I have a W221 and the ism has a redundancy value of 100... the car doesnt start and it doesnt shift gears .
Is there any possible way for me to reset the eeprom or anything like that? Please help me out cause im new to this.
У Вас проблема из за дохлого АКБ , даже скинув колличество срабатываний , все быстро повторится вновь , нужно искать причину
You have a problem because of a dead battery, even if you reset the number of alarms, everything will quickly repeat itself again, you need to look for the cause
The car was flooded and had a lot of errors with the can bus and also battery voltages. I had replaced the main and auxiliary battery, cleaned and dried the can bus connectors and any other issues.
I recently bought a new DSM and got it programmed from someone i know it worked well for about 2 months and then again it stopped working... I just wanted to know is it possible for me to like modify the eeprom counter directly because i dont have vvdi prog or any special tools. I just have a tool called EZP2023 its an eeprom programmer.
Конкретно за Ваш программатор я не знаю , но другими все это сделать возможно
