;* This file contains vehicle specific definitions. *
;* It consists of six main sections: *
;* - [GLOBAL] contains general vehicle information like the kind of diag *
;* plug which is mounted. *
;* - [INIT] If an ECU requires a special Init service for this vehicle,*
;* this can be defined here. Syntax is: *
;* 'EcuName = ServiceName' *
;* - [COMMPARAMS] If an ECU requires special Comm parameter settings for *
;* this vehicle, this can be defined here. Syntax is: *
;* 'EcuName = CommParamName1, Value1, CommParamName2, Value2' *
;* - [ECUS] describes the ECUs which are possibly mounted within this *
;* specific vehicle. The sequence of definition reflects the *
;* initialization sequence for shorttest ! *
;* - [CONTACT CHECK] defines for each pin if a contact check is possible. *
;* Pins not declared here are assumed as 'no contact check'; *
;* Syntax is 'PINn = <percents of battery voltage>' *
;* All ECU names defined or used in this file are DAS names, except the first *
;* name in each entry of ECUS section. *
[GLOBAL]
PLUG = D_OBDII,D_Plug4
Engine =
UNIT =
VINECU = CDI4
VINService = DT_FIN_Lesen_ASCII
DISTANCEECU= KIW2M
DISTANCESERVICE= DT_Gesamtwegstrecke_Wert
[INIT]
ABZK = FN_Unlock_ARMIN_0_To_1
CDI4 = FN_SG_Entriegeln
[DRIVERTYPES]
MOST=NULL
KIN=NULL
CanB=NULL
[SKIP_IF_PRESENT]
AGW=TGW3,SND3,UCI,DAB,SDAR3,TV40,TV45,TVJP2,TELJP2
;--- The following section contains entries for each ECU.
;--- All ECUs possibly connected have to be described; K-Line ECUs as well as
;--- Members which are connected via a gateway connection.
;--- The ECUs have to be enumerated in ascending order; the numbering defines the
;--- sequence for shorttest.
;--- Each ECU entry consists of six fields:
;--- 1. Name = DIOGENES name of that ECU
;--- 2. DAS group = DAS group name of that ECU
;--- 3. Type = Single,
;--- CanBGateway, KINGateway, FPSGateway, SKNGateway
;--- CanBMember, KINMember, FPSMember, SKNMember
;--- 4. Status = MANDATORY or OPTIONAL
;--- (necessary for correct shorttest indication)
;--- 5. Pin = numerical value
;--- 6. Shorttest relevance = YES or NO; default is YES
[ECUS]
;---------- Diogenes name --group name -- Type -------------Status ------ Pin -- shorttest
ECU1 =EZS209 ,ALLEZS2 ,Single ,MANDATORY ,CAN_HS ,YES
ECU2 =EGS52 ,GETRIEBE ,Single ,MANDATORY ,CAN_HS ,YES
ECU3 =EGS53 ,GETRIEBE ,Single ,MANDATORY ,CAN_HS ,YES
ECU4 =VGSNAG2 ,GETRIEBE ,Single ,MANDATORY ,CAN_HS ,YES
ECU5 =VGSNAG2*PDTC, ,Single ,MANDATORY ,CAN_HS ,NO
ECU6 =EWM210 , ,Single ,MANDATORY ,9 ,YES
ECU7 =VGS463 , ,Single ,MANDATORY ,15 ,YES
ECU8 =CR4 , ,Single ,MANDATORY ,CAN_HS ,YES
ECU9 =ESP463 ,ALLTRAKT ,Single ,MANDATORY ,CAN_HS ,YES
ECU10 =TPM_209 , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU11 =ARMIN , ,Single ,MANDATORY ,13 ,YES
ECU12 =OBF203 , ,Single ,MANDATORY ,CAN_HS ,YES
ECU13 =SAMV463 , ,Single ,MANDATORY ,CAN_HS ,YES
ECU14 =SAMH463 , ,Single ,MANDATORY ,CAN_HS ,YES
ECU15 =DBE463 , ,Single ,MANDATORY ,CAN_HS ,YES
ECU16 =ALWR906 , ,Single ,MANDATORY ,CAN_HS ,YES
ECU17 =MSS203 , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU18 =TSGVL203 , ,Single ,MANDATORY ,CAN_HS ,YES
ECU19 =TSGVR203 , ,Single ,MANDATORY ,CAN_HS ,YES
ECU20 =TSGHL203 , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU21 =TSGHR203 , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU22 =KLA203 , ,Single ,MANDATORY ,CAN_HS ,YES
ECU23 =SSGB203 ,ALLESVB ,Single ,OPTIONAL ,CAN_HS ,YES
ECU24 =SSGB211 ,ALLESVB ,Single ,OPTIONAL ,CAN_HS ,YES
ECU25 =SSGB164 ,ALLESVB ,Single ,OPTIONAL ,CAN_HS ,YES
ECU26 =SSGF203 ,ALLESVF ,Single ,OPTIONAL ,CAN_HS ,YES
ECU27 =SSGF211 ,ALLESVF ,Single ,OPTIONAL ,CAN_HS ,YES
ECU28 =SSGF164 ,ALLESVF ,Single ,OPTIONAL ,CAN_HS ,YES
ECU29 =KI203M , ,Single ,MANDATORY ,CAN_HS ,YES
ECU30 =MRM211 ,ALLMRM ,Single ,OPTIONAL ,CAN_HS ,YES
ECU31 =MRM171 ,ALLMRM ,Single ,OPTIONAL ,CAN_HS ,YES
ECU32 =AAG203 ,ALLAAG ,Single ,OPTIONAL ,CAN_HS ,YES
ECU33 =AAG169 ,ALLAAG ,Single ,OPTIONAL ,CAN_HS ,YES
ECU34 =STH203 , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU35 =SHZ164*1 ,ALLLRK ,Single ,OPTIONAL ,CAN_HS ,NO ,
ECU36 =XAGW ,AGW ,MOSTGateway ,OPTIONAL ,CAN_HS ,YES
ECU37 =XHUAGW ,AGW ,MOSTGateway ,OPTIONAL ,CAN_HS ,YES
ECU38 =XHU ,HUALL ,MOSTMember ,OPTIONAL ,CAN_HS ,YES
ECU39 =XHUJP ,HUALL ,MOSTMember ,OPTIONAL ,CAN_HS ,YES
ECU40 =XCDC , ,MOSTMember ,OPTIONAL ,CAN_HS ,YES
ECU41 =XSBS , ,MOSTMember ,OPTIONAL ,CAN_HS ,YES
ECU42 =XSDARS , ,MOSTMember ,OPTIONAL ,CAN_HS ,YES
ECU43 =XSNDHB , ,MOSTMember ,OPTIONAL ,CAN_HS ,YES
ECU44 =TV211 ,TVALL ,MOSTMember ,OPTIONAL ,CAN_HS ,YES
ECU45 =XUHI ,CPALL ,MOSTMember ,OPTIONAL ,CAN_HS ,YES
ECU46 =XMCSNAV , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU47 =HU25 , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU48 =SOUND25 , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU49 =UCI25 , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU50 =DAB25 , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU51 =SDARS25 , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU52 =TV25 ,TV4 ,Single ,OPTIONAL ,CAN_HS ,YES
ECU53 =TV25JAP ,TV4 ,Single ,OPTIONAL ,CAN_HS ,YES
ECU54 =TV45NTG25 ,TV4 ,Single ,OPTIONAL ,CAN_HS ,YES
ECU55 =CBJ25 , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU56 =XLCT ,TCAND ,Single ,OPTIONAL ,CAN_HS ,YES
ECU57 =XLCTSERV , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU58 =XLCTECL , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU59 =XLCTREM , ,Single ,OPTIONAL ,CAN_HS ,YES
ECU60 =XLCTTRK , ,Single ,OPTIONAL ,CAN_HS ,YES
[BasicData]
;463_?_2?
WCFNAME=PKW
ServiceScopeEcu=KIW2M
ServiceScopeService=DT_STO_Zwischenwerte_Serviceintervall_Serviceumfang
TimeTilServiceEcu=KIW2M
TimeTilServiceService=DT_STO_Zwischenwerte_Serviceintervall_Restlaufzeit, d
DistanceTilServiceEcu=KIW2M
DistanceTilServiceService=DT_STO_Auslesen_WIA_Messwerte_Restlaufstrecke_Anzeige, km
