722.9 - перенос адаптаций | benzpro
722.9 перенос адаптаций
7G Tronic
dimas_500
Приветсвую, вопрос как их ложить в плату ? руками вбивать в дасе? лог создал
[SG_INFO]
FIN=xxxxxxxxxxxxxxxx
EHS_Nummer=2202702306
Programmstand=v37ba08k
Datenstand=05ssfes8
Kilometerstand=22894
Variantecodierung=y12a
ECU_Softwarenummer=0104488010
ECU_Hardwarenummer=0034460310
ECU_Seriennummer=03091270
Livetime_History=10000000900000000200000100000400
[EEPROM_BLOCK]
EEPROM_BLOCK_1=F1F127E7661D60E989138BF782196464646401040000CEBFCFE6BEB2D2EAC4BAD3FAB9B3DAF7A6B7DCE8C6ABC4D100000000CE9BBCD9031C4444000000FF0DC400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000007
EEPROM_BLOCK_2=0100000000000000000000000000000000000000000000FEFEEDECECFDFCFDFCF6FCFDFBFBFBF6FB000000FDFFFFF5F5F5F1F3F3E8E7E7020902000000000000
EEPROM_BLOCK_3=0100000000000000000000000000F2D39C30E7EDEDD8D6D602FF02F9FCF9EEF2F2FEFAFE0F0F0FDDDCDCF3F4F4EFE9E9EFE7E7F6F3F600141413ECEDFA1E03FA3600FA1203FA1C03FA0C00FA3800000000FA2102FA5D04FA6002FA0C01FA0801
EEPROM_BLOCK_4=01000000F2D7160000EFF2E70000F0EDF1ED00FFFAFC000000000000000000000000F6F2FDFF00FBFB000B00FEFA090B00000000000000000000000000000000
EEPROM_BLOCK_5=010000000BF30100000A0AFC00000C06100000CEF519000000000000000000000000150C000000F4EE000000F5EE000000000000000000000000000000000000
EEPROM_BLOCK_6=01000000FCFF01FE00FFFD01FF00000000000000000000000000000000000000000001021200000B0C1700000000000000000000000000000000000000000000
EEPROM_BLOCK_7=01000000F5F3EFECEBFDF9F5F2F20000000000DCE2E4E3E7D4CBC2C0B70000000000000000000000000000000000000000000000000000000000000000000000
EEPROM_BLOCK_8=00000000000000000000000000000000000000000000000000FF000000000001
EEPROM_BLOCK_11=00000000000000590001
EEPROM_BLOCK_12=0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000003
EEPROM_BLOCK_14=0000000101010101010107081543020708055102070806040408080000000191418901914189000006101104100400000001701036000000000052AD6D5A64A8
EEPROM_BLOCK_15=0000640012022E040E062A08780A100EC6110C17BC1B401F00006400E0010604F0052008820A4C0E2A128E17201C401F00006400A401C903C8050C08820A560E4812AC173E1C8A200000040154019A01CC01FE0130027602BC02200384034C047100000000000000000000000000000000000000000000000000000000000000
EEPROM_BLOCK_16=061DEA1AA0193016A8115C0D6E0A8007BA044E0264000000CE1D2A1CD2196216EE11C00DD20AE4071E05B20264000000741DD01B781912169E11700D8C0ABC07F6048A02640000006A1DE41B8C19F4157611160D000A26074C041C02320000000000C8002C019001F40144027602A802DA020C035203E8030000000000000000
EEPROM_BLOCK_17=00000A0046000E014E02EC0412075609460FC017021C781E0000C80004012C0154019A01CC01FE01760220038403E803
EEPROM_BLOCK_19=0000E8FDE8FDE8FDC50D000000000000000000000000000000000000
EEPROM_BLOCK_20=010100000F0D040A00000DFFAE2C01429A03A200B12C0193E3041100
BLOCK_TS=000007007A0070022108E50F9E1CB72530349C4E645EE4A86BA5445ACB1A0F000000000000000000000000000000000000030000000000000000000000020403040403040303030303020201000000000000000020006B00D203D904E20425106D03720D1A0BE700EF0703000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Чессно говоря тоже не до конца понял про этот перенос из ДАСа
в ведьме то можно - но как то муторно
Пробовал я запустить сохранение данных - запросил пароль, вроде и фиксы все стоят
в ксентри просит пароль, или я не в то меню лезу - пытаюсь через Специальный процессы
ну, всё правильно, потому, что в КСЕНТРИ это делается не через спецпроцессы, а из просмотра адаптаций!!! самый нижний пункт!
блин , что за манера постоянно в какое-то СПЕЦ- лезть?
16:53:50 System VGSNAG2 is selected
16:53:50 VGSNAG2: SGML-Version:04.00.84
16:53:53 Contact with ECU VGSNAG2 established.
16:54:02 Service VGSNAG2:😀J_Set_Blocksize executed successfully.
16:54:50 Error: DL_Lifetime_history failed..
а как их записать? не получается ни в дасе ни ведьме
Livetime_History в примере
eeprom 1 даже ок не дает нажать!
128
автоматом не идет , уже раз 10 платы тусовал(
лайф хистори тоже не сохраняет(
зачем их тусовать? данные считаны? считаны.
при входе в ремонтную плату оно сразу говорит, что необходимо выполнить ввод в эксплуатацию и переносит данные, после чего удаляет файл с этими данными.
сейчас проблема в чём? ты понимаешь, что за кнопки ты тычешь и для чего? На экране русским языком пишут что делать.
блок еепром 2 перекопировался прогресс
ну тут целая история все пошло не по плану потом, ругалась на ошибку передачи данных, ехс почему то не тот стал, короче трешь плата активирована персонализирована, и не дает может из за этого
перенос данных возможен в любую ремонтную плату без ограничений на привязку и софт. главное не в буте.
с 14го сообщения перечитывай.
если файл УДАЛИЛСЯ - значит он ЗАПИСАЛСЯ.
если хочешь записать его ещё раз - ПОЛОЖИ ТУДА, ГДЕ ОН БЫЛ и с 14го сообщения снова.
КУДА В НЕЙ ЗАХОЖУ?!
ты КАК СДЕЛАЛ ЭТОТ ФАЙЛ?
КАКОЙ ВВОД В ЭКСПЛУАТАЦИЮ ЕСЛИ ТЫ УЖЕ ВСЁ СДЕЛАЛ?
с 14го сообщения.
