Верхняя панель кнопок OBF W223 не работает.
mbwag66
Блок CTRLU223_CTRLU223_06 не работают кнопки, подкидывали другой блок кнопок - работает. Ошибок в блоке нет, другие блоки пишут нет связи с OBF по LIN. Если пролить софт, кодировки слетят? И поможет ли это?
Пытался прошить, не получилось. Ошибки ниже.
Зензефи не запрашивает.
Messages in Flash Control created at 14:09:10 on 16.11.2023
Software Version 9.02.013
2023-11-16 13:57:14 Ready to Start
2023-11-16 14:08:04 Flash process in progress. Currently flashing session: MAIN
2023-11-16 14:08:04 ODX version: 3.5.0
2023-11-16 14:08:04 >>>>> JobPosition: job started job started {
2023-11-16 14:08:04 JobVersion: 1.0.9
2023-11-16 14:08:04 JobName: CTRLU223
2023-11-16 14:08:04 TemplateVersion: 9.2.5
2023-11-16 14:08:04 TemplateName: DaimlerUDSFlashjob
2023-11-16 14:08:04 Inputparameter:
2023-11-16 14:08:04 debug = NORMAL_MODE
2023-11-16 14:08:04 jobState = PREPARE
2023-11-16 14:08:04 ECUBaseVariant = CTRLU223
2023-11-16 14:08:04 ECUVariant = CTRLU223_CTRLU223_06
2023-11-16 14:08:04 Protocol = UDS_Ethernet_DoIP
2023-11-16 14:08:04 JobQualifier = WVC_FlashProg (com.daimler.odxjobs.flash.uds.MCD3_GenericUdsFlashjob)
2023-11-16 14:08:04 JobVersion = 1.0.9
2023-11-16 14:08:04 >>>>> JobPosition: ReadingConfigFile reading the xml file to retrive ECU information {
2023-11-16 14:08:04 }
2023-11-16 14:08:04 Using debug state NORMAL_MODE
2023-11-16 14:08:04 WARNING null
2023-11-16 14:08:04 This is some junit test test
2023-11-16 14:08:04 >>>>> JobPosition: Initialization Initialization of Dlls {
2023-11-16 14:08:04 Logical block ID: 0
2023-11-16 14:08:04 Department = Development
2023-11-16 14:08:04 TesterID: 0x1
2023-11-16 14:08:04 executing service ReadFingerprint_Read
2023-11-16 14:08:04 RQ_ReadFingerprint_Read [22 F1 5B]
2023-11-16 14:08:04 Positive Response from ECU [62 F1 5B 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00] (94 ms)
2023-11-16 14:08:04 Response of service ReadFingerprint_Read
2023-11-16 14:08:04 Software_Fingerprint_s
2023-11-16 14:08:04 STR_Software_Fingerprints
2023-11-16 14:08:04 Software_Programmed_and_Valid: CRC and signature valid
2023-11-16 14:08:04 Software_Software_Mismatch: no mismatch
2023-11-16 14:08:04 Software_Hardware_Mismatch: no mismatch
2023-11-16 14:08:04 Memory_Status_Information: Memory not erased
2023-11-16 14:08:04 Reprogramming_Process_State: Block valid
2023-11-16 14:08:04 Diagnostic_Authentication_Certificate_ID: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2023-11-16 14:08:04 SW_Programming_year: 0
2023-11-16 14:08:04 SW_Programming_month: 0
2023-11-16 14:08:04 SW_Programming_day: 0
2023-11-16 14:08:04
2023-11-16 14:08:04 executing service BootSoftwareVersion_Read
2023-11-16 14:08:04 RQ_BootSoftwareVersion_Read [22 F1 53]
2023-11-16 14:08:04 Positive Response from ECU [62 F1 53 13 25 00] (23 ms)
2023-11-16 14:08:04 Response of service BootSoftwareVersion_Read
2023-11-16 14:08:04 Boot_SW_year: 19
2023-11-16 14:08:04 Boot_SW_week: 37
2023-11-16 14:08:04 Boot_SW_patch_level: 0
2023-11-16 14:08:04
2023-11-16 14:08:04 executing service HardwareVersion_Read
2023-11-16 14:08:04 RQ_HardwareVersion_Read [22 F1 50]
2023-11-16 14:08:04 Positive Response from ECU [62 F1 50 12 33 00] (24 ms)
2023-11-16 14:08:04 Response of service HardwareVersion_Read
2023-11-16 14:08:04 HW_year: 18
2023-11-16 14:08:04 HW_week: 51
2023-11-16 14:08:04 HW_patch_level: 0
2023-11-16 14:08:04
2023-11-16 14:08:04 executing service SoftwareVersion_Read
2023-11-16 14:08:04 RQ_SoftwareVersion_Read [22 F1 51]
2023-11-16 14:08:04 Positive Response from ECU [62 F1 51 14 2F 00 14 2F 00] (17 ms)
2023-11-16 14:08:04 Response of service SoftwareVersion_Read
2023-11-16 14:08:04 Software_Logical_Block_Version_Information
2023-11-16 14:08:04 STR_Software_Logical_Block_Version_Information
2023-11-16 14:08:04 SW_year: 20
2023-11-16 14:08:04 SW_week: 47
2023-11-16 14:08:04 SW_patch_level_1: 0
2023-11-16 14:08:04
2023-11-16 14:08:04 executing service Reprogramming_Attempt_Counter_Read
2023-11-16 14:08:04 RQ_Reprogramming_Attempt_Counter_Read [22 01 00]
2023-11-16 14:08:04 Positive Response from ECU [62 01 00 00 01 00 00 00 01 00 00] (19 ms)
2023-11-16 14:08:04 Response of service Reprogramming_Attempt_Counter_Read
2023-11-16 14:08:04 Reprogramming_Attempts
2023-11-16 14:08:04 STR_Reprogramming_Attempts
2023-11-16 14:08:04 Number_of_Reprogramming_Attempts: 1
2023-11-16 14:08:04 Max_Number_of_Reprogramming_Attempts: 0
2023-11-16 14:08:04
2023-11-16 14:08:04 current Monitoring state:true
2023-11-16 14:08:04 Using Jobstate PREPARE
2023-11-16 14:08:04 Build-Date:Release <15.02.2019 13:31:46,54>
2023-11-16 14:08:04 Global Flashstate: Flash state not set
2023-11-16 14:08:04 unable to get the comparaminfos for CP_CanPhysReqId with error null
2023-11-16 14:08:04 >>>>> JobPosition: VarIdentification identifying the FBL Version with the Active Diagnostic Information service {
2023-11-16 14:08:04 executing service ActiveDiagnosticInformation_Read
2023-11-16 14:08:04 RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-11-16 14:08:04 Positive Response from ECU [62 F1 00 00 03 04 03] (27 ms)
2023-11-16 14:08:04 >>>>> JobPosition: StartSessionProgramming setting ECU into programming Session {
2023-11-16 14:08:04 executing job StartSecureDiagSession
2023-11-16 14:08:05 executing job Programming_Start
2023-11-16 14:08:05 SEVERE Severity: eERROR Severity: eERROR
2023-11-16 14:08:05 SEVERE Code: 51712, CodeDescription: JobError occured
2023-11-16 14:08:05 SEVERE VendorCode: 10060, VendorCodeDescription: 10060 Position: job started > MCDError: 10012 Position: job started > Negative response received ProgrammingStart PDU [10 02] > [7F 10 33] Security Access Denied > logId: 18BD7633528 > common error see description for details > Error executing service: JobStartProgramming
2023-11-16 14:08:05 Execution of progsession returned error MCDError: 10060 Position: job started > MCDError: 10012 Position: job started > Negative response received ProgrammingStart PDU [10 02] > [7F 10 33] Security Access Denied > logId: 18BD7633528 > common error see description for details > Error executing service: JobStartProgramming > common error see description for details > Error executing service: Programming_Start
2023-11-16 14:08:05 wait for 3100 ms for PDU api to get internal state ready
2023-11-16 14:08:05 Waiting 0 of 3 s
2023-11-16 14:08:06 Waiting 1 of 3 s
2023-11-16 14:08:07 Waiting 2 of 3 s
2023-11-16 14:08:08 Waiting2 for 3100ms
2023-11-16 14:08:08 Start waiting for ECU availabilty in session 2 for max. of 30000ms
2023-11-16 14:08:08 executing service ActiveDiagnosticInformation_Read
2023-11-16 14:08:08 RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-11-16 14:08:08 Positive Response from ECU [62 F1 00 00 03 04 03] (19 ms)
2023-11-16 14:08:08 Waiting1 for 380ms
2023-11-16 14:08:08 no connection... waiting and retry 29600
2023-11-16 14:08:08 Positive Response from ECU [62 F1 00 00 03 04 03] (18 ms)
2023-11-16 14:08:08 no connection... waiting and retry 29200
2023-11-16 14:08:08 Positive Response from ECU [62 F1 00 00 03 04 03] (16 ms)
2023-11-16 14:08:09 Waiting1 for 382ms
2023-11-16 14:08:09 no connection... waiting and retry 28800
2023-11-16 14:08:09 executing service ActiveDiagnosticInformation_Read
2023-11-16 14:08:09 RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-11-16 14:08:37 no connection... waiting and retry 400
2023-11-16 14:08:37 executing service ActiveDiagnosticInformation_Read
2023-11-16 14:08:37 RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-11-16 14:08:37 Positive Response from ECU [62 F1 00 00 03 04 03] (22 ms)
2023-11-16 14:08:38 Waiting1 for 376ms
2023-11-16 14:08:38 no connection... waiting and retry 0
2023-11-16 14:08:38 ProgSession change:33s
2023-11-16 14:08:38 }
2023-11-16 14:08:38 executing service ActiveDiagnosticInformation_Read
2023-11-16 14:08:38 RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-11-16 14:08:38 Positive Response from ECU [62 F1 00 00 03 04 03] (20 ms)
2023-11-16 14:08:38 SEVERE >>>>> InternalJobException {
2023-11-16 14:08:38 SEVERE Severity: eERROR Severity: eERROR
VendorCode: 20360, VendorCodeDescription: Position: StartSessionProgramming > com.daimler.odxjobs.exception.InternalJobException: common error see description for details > unable to confirm successfull transition to programming session session ID:3 > Error while variant identification
2023-11-16 14:08:38 SEVERE com.daimler.odxjobs.exception.InternalJobException: com.daimler.odxjobs.exception.InternalJobException: common error see description for details > unable to confirm successfull transition to programming session session ID:3 > Error while variant identification
at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.identifyBootloaderVariant(AbstractUdsFlashJob.java:932)
at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.startMajorProgrammingSequence(AbstractUdsFlashJob.java:562)
at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.executeJobTask(AbstractUdsFlashJob.java:284)
at com.daimler.odxjobs.flash.uds.MCD3_GenericUdsFlashjob.executeJobTask(MCD3_GenericUdsFlashjob.java:79)
at com.daimler.odxjobs.common.AbstractSingleEcuJob.execute(AbstractSingleEcuJob.java:274)
at com.daimler.odxjobs.flash.AbstractFlashJob.execute(AbstractFlashJob.java:129)
at JobProcessor.JobThread.run(Unknown Source)
2023-11-16 14:08:38 SEVERE }
2023-11-16 14:08:38 SEVERE Code: 51712, CodeDescription: JobError occured
2023-11-16 14:08:38 SEVERE VendorCode: 20360, VendorCodeDescription: 20360 Position: StartSessionProgramming > com.daimler.odxjobs.exception.InternalJobException: common error see description for details > unable to confirm successfull transition to programming session session ID:3 > Error while variant identification
2023-11-16 14:08:38 SEVERE Execution State = eALL_FAILED
2023-11-16 14:08:38 SEVERE Error occurred during job execution!
2023-11-16 14:08:38 Job duration: 0h 0m 33s 970ms
2023-11-16 14:08:38 Total number of bytes transferred: 0
2023-11-16 14:08:38 Erase time: 0s
2023-11-16 14:08:38 Checkmemory time: -1s
2023-11-16 14:08:38 Checkdependency time: 0s
2023-11-16 14:08:38 Flash process stopped due to error!
Шил кто- нибудь 223 кузов? Почему не получается?
