722.9 - перенос адаптаций | Страница 5 | benzpro
722.9 перенос адаптаций
7G Tronic
зачем вам их перезаписывать, если у вас нет их сохрания???
DT_STO_EEPROM_Block_19_Data 00 00 0A C4 2B F6 00 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DT_STO_EEPROM_Block_20_Data 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 01
DT_STO_EEPROM_Block_21_Data 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
DT_STO_EEPROM_Block_22_Data 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02
DT_STO_EEPROM_Block_23_Data 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
DT_STO_EEPROM_Block_24_Data 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Perfect. You made it. This is good way to learn.
Yeah, thanks.
I was a bit confused as per double-click on the i.e. DL_EEPROM_Block_1 (and others) it says "Nicht bedatet" which means there is no data.
Thats why i started asking questions 🙂
переписывать надо то, что сохраняется в Ventilkennlinien_*.log
то, что вы сохранили полный епром - это для разработчиков.
Мерседес WDD2120481A678489
VGSNAG2
Вчера новую плату вводили в эксплуатацию (0310 ремонтная )
,Перенос ПО с помощью Ведиамо с CFF не пошло , вылетало на 25 секунде не начинаясь , в итоге плата свалилась в Бут , но легко подняли с тем же ПО , только с SMR-F,
Не поняли почему так получилось
Имеем предположение что плата свежая и поэтому пошло только с SMR-F
Почитав тему про перенос адаптаций, попытались это сделать , создали файл и при подключении новой платы не поняли перенеслись адаптации или нет
Но когда все закончили , блок просил ввод в эксплуатацию, хотя ошибок не было ! пока не удалили этот файл , как только удалили все стало sehr gut
Да понял уже что не перенесли , машина будет на следующей неделе , попробуем по-новой это сделать , в ксентри муторно все , без стакана не разобраться
Если не получится , то думаю можно Ведиамо - сохранить , скопировать и в DL вставить.
Там очень внимательно надо читать что пишет и что нажимать.
Спасибо Романофф !!!
Сегодня пришла машина и всё получилось !!! Нужно было всего лишь всё внимательно перечитать что пишет и спрашивает прога
Файл записался , далее сам удалился
Все перепроверил через Ведиамо данные перенеслись !
На пробной поездке лёгкие подёргивания остались , но в целом улучшения заметны.
Здравствуйте!
Ребят, кому не сложно, скиньте, пожалуйста, параметры гидравлики (Ventilkennlinien) со своих машин (или не только со своих), у кого 722.908; VGS4NAG2 с номером 2312703801.
Я извиняюсь, но я вижу только "Скрытый контент для участников."
Для участников чего?
Добрый день
Вопрос по переносу адаптаций в DAS , с Xentry все́ понятно происходит и подробно разже́вано в теме , а вот в DAS , как это сделать также быстро и удобно как в Xentry из за , (применю фирменное выражение ) , всратого проверочного числа , которое никто не может посчитать , сделать не получается , приходится , после неудачного программирования возвращаться назад , и потом шить и переносить данные вручную с Vediamo
Ответ на вопрос , знаю , поставить старую версию Xentry и не будет просить проверочное число , а кроме этого больше никак это не решить ?
Ты что то не то делаешь
Да , сначала делала неправильно , сейчас выкупил как надо , Все перепроверил на столе , адаптации перенеслись , немного неудобно что потом не даёт делать прошивку из за этого числа , но это не проблема , главное подбирает правильный софт
