NTG6 - Всё очень плохо. | Страница 2 | benzpro
NTG6 Всё очень плохо.
Видел опцию активации (покупки) интеграции смартфона, но на зарубежном сайте! Типа 270 фунтов бессрочно. Навигация не указана. (это для MBUX как раз).
Написано, что активация пару дней занимает.
Mercedes me connect United Kingdom
Infotainment
Smartphone Integration
Transfer your personal smartphone screen to the media display in your Mercedes.
  • Easy cable connection
  • Supports Apple™ CarPlay™ and Android Auto™
  • Convenient operation by voice control
  • Access to e.g. navigation, traffic information, messaging, telephony, media, IP radio and selected apps from third-party providers
  • Optimised display of content in the media display
Note: Following purchase, activation may take several hours.
Availability:
permanently activated
once-on £267.00
Please register in order to shop.
The smart way to connect your smartphone with your Mercedes.
Need an address from your contacts list, want to chat or listen to music using an app? Smartphone Integration connects your mobile phone with the vehicle, turning the media display into your personal smartphone screen. Using a cable and Apple™ CarPlay™ or Android Auto™, you can connect your smartphone to the multimedia system and make telephone calls, read emails, make diary entries or choose an audiobook. Because that's what you're used to, your personal smartphone control – and almost all the content – is transferred to the media display. So you can control the smartphone as if you were holding it.
Your advantages at a glance.
With Smartphone Integration you can effortlessly network your smartphone with the media display for convenient access to many apps. Also apps from third-party providers. Using the interface, you can control numerous functions just as you would on the smartphone. And things are even easier with voice control. Moreover, all content is processed so that it is optimally and particularly clearly presented in the media display. So that nothing distracts you and you are always on the road safely.
Before purchasing, please check compatibility of your smartphone with the Apple™ CarPlay™ or Android Auto™ standard. This is absolutely essential in addition to the technical features in the vehicle for use of the on-demand feature Smartphone Integration. Please see the FAQ section for further details.
User note:
Once purchased, this feature is permanently available in the vehicle.
The on-demand feature Smartphone Integration is currently only available in the new A-Class (market launch May 2018).
Please note that this on-demand feature requires the following optional equipment:
  • MBUX Multimedia System with
  • extended MBUX function or 10.25-inch media display
Вот такое пока! Причём написано, что
хз что это, понятно , что широкий моник, но что за функция?
посмотрим что у нас будет. тоже вопрос такой стоит, пока аппаратов нет на опыты , возможно будет вариант перманентной активации... кстати, в 167 кузове опции этой телефонии и карплея как раз и называются - перманентная активация карплея (например), возможно подразумевается покупной опционал.
ждём доноров.
New developments at Mercedes me: Mercedes me is becoming more international
Даже если автомобиль уже поставлен, клиенты могут впоследствии приобрести Цифровое радио, Интеграцию со смартфоном (Apple Carplay / Android Auto) и Навигацию. Это требует, чтобы клиент соединил автомобиль с Mercedes me, с рабочим соединением данных.
Везде. Новый спринтер, новое мыло 167, новый а, б класс, 205 рестайл и всё, что из него сделано. Но сейчас они везде его будут засовывать.
в аппарате могут отсутствовать физические входы при отсутствии комплектации.
заглушки в SPV/AR (камера зеркала)
TV/SDARS - спутниковое радио/тв?
USB CI - интерфейс карт для DVB-T?
WLAN отдельной антенной
т.е. кодировками добавить что-то физически отсутствующее никак.
в России и Беларуси по прежнему невозможно докупить карплей и навигацию на NTG6?
какое все таки гадство ))))
ну не на весь экран, но зачем эти два пустых см с обеих сторон...
Добрый день!
W1V44781313799993 NTG6
Подскажите можно ли активировать: Android Auto, Apple Carplay(проводн.св.), Навигацию?
можно, но для этого надо или купить новое радио или переехать в другую страну, где работает мерседес-ми магазин.
