Отключение пиропатрон капота. | benzpro
Всем привет. Машина Mersedes SLC 2019 r172. Поставил новый блок srs. Старый не на связи. Нужно убрать из кодировок пиропатроны капота. Их тут не должно быть. Как называется кодировка? Или кто поможет отключить?
Varcoding of:ORC_172 (1)
Coding service:1.VCD_BR172_ECU_Configurable_Features
FragmentsValues
1st Pyrofuseyes
1st Row Driver Anchor Pretensionerno
1st Row Driver Retractor Pretensionerno
1st Row Driver Seat Belt Buckle Pretensioneryes
1st Row Driver Seat Belt Load Limiterno
1st Row Passanger Seat Belt Load Limiterno
1st Row Passenger Anchor Pretensionerno
1st Row Passenger Retractor Pretensionerno
1st Row Passenger Seat Belt Buckle Pretensioneryes
2nd Pyrofuseno
2nd Row Center Anchor Pretensionerno
2nd Row Center Retractor Pretensionerno
2nd Row Center Seat Belt Buckle Pretensionerno
2nd Row Left Anchor Pretensionerno
2nd Row Left Retractor Pretensionerno
2nd Row Left Seat Belt Buckle Pretensionerno
2nd Row Right Anchor Pretensionerno
2nd Row Right Retractor Pretensionerno
2nd Row Right Seat Belt Buckle Pretensionerno
30° Crashfunction activeno
30° Crashfunction only when unbeltedno
3rd Row Center Anchor Pretensionerno
3rd Row Center Retractor Pretensionerno
3rd Row Center Seat Belt Buckle Pretensionerno
3rd Row Left Anchor Pretensionerno
3rd Row Left Retractor Pretensionerno
3rd Row Left Seat Belt Buckle Pretensionerno
3rd Row Right Anchor Pretensionerno
3rd Row Right Retractor Pretensionerno
3rd Row Right Seat Belt Buckle Pretensionerno
All buckle switches are simple switchesno
All buckle switches hall effectno
All buckle switches resistive codedyes
Analogue Crashoutput existingyes
B-Pillar gSats presentyes
CAH Driver persentyes
CAH Passenger presentyes
CAH_via_CANno
Check: ECU Key No. equal Key No. received on CANyes
Check: Perform Algorithm Parameter Set plausibility check on CANno
Check: RHD/LHD options equal CAN messageyes
Comfort Exit (Hinges activation)no
Curtain Bags left and right presentyes
DOC disable Switch Existingno
Default value Weight class of the passengerClass 3
Digital Crashoutput/TeleAid Existingno
Disposal Firing Driver belted onyes
Disposal Firing Driver unbelted onyes
Disposal Firing Passenger belted onyes
Disposal Firing Passenger unbelted onyes
Driver Bag 1st and 2nd stage presentyes
Driver Knee Bag presentyes
Driver Seat Track Position Sensorno
Driver buckle HW input presentyes
ECSs presentyes
EDR-KonfigurationAnlieferzustand
Front Door pSats presentyes
Hood Sensors Presentno
ISOFIX switch 1 und 2 existingno
LIN Crashoutput existingno
Left Side Thorax Squib 1yes
Occupant Detection Sensor (ODS, SBR) Existingno
PAD-Lamp ON at Weight Class 0no
PPS Presentyes
PPS p-Sat Left and Right Existingyes
Passenger Airbag On Lampselftest, activation 65s
Passenger Bag 1st and 2nd stage presentyes
Passenger Frontal Airbag Squibyes
Passenger Knee Bag presentyes
Passenger Seat Track Position Sensorno
Passenger buckle HW input presentyes
Pelvis Bag Driverno
Pelvis Bag Passengerno
Pitchover Algorithm enableddisabled
RHD vehicleno
Rear Door pSats presentno
Rear Sidebags left and right presentno
Refrigerant deactivation 1no
Refrigerant deactivation 2no
Right Side Thorax Squib 1yes
RoE Existingyes
Rollover Algorithmyes
Rolloverbar 1 leftno
Rolloverbar 1 rightno
SBR suppressednot active
Seat belt pretensioner trigger impact side for a side crashenabled
Seat belt pretensioner trigger non-impact side for a side crashenabled
Seat belt reminderenabled
Seat mat components, passengerLIN IEE WSS_V1
Seatposition Sensorseattrack sensor analog
Venthole Driverno
Venthole Passengerno
g-Sats at C-Pillar existingno
Coding string Dec.:197 073 000 000 110 058 028 247 242 011 192 020 001 015 000
PPS p-Sat Left and Right Existing и если не попрет ещё и PPS Present
А по последней потыкать на варианты мата
по-моему pps present , отдельно датчики не надо вырубать
Моё мнение такого, что это аббревиатура на английском
пассивная безопасность пешехода-PPS
pedestrian passive safety
Активный капот это PPS present
PPS present отключил и
Ошибки ушли и с матом пасажирским разобрался.
Как заблокировать блок?
SG Verriegein Не работает. По ходу криво поставили ксентри. Ведьмой можно сделать?
в кодировках уже заменили? блок ресетнуть, заблокировать и дать заснуть. потом поправить LIN конфигурацию.
идеально - online scn.
Где именно LIN конфигурацию править, подскажите, пожалуйста.
