[SG_INFO]
DAS_NAME=VGS3
EHS_Nummer=2202702406
[EEPROM_BLOCK]
EEPROM_BLOCK_1=F0EC7A53030C9059191C5E4531635F5C303716180800F9050307E105F61ECA0809DB27F105BF1415EADB1712C0BB00FE0B11C0DADB0000143D4F00070000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000008
EEPROM_BLOCK_2=01000000000000000000000000000000000000000000F2EFEFF9F9F90D0A0D00FBFBF5F3F3F5F2F2000000FCFCFCFFFCFCF9FBFBF9F6F6FCF9F9000000000000
EEPROM_BLOCK_3=0100000000000000000000000000CCCB9C0CFCF5FCDDD9DDFAF4FAF2E9E9FBFBFB0400000F0F0FE3E5E5FEFAFAFCFAFACDD3D3FEFAFA0014ECECECEC000000000000000000000000000000000000000000000000000000000000000000000000
EEPROM_BLOCK_4=01000000ECECFC0000EBEAF90000F6EDEBFE000D04F1FE0000000000000000000000F8FCED0200FFFFF503002C06050800002B320E0000000000000000000000
EEPROM_BLOCK_5=01000000FF00F1000001020000000203FDFF00302EF1FF0000000000000000000000E2F8000000E7F3000000F4F3000000FEFE00000000000000000000000000
EEPROM_BLOCK_6=01000000F9F9FC000001000201002A2E06020000000000000000000000000000000000FFD3000010072C00000D321E0000000000000000000000000000000000
EEPROM_BLOCK_7=01000000FBFCFCFAFC0D080D1203021E070400F0F2ECE3D5FAEFEAE6DCE9EDE3E1E2000000000000000000000000000000000000000000000000000000000000
EEPROM_BLOCK_8=000000000000000000000000000048392F0A2019000000000000000000004602
EEPROM_BLOCK_12=0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000003
EEPROM_BLOCK_15=00006400EA01FC03D2050208640A100EDA112017EE1B851F0000640026023804180634088C0A380EF8112A17DA1B401F000064001202240404062A08820A2E0EF8112A17F81BB2200000040154019A01CC01FE0130027602BC02200384034C047000000000000000000000000000000000000000000000000000000000000000
EEPROM_BLOCK_16=001E021CB4194416C611980DBE0ADA071E05BC02640000001E1E7A1C181A8A16E411A20DB40ADA072805CF0264000000881DEE1B96193A16BC11840D960ABC071E05C60264000000141E841C2C1ABC16E411660D640A8007CE046C02A00000000000C8002C019001F40144027602A802DA020C035203E8030000000000000000
EEPROM_BLOCK_17=000014005A002C016202F60412074C093C0FDE175C1C781E0000C80004012C0154019A01CC01FE01760220038403E803
EEPROM_BLOCK_19=0D005362FFFF6828B82FCC023A00050001000000000000000000B400
Набивка не интересует. Платы бу. Я учусь только...
там-же русским языком пишет, что перенос делается только в 0310 HW. и ни про какие ручные не пишет.
ну, руками. что значит не нужно?
Понял, спасибосохрани, сбрось адаптации, сохрани, сравни.
