Прошивка фары GLE167 HLI_FL247 | Страница 5 | benzpro
Готово.
Messages in Flash Control created at 17:24:32  on 06.07.2023
Software Version 8.16.015
2023-07-06 17:21:45  Ready to Start
2023-07-06 17:22:54  Flash process in progress. Currently flashing session: 2479023401_001_173900_SW_HLI
2023-07-06 17:22:54  ODX version: 0.7.47
2023-07-06 17:22:54  >>>>> JobPosition: job started job started {
2023-07-06 17:22:54  JobVersion: 1.0.18
2023-07-06 17:22:54  JobName: HLI_Fx247
2023-07-06 17:22:54  TemplateVersion: 9.2.8
2023-07-06 17:22:54  TemplateName: DaimlerUDSFlashjob
2023-07-06 17:22:54  Input parameter:
2023-07-06 17:22:54      debug = NORMAL_MODE
2023-07-06 17:22:54      jobState = PREPTRANSFIN
2023-07-06 17:22:54  ECUBaseVariant = HLI_FL247 650 / 5D0
2023-07-06 17:22:54  ECUVariant     = HLI_FL247_Boot_Variante_R7_1
2023-07-06 17:22:54  Protocol       = UDS_CAN_D
2023-07-06 17:22:54  JobQualifier   = WVC_FlashProg (com.daimler.odxjobs.flash.uds.MCD3_GenericUdsFlashjob)
2023-07-06 17:22:54  JobVersion     = 1.0.18
2023-07-06 17:22:54  >>>>> JobPosition: ReadingConfigFile reading the xml file to retrive ECU information {
2023-07-06 17:22:54  }
2023-07-06 17:22:54  Using debug state NORMAL_MODE
2023-07-06 17:22:54  WARNING unable to get logbreaker parameter
2023-07-06 17:22:54  This is some junit test test
2023-07-06 17:22:54  >>>>> JobPosition: Initialization Initialization of Dlls {
2023-07-06 17:22:54  Logical block ID: 0
2023-07-06 17:22:54  Department = Development
2023-07-06 17:22:54  TesterID: 0x1
2023-07-06 17:22:54  Executing service ReadFingerprint_Read
2023-07-06 17:22:54  RQ_ReadFingerprint_Read [22 F1 5B]
2023-07-06 17:22:54      Positive Response from ECU [62 F1 5B 56 00 04 17 07 06 00 00 00 01] (24 ms)
2023-07-06 17:22:54  Response of service ReadFingerprint_Read
2023-07-06 17:22:54      Software_Programmed_and_Valid: Software invalid
2023-07-06 17:22:54      Software_Software_Mismatch: mismatch occurred
2023-07-06 17:22:54      Software_Hardware_Mismatch: mismatch occurred
2023-07-06 17:22:54      Memory_Status_Information: Memory Programmed
2023-07-06 17:22:54      Reprogramming_Process_State_1: Memory check unsuccessful
2023-07-06 17:22:54      Supplier_Identification: MB
2023-07-06 17:22:54      SW_Programming_year: 23
2023-07-06 17:22:54      SW_Programming_month: 7
2023-07-06 17:22:54      SW_Programming_day: 6
2023-07-06 17:22:54      Diagnostic_Tool_Serial_Number: 00 00 00 01
2023-07-06 17:22:54
2023-07-06 17:22:54  Executing service BootSoftwareVersion_Read
2023-07-06 17:22:54  RQ_BootSoftwareVersion_Read [22 F1 53]
2023-07-06 17:22:54      Positive Response from ECU [62 F1 53 01 02 10] (5 ms)
2023-07-06 17:22:54  Response of service BootSoftwareVersion_Read
2023-07-06 17:22:54      Boot_SW_year: 1
2023-07-06 17:22:54      Boot_SW_week: 2
2023-07-06 17:22:54      Boot_SW_patch_level: 16
2023-07-06 17:22:54
2023-07-06 17:22:54  Executing service HardwareVersion_Read
2023-07-06 17:22:54  RQ_HardwareVersion_Read [22 F1 50]
2023-07-06 17:22:54      Positive Response from ECU [62 F1 50 11 14 00] (7 ms)
2023-07-06 17:22:54  Response of service HardwareVersion_Read
2023-07-06 17:22:54      HW_year: 17
2023-07-06 17:22:54      HW_week: 20
2023-07-06 17:22:54      HW_patch_level: 0
2023-07-06 17:22:54
2023-07-06 17:22:54  Executing service SoftwareVersion_Read
2023-07-06 17:22:54  RQ_SoftwareVersion_Read [22 F1 51]
2023-07-06 17:22:54      Positive Response from ECU [62 F1 51 11 27 00] (6 ms)
2023-07-06 17:22:54  SEVERE  Severity: eERROR
2023-07-06 17:22:54  SEVERE     Code: 49192
2023-07-06 17:22:54  SEVERE     CodeDescription: The interpretation of a Service failed.
2023-07-06 17:22:54  SEVERE     VendorCode: 54179
2023-07-06 17:22:54  SEVERE     VendorCodeDescription: Error: MaxLength violation (PDU is too long), Required bytes: 32, available: 48.
2023-07-06 17:22:54  Executing service MercedesCarGroupHardware_Read
2023-07-06 17:22:54  RQ_MercedesCarGroupHardware_Read [22 F1 11]
2023-07-06 17:22:54      Positive Response from ECU [62 F1 11 32 34 37 39 30 31 30 37 30 32] (21 ms)
2023-07-06 17:22:54  Response of service MercedesCarGroupHardware_Read
2023-07-06 17:22:54      Hardware_Part_Number: 2479010702
2023-07-06 17:22:54
2023-07-06 17:22:54  Executing service MercedesCarGroupSoftware_Read
2023-07-06 17:22:54  RQ_MercedesCarGroupSoftware_Read [22 F1 21]
2023-07-06 17:22:54      Positive Response from ECU [62 F1 21 32 34 37 39 30 32 33 36 30 30] (17 ms)
2023-07-06 17:22:54  Response of service MercedesCarGroupSoftware_Read
2023-07-06 17:22:54      Logical_Block_0_Part_Number: 2479023600
2023-07-06 17:22:54
2023-07-06 17:22:54  Executing service Reprogramming_Attempt_Counter_Read
2023-07-06 17:22:54  RQ_Reprogramming_Attempt_Counter_Read [22 01 00]
2023-07-06 17:22:54      Positive Response from ECU [62 01 00 00 27 10 00] (3 ms)
2023-07-06 17:22:54  Response of service Reprogramming_Attempt_Counter_Read
2023-07-06 17:22:54      Number_of_Reprogramming_Attempts_Counter_0: 39
2023-07-06 17:22:54      Max_Number_of_Reprogramming_Attempts_Counter_0: 4096
2023-07-06 17:22:54
2023-07-06 17:22:54  current Monitoring state:true
2023-07-06 17:22:54  Using Jobstate PREPTRANSFIN
2023-07-06 17:22:54  Build-Date:Release <XXXXXXXXXXXXXXXXXXXXXX>
2023-07-06 17:22:54  Global Flashstate: Flash state not set
2023-07-06 17:22:54  Link type:CAN
2023-07-06 17:22:54  P2Max:2100000
2023-07-06 17:22:54  RC78CompletionTimeout:60000000
2023-07-06 17:22:54  >>>>> JobPosition: VarIdentification identifying the FBL Version with the Active Diagnostic Information service {
2023-07-06 17:22:54  Executing service ActiveDiagnosticInformation_Read
2023-07-06 17:22:54  RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-07-06 17:22:54      Positive Response from ECU [62 F1 00 01 05 06 03] (3 ms)
2023-07-06 17:22:54  Response of service ActiveDiagnosticInformation_Read
2023-07-06 17:22:54      Active_Diagnostic_Version: 6
2023-07-06 17:22:55      Active_Diagnostic_Variant: 5
2023-07-06 17:22:55      ECU_Software_Mode: Running in Boot
2023-07-06 17:22:55      Identification: 66822
2023-07-06 17:22:55      Active_Diagnostic_Session: Extended
2023-07-06 17:22:55
2023-07-06 17:22:55  >>>>> JobPosition: StartSessionProgramming setting ECU into programming Session {
2023-07-06 17:22:55  WARNING Unable to find service 'StartSecureDiagSession' via short name
2023-07-06 17:22:55  Exception of StartSecureDiagSessionservice not found in database > Could not find serivce 'StartSecureDiagSession' by ShortName or interal service list.
2023-07-06 17:22:55  Executing service Programming_Start
2023-07-06 17:22:55  RQ_Programming_Start [10 02]
2023-07-06 17:22:55      Positive Response from ECU [50 02 00 14 00 C8] (3 ms)
2023-07-06 17:22:55  Response of service Programming_Start
2023-07-06 17:22:55      P2_CAN_ECU_max: 20.000000
2023-07-06 17:22:55      P2s_CAN_ECU_max: 2000.000000
2023-07-06 17:22:55
2023-07-06 17:22:55  ProgSession change:0s
2023-07-06 17:22:55  }
2023-07-06 17:22:55  Executing service ActiveDiagnosticInformation_Read
2023-07-06 17:22:55  RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-07-06 17:22:55      Positive Response from ECU [62 F1 00 01 05 06 02] (3 ms)
2023-07-06 17:22:55  Response of service ActiveDiagnosticInformation_Read
2023-07-06 17:22:55      Active_Diagnostic_Version: 6
2023-07-06 17:22:55      Active_Diagnostic_Session: Programming
2023-07-06 17:22:55
2023-07-06 17:22:55  DiagnosticStatusOfEcu: 0x1
2023-07-06 17:22:55  DiagnosticVariant: 0x5
2023-07-06 17:22:55  DiagnosticVersion: 0x6
2023-07-06 17:22:55  DiagnosticSession: 0x2
2023-07-06 17:22:55  Active DiagnosticVariant: 0x506
2023-07-06 17:22:55  Used variant: Development
2023-07-06 17:22:55  Bootloader Revision: REV_G Security Class: CLASS_CCC Signature Key Type: DEVELOPMENT sendCrc = true key length = 4
2023-07-06 17:22:55  Use data compression: false
2023-07-06 17:22:55  jobstate set to PREPTRANSFIN but ecu does not support stateflash therefore switching to classic mode
2023-07-06 17:22:55  >>>>> JobPosition: SetComparameter setting comunication parameters {
2023-07-06 17:22:55  >>>>> JobPosition: SecurityAccessViaJar calculating the security key with Jar {
2023-07-06 17:22:55  loading secure jar HLI_Fx247_16_03_03.jar.pgp
2023-07-06 17:22:55  file in jar found:com/
2023-07-06 17:22:55  file in jar found:com/daimler/
2023-07-06 17:22:55  file in jar found:com/daimler/security/
2023-07-06 17:22:55  file in jar found:com/daimler/security/interfaces/
2023-07-06 17:22:55  file in jar found:com/daimler/security/interfaces/IParameterProvider.class
2023-07-06 17:22:55  file in jar found:com/daimler/security/interfaces/ISecurityAlgorithm.class
2023-07-06 17:22:55  file in jar found:com/daimler/security/interfaces/ISeedKey.class
2023-07-06 17:22:55  file in jar found:com/daimler/security/interfaces/Parameter.class
2023-07-06 17:22:55  file in jar found:com/daimler/security/interfaces/ParameterDesc.class
2023-07-06 17:22:55  file in jar found:com/daimler/security/interfaces/VKeyGenResultEx.class
2023-07-06 17:22:55  file in jar found:com/daimler/security/algorithms/
2023-07-06 17:22:55  file in jar found:com/daimler/security/algorithms/DaimlerStandardSecurityAlgoRefG.class
2023-07-06 17:22:55  file in jar found:com/daimler/security/generated/
2023-07-06 17:22:55  file in jar found:com/daimler/security/generated/HLI_Fx247_16_03_03_20181310091344.class
2023-07-06 17:22:55  plugin with interface com.daimler.security.interfaces.ISeedKey and implementation com.daimler.security.generated.HLI_Fx247_16_03_03_20181310091344 used
2023-07-06 17:22:55  ISeedKey plugin successfully loaded
2023-07-06 17:22:55  requesting seed for sa
2023-07-06 17:22:55  HexService [27 11]
2023-07-06 17:22:55      Positive Response from ECU [67 11 73 73 2A 4C 97 2D 26 CC] (17 ms)
2023-07-06 17:22:55  Security Access - Calculating Key from Seed
2023-07-06 17:22:55  file in jar found:com/daimler/security/generated/ParameterProvider_HLI_Fx247_16_03_03_20181310091344.class
2023-07-06 17:22:55  GenerateKeyExOpt returned: KGRE_Ok
2023-07-06 17:22:55  HexService [27 12 ED D1 DC 2D]
2023-07-06 17:22:55      Positive Response from ECU [67 12] (8 ms)
2023-07-06 17:22:55  Security Access Successful
2023-07-06 17:22:55  Block size and STmin parameter not set.
2023-07-06 17:22:55  >>>>> JobPosition: WriteFingerPrint writing date and tester information {
2023-07-06 17:22:55  Programming Date: Thu Jul 06 17:22:55 MSK 2023 used BlockId: 0
2023-07-06 17:22:55  HexService [2E F1 5A 00 04 17 07 06 00 00 00 01]
2023-07-06 17:22:55      Positive Response from ECU [6E F1 5A] (6 ms)
2023-07-06 17:22:55  Baudrate parameter not set
2023-07-06 17:22:55  >>>>> JobPosition: ProgrammingState getting programmingstate of logical block {
2023-07-06 17:22:55  HexService [22 F1 5B]
2023-07-06 17:22:55      Positive Response from ECU [62 F1 5B 56 00 04 17 07 06 00 00 00 01] (22 ms)
2023-07-06 17:22:55  blockstate of block 0 is Memorycheckunsuccessful
2023-07-06 17:22:55  >>>>> JobPosition: DownloadSwil1 download of swil1 {
2023-07-06 17:22:55  com.daimler.odxjobs.flash.Swil@e4ae9
2023-07-06 17:22:55  >>>>> JobPosition: DownloadSwilBlockStartTransfer start transfer of swil data {
2023-07-06 17:22:55  HexService [34 00 44 FE DF 80 00 00 00 20 00]
2023-07-06 17:22:55      Positive Response from ECU [74 20 0F 02] (6 ms)
2023-07-06 17:22:55  maxNumberOfBlockLength: 3840 bytes:8192
2023-07-06 17:22:55  >>>>> JobPosition: DownloadSwilBlockTransfer transfering swill data {
2023-07-06 17:22:55  Will download: 8192 bytes
2023-07-06 17:22:55  >>>>> JobPosition: DownloadSwilBlockTransferExit ending swil data transfer {
2023-07-06 17:22:55  HexService [37]
2023-07-06 17:22:55      Positive Response from ECU [77] (3 ms)
2023-07-06 17:22:55  >>>>> JobPosition: CheckMemSwil1 checkmemory of swil1 {
2023-07-06 17:22:55  HexService [31 01 02 02 00 04 31 EF 3F 53 00 80 44 74 39 DD BD 01 83 69 38 C2 53 28 7D FC 8C E4 0E F3 00 9D EC 00 91 E9 38 49 D2 37 6F 89 19 A3 C1 95 6B D5 3B 0A 43 A3 0D 90 12 85 73 E7 96 58 0A 55 44 79 5A 93 DA 89 30 81 77 B2 1D 38 4D E1 91 69 03 54 86 B4 42 3B E0 A6 86 AA 7F 7B 49 2D 42 71 82 67 3D F1 08 17 DE D2 E9 BD 6D D7 DD 85 F4 F2 A2 8B 38 F1 CE 90 6A 89 7F DB 87 3E C3 23 D2 14 4E 65 76 50 63 B0 A3 26 FA D0 49 A6 E2 13]
2023-07-06 17:22:55      Positive Response from ECU [71 01 02 02 00 00] (141 ms)
2023-07-06 17:22:55  >>>>> JobPosition: Erase erase of the flash memory {
2023-07-06 17:22:55  HexService [31 01 FF 00 01 00]
2023-07-06 17:22:59      Positive Response from ECU [71 01 FF 00 00 00] (3775 ms)
2023-07-06 17:22:59  }
2023-07-06 17:22:59  >>>>> JobPosition: DownloadDataBlock Download of application data {
2023-07-06 17:22:59  Flashing DataBlock _2479023401_001_173900_SW_HLI
2023-07-06 17:22:59  DataBlockType: CODE
2023-07-06 17:22:59  Partnumber: 2479023401_001
2023-07-06 17:22:59  Available number of Flash Segments: 1
2023-07-06 17:22:59  Will download totalNoBytes: 999424
2023-07-06 17:22:59  start segment: 0 block offset:0
2023-07-06 17:22:59  Downloading segment 0
2023-07-06 17:22:59  Segment_0x00004000_0x000F7FFF Size uncompressed:999424 start:16384
2023-07-06 17:22:59  >>>>> JobPosition: DownloadDataBlockStartTransfer initiating data transfer of application {
2023-07-06 17:22:59  HexService [34 00 44 00 00 40 00 00 0F 40 00]
2023-07-06 17:22:59      Positive Response from ECU [74 20 0F 02] (9 ms)
2023-07-06 17:22:59  maxNumberOfBlockLength: 3840 bytes:999424
2023-07-06 17:22:59  >>>>> JobPosition: DownloadDataBlockTransfer transfering data of application {
2023-07-06 17:24:11  }
2023-07-06 17:24:11  >>>>> JobPosition: DownloadDataBlockTransferExit ending data transfer of application {
2023-07-06 17:24:11  HexService [37]
2023-07-06 17:24:11      Positive Response from ECU [77] (3 ms)
2023-07-06 17:24:11  Download of data block finished in 71s
2023-07-06 17:24:11  >>>>> JobPosition: CheckMemData checkmemory of data or applikation {
2023-07-06 17:24:11  HexService [31 01 02 02 00 04 21 25 AA DB 00 80 2A 20 CF 11 C3 AF 38 1B 0A F2 82 8B C3 52 A0 3C 0A 1C 3C F3 3F 2B 0C 59 FF C3 6B 62 1E 7E 1D 97 AA 0D 33 76 F1 1D 9D BF B2 0B B7 34 0D CB CB 38 B6 E2 FA CA EF 97 BB 02 B8 3F 06 8D 3B 27 10 E6 59 EF 72 75 CC 9E 17 0B 70 DD 3F A0 EA E7 3F 95 5C D3 5B F1 49 90 B0 41 3B 60 5F 24 C2 97 58 F6 18 F6 08 E2 2D 10 85 E9 33 BB C3 4C 33 95 56 A1 CF 33 1F CC B3 64 E7 C0 2B B3 FC 5A EB 27 10 7C]
2023-07-06 17:24:11      Positive Response from ECU [71 01 02 02 00 04] (144 ms)
2023-07-06 17:24:11  SEVERE
2023-07-06 17:24:11  SEVERE >>>>> com.daimler.odxjobs.exception.InternalJobException {
2023-07-06 17:24:11  SEVERE A Signature error occured while checking the just flashed block
2023-07-06 17:24:11  SEVERE com.daimler.odxjobs.exception.InternalJobException: A Signature error occured while checking the just flashed block
2023-07-06 17:24:11  SEVERE     at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.checkMemoryRoutine(AbstractUdsFlashJob.java:2473)
2023-07-06 17:24:11  SEVERE     at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.downloadFlashData(AbstractUdsFlashJob.java:1863)
2023-07-06 17:24:11  SEVERE     at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.startMajorProgrammingSequence(AbstractUdsFlashJob.java:699)
2023-07-06 17:24:11  SEVERE     at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.executeJobTask(AbstractUdsFlashJob.java:317)
2023-07-06 17:24:11  SEVERE     at com.daimler.odxjobs.flash.uds.MCD3_GenericUdsFlashjob.executeJobTask(MCD3_GenericUdsFlashjob.java:76)
2023-07-06 17:24:11  SEVERE     at com.daimler.odxjobs.common.AbstractSingleEcuJob.execute(AbstractSingleEcuJob.java:280)
2023-07-06 17:24:11  SEVERE     at com.daimler.odxjobs.flash.AbstractFlashJob.execute(AbstractFlashJob.java:129)
2023-07-06 17:24:11  SEVERE     at JobProcessor.JobThread.run(Unknown Source)
2023-07-06 17:24:11  SEVERE }
2023-07-06 17:24:11  SEVERE Job error:
2023-07-06 17:24:11  SEVERE  Severity: eERROR
2023-07-06 17:24:11  SEVERE     Code: 51717
2023-07-06 17:24:11  SEVERE     CodeDescription: Unknown error code
2023-07-06 17:24:11  SEVERE     VendorCode: 21781
2023-07-06 17:24:11  SEVERE     VendorCodeDescription: JobError occured .21781 Position: CheckMemData > A Signature error occured while checking the just flashed block logId: 1892B95A484
2023-07-06 17:24:11  SEVERE Execution State = eALL_FAILED
2023-07-06 17:24:11  SEVERE Error occurred during job execution!
2023-07-06 17:24:11  Job duration: 0h 1m 17s 149ms
2023-07-06 17:24:11  Total number of bytes transferred: 1 007 616
2023-07-06 17:24:11  Transfer rate: 13886byte/s
2023-07-06 17:24:11  Transfer time: 72 s
2023-07-06 17:24:11  Uncompressed transfer Time: 71 s
2023-07-06 17:24:11  Erase time: 3s
2023-07-06 17:24:11  Checkmemory time: 0s
2023-07-06 17:24:11  Checkdependency time: 0s
2023-07-06 17:24:11  WARNING Erasetime differs significantly from Tested time, expected time:9
2023-07-06 17:24:11  Flash process stopped due to error!
Два линка должно быть открыто в diagnostic services
Там слева видно, что с замком связь есть. Кто-то шил такие блоки вобще?
проверка подписи... у тебя licenese загружен в конфигураторе DTS? а то какой-то он горбатый. кнопки с вопросиками и прочее...
Загружен. Прошиваю каждый день что-то. СМРД файлы я крайний раз самые новые взял, в проектах действительно 16-17-18 год был. Но это тоже не дает эффекта к сожалению.
Прошил в 8.14. Эффект тот же.
Messages in Flash Control created at 18:31:18  on 06.07.2023
Software Version 8.14.016
2023-07-06 18:28:13  Ready to Start
2023-07-06 18:29:31  Flash process in progress. Currently flashing session: 2479023401_001_173900_SW_HLI
2023-07-06 18:29:31  ODX version: 0.7.47
2023-07-06 18:29:31  >>>>> JobPosition: job started job started {
2023-07-06 18:29:31  JobVersion: 1.0.18
2023-07-06 18:29:31  JobName: HLI_Fx247
2023-07-06 18:29:31  TemplateVersion: 9.2.8
2023-07-06 18:29:31  TemplateName: DaimlerUDSFlashjob
2023-07-06 18:29:31  Input parameter:
2023-07-06 18:29:31      debug = NORMAL_MODE
2023-07-06 18:29:31      jobState = PREPTRANSFIN
2023-07-06 18:29:31  ECUBaseVariant = HLI_FL247 650 / 5D0
2023-07-06 18:29:31  ECUVariant     = HLI_FL247_Boot_Variante_R7_1
2023-07-06 18:29:31  Protocol       = UDS_CAN_D
2023-07-06 18:29:31  JobQualifier   = WVC_FlashProg (com.daimler.odxjobs.flash.uds.MCD3_GenericUdsFlashjob)
2023-07-06 18:29:31  JobVersion     = 1.0.18
2023-07-06 18:29:31  >>>>> JobPosition: ReadingConfigFile reading the xml file to retrive ECU information {
2023-07-06 18:29:31  }
2023-07-06 18:29:31  Using debug state NORMAL_MODE
2023-07-06 18:29:31  WARNING unable to get logbreaker parameter
2023-07-06 18:29:31  This is some junit test test
2023-07-06 18:29:31  >>>>> JobPosition: Initialization Initialization of Dlls {
2023-07-06 18:29:32  Logical block ID: 0
2023-07-06 18:29:32  Department = Development
2023-07-06 18:29:32  TesterID: 0x1
2023-07-06 18:29:32  Executing service ReadFingerprint_Read
2023-07-06 18:29:32  RQ_ReadFingerprint_Read [22 F1 5B]
2023-07-06 18:29:32      Positive Response from ECU [62 F1 5B 56 00 04 17 07 06 00 00 00 01] (20 ms)
2023-07-06 18:29:32  Response of service ReadFingerprint_Read
2023-07-06 18:29:32      Software_Programmed_and_Valid: Software invalid
2023-07-06 18:29:32      Software_Software_Mismatch: mismatch occurred
2023-07-06 18:29:32      Software_Hardware_Mismatch: mismatch occurred
2023-07-06 18:29:32      Memory_Status_Information: Memory Programmed
2023-07-06 18:29:32      Reprogramming_Process_State_1: Memory check unsuccessful
2023-07-06 18:29:32      Supplier_Identification: MB
2023-07-06 18:29:32      SW_Programming_year: 23
2023-07-06 18:29:32      SW_Programming_month: 7
2023-07-06 18:29:32      SW_Programming_day: 6
2023-07-06 18:29:32      Diagnostic_Tool_Serial_Number: 00 00 00 01
2023-07-06 18:29:32
2023-07-06 18:29:32  Executing service BootSoftwareVersion_Read
2023-07-06 18:29:32  RQ_BootSoftwareVersion_Read [22 F1 53]
2023-07-06 18:29:32      Positive Response from ECU [62 F1 53 01 02 10] (5 ms)
2023-07-06 18:29:32  Response of service BootSoftwareVersion_Read
2023-07-06 18:29:32      Boot_SW_year: 1
2023-07-06 18:29:32      Boot_SW_week: 2
2023-07-06 18:29:32      Boot_SW_patch_level: 16
2023-07-06 18:29:32
2023-07-06 18:29:32  Executing service HardwareVersion_Read
2023-07-06 18:29:32  RQ_HardwareVersion_Read [22 F1 50]
2023-07-06 18:29:32      Positive Response from ECU [62 F1 50 11 14 00] (8 ms)
2023-07-06 18:29:32  Response of service HardwareVersion_Read
2023-07-06 18:29:32      HW_year: 17
2023-07-06 18:29:32      HW_week: 20
2023-07-06 18:29:32      HW_patch_level: 0
2023-07-06 18:29:32
2023-07-06 18:29:32  Executing service SoftwareVersion_Read
2023-07-06 18:29:32  RQ_SoftwareVersion_Read [22 F1 51]
2023-07-06 18:29:32      Positive Response from ECU [62 F1 51 11 27 00] (6 ms)
2023-07-06 18:29:32  Response of service SoftwareVersion_Read
2023-07-06 18:29:32      SW_patch_level: 0
2023-07-06 18:29:32      SW_week: 39
2023-07-06 18:29:32      SW_year: 17
2023-07-06 18:29:32
2023-07-06 18:29:32  Executing service MercedesCarGroupHardware_Read
2023-07-06 18:29:32  RQ_MercedesCarGroupHardware_Read [22 F1 11]
2023-07-06 18:29:32      Positive Response from ECU [62 F1 11 32 34 37 39 30 31 30 37 30 32] (23 ms)
2023-07-06 18:29:32  Response of service MercedesCarGroupHardware_Read
2023-07-06 18:29:32      Hardware_Part_Number: 2479010702
2023-07-06 18:29:32
2023-07-06 18:29:32  Executing service MercedesCarGroupSoftware_Read
2023-07-06 18:29:32  RQ_MercedesCarGroupSoftware_Read [22 F1 21]
2023-07-06 18:29:32      Positive Response from ECU [62 F1 21 32 34 37 39 30 32 33 36 30 30] (23 ms)
2023-07-06 18:29:32  Response of service MercedesCarGroupSoftware_Read
2023-07-06 18:29:32      Logical_Block_0_Part_Number: 2479023600
2023-07-06 18:29:32
2023-07-06 18:29:32  Executing service Reprogramming_Attempt_Counter_Read
2023-07-06 18:29:32  RQ_Reprogramming_Attempt_Counter_Read [22 01 00]
2023-07-06 18:29:32      Positive Response from ECU [62 01 00 00 29 10 00] (3 ms)
2023-07-06 18:29:32  Response of service Reprogramming_Attempt_Counter_Read
2023-07-06 18:29:32      Number_of_Reprogramming_Attempts_Counter_0: 41
2023-07-06 18:29:32      Max_Number_of_Reprogramming_Attempts_Counter_0: 4096
2023-07-06 18:29:32
2023-07-06 18:29:32  current Monitoring state:true
2023-07-06 18:29:32  Using Jobstate PREPTRANSFIN
2023-07-06 18:29:32  Build-Date:Release <XXXXXXXXXXXXXXXXXXXXXX>
2023-07-06 18:29:32  }
2023-07-06 18:29:32  Global Flashstate: Flash state not set
2023-07-06 18:29:32  Link type:CAN
2023-07-06 18:29:32  P2Max:2100000
2023-07-06 18:29:32  RC78CompletionTimeout:60000000
2023-07-06 18:29:32  >>>>> JobPosition: VarIdentification identifying the FBL Version with the Active Diagnostic Information service {
2023-07-06 18:29:32  Executing service ActiveDiagnosticInformation_Read
2023-07-06 18:29:32  RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2023-07-06 18:29:32      Positive Response from ECU [62 F1 00 01 05 06 03] (3 ms)
2023-07-06 18:29:32  Response of service ActiveDiagnosticInformation_Read
2023-07-06 18:29:32      Active_Diagnostic_Version: 6
2023-07-06 18:29:32      Active_Diagnostic_Variant: 5
2023-07-06 18:29:32      ECU_Software_Mode: Running in Boot
2023-07-06 18:29:32      Identification: 66822
2023-07-06 18:29:32      Active_Diagnostic_Session: Extended
2023-07-06 18:29:32
2023-07-06 18:29:32  >>>>> JobPosition: StartSessionProgramming setting ECU into programming Session {
2023-07-06 18:29:32  WARNING Unable to find service 'StartSecureDiagSession' via short name
2023-07-06 18:29:32  Exception of StartSecureDiagSessionservice not found in database > Could not find serivce 'StartSecureDiagSession' by ShortName or interal service list.
2023-07-06 18:29:32  Executing service Programming_Start
2023-07-06 18:29:32  RQ_Programming_Start [10 02]
2023-07-06 18:29:32      Positive Response from ECU [50 02 00 14 00 C8] (7 ms)
2023-07-06 18:29:32  Response of service Programming_Start
2023-07-06 18:29:32      P2_CAN_ECU_max: 20.000000
2023-07-06 18:29:32      P2s_CAN_ECU_max: 2000.000000
2023-07-06 18:29:32
2023-07-06 18:29:32  ProgSession change:0s
2023-07-06 18:29:32      Positive Response from ECU [62 F1 00 01 05 06 02] (3 ms)
2023-07-06 18:29:32      Active_Diagnostic_Session: Programming
2023-07-06 18:29:32
2023-07-06 18:29:32  DiagnosticStatusOfEcu: 0x1
2023-07-06 18:29:32  DiagnosticVariant: 0x5
2023-07-06 18:29:32  DiagnosticVersion: 0x6
2023-07-06 18:29:32  DiagnosticSession: 0x2
2023-07-06 18:29:32  Active DiagnosticVariant: 0x506
2023-07-06 18:29:32  Used variant: Development
2023-07-06 18:29:32  Bootloader Revision: REV_G Security Class: CLASS_CCC Signature Key Type: DEVELOPMENT sendCrc = true key length = 4
2023-07-06 18:29:32  Use data compression: false
2023-07-06 18:29:32  jobstate set to PREPTRANSFIN but ecu does not support stateflash therefore switching to classic mode
2023-07-06 18:29:32  >>>>> JobPosition: SetComparameter setting comunication parameters {
2023-07-06 18:29:32  >>>>> JobPosition: SecurityAccessViaJar calculating the security key with Jar {
2023-07-06 18:29:32  loading secure jar HLI_Fx247_16_03_03.jar.pgp
2023-07-06 18:29:32  file in jar found:com/
2023-07-06 18:29:32  file in jar found:com/daimler/
2023-07-06 18:29:32  file in jar found:com/daimler/security/
2023-07-06 18:29:32  file in jar found:com/daimler/security/interfaces/
2023-07-06 18:29:32  file in jar found:com/daimler/security/interfaces/IParameterProvider.class
2023-07-06 18:29:32  file in jar found:com/daimler/security/interfaces/ISecurityAlgorithm.class
2023-07-06 18:29:32  file in jar found:com/daimler/security/interfaces/ISeedKey.class
2023-07-06 18:29:32  file in jar found:com/daimler/security/interfaces/Parameter.class
2023-07-06 18:29:32  file in jar found:com/daimler/security/interfaces/ParameterDesc.class
2023-07-06 18:29:32  file in jar found:com/daimler/security/interfaces/VKeyGenResultEx.class
2023-07-06 18:29:32  file in jar found:com/daimler/security/algorithms/
2023-07-06 18:29:32  file in jar found:com/daimler/security/algorithms/DaimlerStandardSecurityAlgoRefG.class
2023-07-06 18:29:32  file in jar found:com/daimler/security/generated/
2023-07-06 18:29:32  file in jar found:com/daimler/security/generated/HLI_Fx247_16_03_03_20181310091344.class
2023-07-06 18:29:32  plugin with interface com.daimler.security.interfaces.ISeedKey and implementation com.daimler.security.generated.HLI_Fx247_16_03_03_20181310091344 used
2023-07-06 18:29:32  ISeedKey plugin successfully loaded
2023-07-06 18:29:32  requesting seed for sa
2023-07-06 18:29:32  HexService [27 11]
2023-07-06 18:29:32      Positive Response from ECU [67 11 C7 D8 E7 EE 46 DD C5 BB] (16 ms)
2023-07-06 18:29:32  Security Access - Calculating Key from Seed
2023-07-06 18:29:32  file in jar found:com/daimler/security/generated/ParameterProvider_HLI_Fx247_16_03_03_20181310091344.class
2023-07-06 18:29:32  GenerateKeyExOpt returned: KGRE_Ok
2023-07-06 18:29:32  HexService [27 12 36 7A 70 6A]
2023-07-06 18:29:32      Positive Response from ECU [67 12] (6 ms)
2023-07-06 18:29:32  Security Access Successful
2023-07-06 18:29:32  Block size and STmin parameter not set.
2023-07-06 18:29:32  >>>>> JobPosition: WriteFingerPrint writing date and tester information {
2023-07-06 18:29:32  Programming Date: Thu Jul 06 18:29:32 MSK 2023 used BlockId: 0
2023-07-06 18:29:32  HexService [2E F1 5A 00 04 17 07 06 00 00 00 01]
2023-07-06 18:29:32      Positive Response from ECU [6E F1 5A] (7 ms)
2023-07-06 18:29:32  Baudrate parameter not set
2023-07-06 18:29:32  >>>>> JobPosition: ProgrammingState getting programmingstate of logical block {
2023-07-06 18:29:32  HexService [22 F1 5B]
2023-07-06 18:29:32      Positive Response from ECU [62 F1 5B 56 00 04 17 07 06 00 00 00 01] (22 ms)
2023-07-06 18:29:32  blockstate of block 0 is Memorycheckunsuccessful
2023-07-06 18:29:32  >>>>> JobPosition: DownloadSwil1 download of swil1 {
2023-07-06 18:29:32  com.daimler.odxjobs.flash.Swil@1187964
2023-07-06 18:29:32  >>>>> JobPosition: DownloadSwilBlockStartTransfer start transfer of swil data {
2023-07-06 18:29:32  HexService [34 00 44 FE DF 80 00 00 00 20 00]
2023-07-06 18:29:32      Positive Response from ECU [74 20 0F 02] (5 ms)
2023-07-06 18:29:32  maxNumberOfBlockLength: 3840 bytes:8192
2023-07-06 18:29:32  >>>>> JobPosition: DownloadSwilBlockTransfer transfering swill data {
2023-07-06 18:29:32  Will download: 8192 bytes
2023-07-06 18:29:32  >>>>> JobPosition: DownloadSwilBlockTransferExit ending swil data transfer {
2023-07-06 18:29:32  HexService [37]
2023-07-06 18:29:32      Positive Response from ECU [77] (2 ms)
2023-07-06 18:29:32  >>>>> JobPosition: CheckMemSwil1 checkmemory of swil1 {
2023-07-06 18:29:32  HexService [31 01 02 02 00 04 31 EF 3F 53 00 80 44 74 39 DD BD 01 83 69 38 C2 53 28 7D FC 8C E4 0E F3 00 9D EC 00 91 E9 38 49 D2 37 6F 89 19 A3 C1 95 6B D5 3B 0A 43 A3 0D 90 12 85 73 E7 96 58 0A 55 44 79 5A 93 DA 89 30 81 77 B2 1D 38 4D E1 91 69 03 54 86 B4 42 3B E0 A6 86 AA 7F 7B 49 2D 42 71 82 67 3D F1 08 17 DE D2 E9 BD 6D D7 DD 85 F4 F2 A2 8B 38 F1 CE 90 6A 89 7F DB 87 3E C3 23 D2 14 4E 65 76 50 63 B0 A3 26 FA D0 49 A6 E2 13]
2023-07-06 18:29:32      Positive Response from ECU [71 01 02 02 00 00] (142 ms)
2023-07-06 18:29:32  >>>>> JobPosition: Erase erase of the flash memory {
2023-07-06 18:29:32  HexService [31 01 FF 00 01 00]
2023-07-06 18:29:36      Positive Response from ECU [71 01 FF 00 00 00] (3784 ms)
2023-07-06 18:29:36  }
2023-07-06 18:29:36  >>>>> JobPosition: DownloadDataBlock Download of application data {
2023-07-06 18:29:36  Flashing DataBlock _2479023401_001_173900_SW_HLI
2023-07-06 18:29:36  DataBlockType: CODE
2023-07-06 18:29:36  Partnumber: 2479023401_001
2023-07-06 18:29:36  Available number of Flash Segments: 1
2023-07-06 18:29:36  Will download totalNoBytes: 999424
2023-07-06 18:29:36  start segment: 0 block offset:0
2023-07-06 18:29:36  Downloading segment 0
2023-07-06 18:29:36  Segment_0x00004000_0x000F7FFF Size uncompressed:999424 start:16384
2023-07-06 18:29:36  >>>>> JobPosition: DownloadDataBlockStartTransfer initiating data transfer of application {
2023-07-06 18:29:36  HexService [34 00 44 00 00 40 00 00 0F 40 00]
2023-07-06 18:29:36      Positive Response from ECU [74 20 0F 02] (9 ms)
2023-07-06 18:29:36  maxNumberOfBlockLength: 3840 bytes:999424
2023-07-06 18:29:36  >>>>> JobPosition: DownloadDataBlockTransfer transfering data of application {
2023-07-06 18:30:47  }
2023-07-06 18:30:47  >>>>> JobPosition: DownloadDataBlockTransferExit ending data transfer of application {
2023-07-06 18:30:47  HexService [37]
2023-07-06 18:30:47      Positive Response from ECU [77] (3 ms)
2023-07-06 18:30:47  Download of data block finished in 71s
2023-07-06 18:30:47  >>>>> JobPosition: CheckMemData checkmemory of data or applikation {
2023-07-06 18:30:47  HexService [31 01 02 02 00 04 21 25 AA DB 00 80 2A 20 CF 11 C3 AF 38 1B 0A F2 82 8B C3 52 A0 3C 0A 1C 3C F3 3F 2B 0C 59 FF C3 6B 62 1E 7E 1D 97 AA 0D 33 76 F1 1D 9D BF B2 0B B7 34 0D CB CB 38 B6 E2 FA CA EF 97 BB 02 B8 3F 06 8D 3B 27 10 E6 59 EF 72 75 CC 9E 17 0B 70 DD 3F A0 EA E7 3F 95 5C D3 5B F1 49 90 B0 41 3B 60 5F 24 C2 97 58 F6 18 F6 08 E2 2D 10 85 E9 33 BB C3 4C 33 95 56 A1 CF 33 1F CC B3 64 E7 C0 2B B3 FC 5A EB 27 10 7C]
2023-07-06 18:30:48      Positive Response from ECU [71 01 02 02 00 04] (143 ms)
2023-07-06 18:30:48  }
2023-07-06 18:30:48  SEVERE
2023-07-06 18:30:48  SEVERE >>>>> com.daimler.odxjobs.exception.InternalJobException {
2023-07-06 18:30:48  SEVERE A Signature error occured while checking the just flashed block
2023-07-06 18:30:48  SEVERE com.daimler.odxjobs.exception.InternalJobException: A Signature error occured while checking the just flashed block
2023-07-06 18:30:48  SEVERE     at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.checkMemoryRoutine(AbstractUdsFlashJob.java:2473)
2023-07-06 18:30:48  SEVERE     at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.downloadFlashData(AbstractUdsFlashJob.java:1863)
2023-07-06 18:30:48  SEVERE     at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.startMajorProgrammingSequence(AbstractUdsFlashJob.java:699)
2023-07-06 18:30:48  SEVERE     at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.executeJobTask(AbstractUdsFlashJob.java:317)
2023-07-06 18:30:48  SEVERE     at com.daimler.odxjobs.flash.uds.MCD3_GenericUdsFlashjob.executeJobTask(MCD3_GenericUdsFlashjob.java:76)
2023-07-06 18:30:48  SEVERE     at com.daimler.odxjobs.common.AbstractSingleEcuJob.execute(AbstractSingleEcuJob.java:280)
2023-07-06 18:30:48  SEVERE     at com.daimler.odxjobs.flash.AbstractFlashJob.execute(AbstractFlashJob.java:129)
2023-07-06 18:30:48  SEVERE     at JobProcessor.JobThread.run(Unknown Source)
2023-07-06 18:30:48  SEVERE }
2023-07-06 18:30:48  SEVERE Job error:
2023-07-06 18:30:48  SEVERE  Severity: eERROR
2023-07-06 18:30:48  SEVERE     Code: 51717
2023-07-06 18:30:48  SEVERE     CodeDescription:
2023-07-06 18:30:48  SEVERE     VendorCode: 21781
2023-07-06 18:30:48  SEVERE     VendorCodeDescription: JobError occured .21781 Position: CheckMemData > A Signature error occured while checking the just flashed block logId: 1892BD2A278
2023-07-06 18:30:48  SEVERE Execution State = eALL_FAILED
2023-07-06 18:30:48  SEVERE Error occurred during job execution!
2023-07-06 18:30:48  Job duration: 0h 1m 16s 316ms
2023-07-06 18:30:48  Total number of bytes transferred: 1 007 616
2023-07-06 18:30:48  Transfer rate: 14042byte/s
2023-07-06 18:30:48  Transfer time: 71 s
2023-07-06 18:30:48  Uncompressed transfer Time: 71 s
2023-07-06 18:30:48  Erase time: 3s
2023-07-06 18:30:48  Checkmemory time: 0s
2023-07-06 18:30:48  Checkdependency time: 0s
2023-07-06 18:30:48  WARNING Erasetime differs significantly from Tested time, expected time:9
2023-07-06 18:30:48  Flash process stopped due to error!
За три дня можно было уже на крайняк прям в кан подключиться и прошить на прямую?
Кац предлагает сдаться.
Можно и проц перепаять. Он есть. Можно прогер подобрать попробовать. НО! Наверное, это не имеет смысла. Завтра придет блок, закодирую его, и все заработает. А три дня я потратил для общего развития, что-то новое узнал.
да, блин, не бывает такого с этими блоками... если есть прям сд-коннект, то настройте софтезернет, и вам сделают удалённо.
Есть, настроено всё. Ты пару подключался когда-то. Что-то по мочевине не получалось сбросить тогда. Коннектов 5 есть.
Короче, что-то пошло не так с ним. Они его не забрали, при случает вскрою и посмотрю. Новый блок решил проблему, закодировался без проблем. Машина уехала. Всем спасибо за помощь!
Новый блок с тем же номером ставили, или новый который по замене?
Новый по замене, там фото выше было. Он один висел через 2 дня, остальное долго совсем. интересная история. Но и 167 я не прошива ранее, они пока только на ТО приезжают да мелкий ремонт.
FF пишутся
а ещё у меня например так бывает если я из проектов пытаюсь шить, если сделать новую папку с 3 файлами замок, фара , софт то шьёт
так это видимо в прошивке так... там-же не сё время FF пишется. а в проектах не во всех есть сразу разблокировка замка. надо руками подправлять чтоб появился замок для разблокировки.
Есть ещё вариант. Параллельно на ОБД скентри запустить и держать открытую сессию на замке, тогда можно хоть ведиамой шить и сохранять , я недавно не мог код от магнитолы HU55 сохранить, хотя замок был разлочен и софт залил, а как старуху параллельно подключил так код и сохранился
Была такая же ситуация с таким же блоком. Шиться не хотел ни как, доходило до 78% и дальше резко 100%. Пришлось в ручную как говориться проц проливать со вскрытием блока.
