и что в логе было? иначе - ни о чём.Шиться не хотел ни как, доходило до 78% и дальше резко 100%.
Messages in Flash Control created at 16:38:52 on 17.09.2026
Software Version 8.16.015
2026-09-17 16:29:05 Ready to Start
2026-09-17 16:34:23 Flash process in progress. Currently flashing session: 2479023401_001_173900_SW_HLI
2026-09-17 16:34:23 ODX version: 0.7.45
2026-09-17 16:34:23 >>>>> JobPosition: job started job started {
2026-09-17 16:34:23 JobVersion: 1.0.18
2026-09-17 16:34:23 JobName: HLI_Fx247
2026-09-17 16:34:23 TemplateVersion: 9.2.8
2026-09-17 16:34:23 TemplateName: DaimlerUDSFlashjob
2026-09-17 16:34:23 Input parameter:
2026-09-17 16:34:23 debug = NORMAL_MODE
2026-09-17 16:34:23 jobState = PREPTRANSFIN
2026-09-17 16:34:23 ECUBaseVariant = HLI_FL247 650 / 5D0
2026-09-17 16:34:23 ECUVariant = HLI_FL247_Boot_Variante_R7_1
2026-09-17 16:34:23 Protocol = UDS_CAN_D
2026-09-17 16:34:23 JobQualifier = WVC_FlashProg (com.daimler.odxjobs.flash.uds.MCD3_GenericUdsFlashjob)
2026-09-17 16:34:23 JobVersion = 1.0.18
2026-09-17 16:34:23 >>>>> JobPosition: ReadingConfigFile reading the xml file to retrive ECU information {
2026-09-17 16:34:24 }
2026-09-17 16:34:24 Using debug state NORMAL_MODE
2026-09-17 16:34:24 WARNING unable to get logbreaker parameter
2026-09-17 16:34:24 This is some junit test test
2026-09-17 16:34:24 >>>>> JobPosition: Initialization Initialization of Dlls {
2026-09-17 16:34:24 Logical block ID: 0
2026-09-17 16:34:24 Department = Development
2026-09-17 16:34:24 TesterID: 0x1
2026-09-17 16:34:24 Executing service ReadFingerprint_Read
2026-09-17 16:34:24 RQ_ReadFingerprint_Read [22 F1 5B]
2026-09-17 16:34:24 Positive Response from ECU [62 F1 5B 56 00 04 1A 09 11 00 00 00 01] (4 ms)
2026-09-17 16:34:24 Response of service ReadFingerprint_Read
2026-09-17 16:34:24 Software_Programmed_and_Valid: Software invalid
2026-09-17 16:34:24 Software_Software_Mismatch: mismatch occurred
2026-09-17 16:34:24 Software_Hardware_Mismatch: mismatch occurred
2026-09-17 16:34:24 Memory_Status_Information: Memory Programmed
2026-09-17 16:34:24 Reprogramming_Process_State_1: Memory check unsuccessful
2026-09-17 16:34:24 Supplier_Identification: MB
2026-09-17 16:34:24 SW_Programming_year: 26
2026-09-17 16:34:24 SW_Programming_month: 9
2026-09-17 16:34:24 SW_Programming_day: 17
2026-09-17 16:34:24 Diagnostic_Tool_Serial_Number: 00 00 00 01
2026-09-17 16:34:24
2026-09-17 16:34:24 Executing service BootSoftwareVersion_Read
2026-09-17 16:34:24 RQ_BootSoftwareVersion_Read [22 F1 53]
2026-09-17 16:34:24 Positive Response from ECU [62 F1 53 11 26 00] (2 ms)
2026-09-17 16:34:24 Response of service BootSoftwareVersion_Read
2026-09-17 16:34:24 Boot_SW_year: 17
2026-09-17 16:34:24 Boot_SW_week: 38
2026-09-17 16:34:24 Boot_SW_patch_level: 0
2026-09-17 16:34:24
2026-09-17 16:34:24 Executing service HardwareVersion_Read
2026-09-17 16:34:24 RQ_HardwareVersion_Read [22 F1 50]
2026-09-17 16:34:24 Positive Response from ECU [62 F1 50 11 14 00] (2 ms)
2026-09-17 16:34:24 Response of service HardwareVersion_Read
2026-09-17 16:34:24 HW_year: 17
2026-09-17 16:34:24 HW_week: 20
2026-09-17 16:34:24 HW_patch_level: 0
2026-09-17 16:34:24
2026-09-17 16:34:24 Executing service SoftwareVersion_Read
2026-09-17 16:34:24 RQ_SoftwareVersion_Read [22 F1 51]
2026-09-17 16:34:24 Positive Response from ECU [62 F1 51 11 27 00] (2 ms)
2026-09-17 16:34:24 SEVERE Severity: eERROR
2026-09-17 16:34:24 SEVERE Code: 49192
2026-09-17 16:34:24 SEVERE CodeDescription: The interpretation of a Service failed.
2026-09-17 16:34:24 SEVERE VendorCode: 54179
2026-09-17 16:34:24 SEVERE VendorCodeDescription: Error: MaxLength violation (PDU is too long), Required bytes: 32, available: 48.
2026-09-17 16:34:24 Executing service MercedesCarGroupHardware_Read
2026-09-17 16:34:24 RQ_MercedesCarGroupHardware_Read [22 F1 11]
2026-09-17 16:34:24 Positive Response from ECU [62 F1 11 32 34 37 39 30 31 30 39 30 32] (3 ms)
2026-09-17 16:34:24 Response of service MercedesCarGroupHardware_Read
2026-09-17 16:34:24 Hardware_Part_Number: 2479010902
2026-09-17 16:34:24
2026-09-17 16:34:24 Executing service MercedesCarGroupSoftware_Read
2026-09-17 16:34:24 RQ_MercedesCarGroupSoftware_Read [22 F1 21]
2026-09-17 16:34:24 Positive Response from ECU [62 F1 21 32 34 37 39 30 32 33 36 30 30] (3 ms)
2026-09-17 16:34:24 Response of service MercedesCarGroupSoftware_Read
2026-09-17 16:34:24 Logical_Block_0_Part_Number: [URL='https://benzpro.ru/forum/pages/flashware/?q=2479023600']2479023600[/URL]
2026-09-17 16:34:24
2026-09-17 16:34:24 Executing service Reprogramming_Attempt_Counter_Read
2026-09-17 16:34:24 RQ_Reprogramming_Attempt_Counter_Read [22 01 00]
2026-09-17 16:34:24 Positive Response from ECU [62 01 00 00 2B 10 00] (2 ms)
2026-09-17 16:34:24 Response of service Reprogramming_Attempt_Counter_Read
2026-09-17 16:34:24 Number_of_Reprogramming_Attempts_Counter_0: 43
2026-09-17 16:34:24 Max_Number_of_Reprogramming_Attempts_Counter_0: 4096
2026-09-17 16:34:24
2026-09-17 16:34:24 current Monitoring state:true
2026-09-17 16:34:24 Using Jobstate PREPTRANSFIN
2026-09-17 16:34:24 Build-Date:Release <XXXXXXXXXXXXXXXXXXXXXX>
2026-09-17 16:34:24 Global Flashstate: Flash state not set
2026-09-17 16:34:24 Link type:CAN
2026-09-17 16:34:24 P2Max:2100000
2026-09-17 16:34:24 RC78CompletionTimeout:60000000
2026-09-17 16:34:24 >>>>> JobPosition: VarIdentification identifying the FBL Version with the Active Diagnostic Information service {
2026-09-17 16:34:24 Executing service ActiveDiagnosticInformation_Read
2026-09-17 16:34:24 RQ_ActiveDiagnosticInformation_Read [22 F1 00]
2026-09-17 16:34:24 Positive Response from ECU [62 F1 00 01 05 06 03] (2 ms)
2026-09-17 16:34:24 Response of service ActiveDiagnosticInformation_Read
2026-09-17 16:34:24 Active_Diagnostic_Version: 6
2026-09-17 16:34:24 Active_Diagnostic_Variant: 5
2026-09-17 16:34:24 ECU_Software_Mode: Running in Boot
2026-09-17 16:34:24 Identification: 66822
2026-09-17 16:34:24 Active_Diagnostic_Session: Extended
2026-09-17 16:34:24
2026-09-17 16:34:24 >>>>> JobPosition: StartSessionProgramming setting ECU into programming Session {
2026-09-17 16:34:24 WARNING Unable to find service 'StartSecureDiagSession' via short name
2026-09-17 16:34:24 Exception of StartSecureDiagSessionservice not found in database > Could not find serivce 'StartSecureDiagSession' by ShortName or interal service list.
2026-09-17 16:34:24 Executing service Programming_Start
2026-09-17 16:34:24 RQ_Programming_Start [10 02]
2026-09-17 16:34:24 Positive Response from ECU [50 02 00 14 00 C8] (2 ms)
2026-09-17 16:34:24 Response of service Programming_Start
2026-09-17 16:34:24 P2_CAN_ECU_max: 20.000000
2026-09-17 16:34:24 P2s_CAN_ECU_max: 2000.000000
2026-09-17 16:34:24
2026-09-17 16:34:24 ProgSession change:0s
2026-09-17 16:34:24 Positive Response from ECU [62 F1 00 01 05 06 02] (1 ms)
2026-09-17 16:34:24 Active_Diagnostic_Session: Programming
2026-09-17 16:34:24
2026-09-17 16:34:24 DiagnosticStatusOfEcu: 0x1
2026-09-17 16:34:24 DiagnosticVariant: 0x5
2026-09-17 16:34:24 DiagnosticVersion: 0x6
2026-09-17 16:34:24 DiagnosticSession: 0x2
2026-09-17 16:34:24 Active DiagnosticVariant: 0x506
2026-09-17 16:34:24 Used variant: Development
2026-09-17 16:34:24 Bootloader Revision: REV_G Security Class: CLASS_CCC Signature Key Type: DEVELOPMENT sendCrc = true key length = 4
2026-09-17 16:34:24 Use data compression: false
2026-09-17 16:34:24 jobstate set to PREPTRANSFIN but ecu does not support stateflash therefore switching to classic mode
2026-09-17 16:34:24 >>>>> JobPosition: SetComparameter setting comunication parameters {
2026-09-17 16:34:24 >>>>> JobPosition: SecurityAccessViaJar calculating the security key with Jar {
2026-09-17 16:34:24 loading secure jar HLI_Fx247_16_03_03.jar.pgp
2026-09-17 16:34:24 file in jar found:com/
2026-09-17 16:34:24 file in jar found:com/daimler/
2026-09-17 16:34:24 file in jar found:com/daimler/security/
2026-09-17 16:34:24 file in jar found:com/daimler/security/interfaces/
2026-09-17 16:34:24 file in jar found:com/daimler/security/interfaces/IParameterProvider.class
2026-09-17 16:34:24 file in jar found:com/daimler/security/interfaces/ISecurityAlgorithm.class
2026-09-17 16:34:24 file in jar found:com/daimler/security/interfaces/ISeedKey.class
2026-09-17 16:34:24 file in jar found:com/daimler/security/interfaces/Parameter.class
2026-09-17 16:34:24 file in jar found:com/daimler/security/interfaces/ParameterDesc.class
2026-09-17 16:34:24 file in jar found:com/daimler/security/interfaces/VKeyGenResultEx.class
2026-09-17 16:34:24 file in jar found:com/daimler/security/algorithms/
2026-09-17 16:34:24 file in jar found:com/daimler/security/algorithms/DaimlerStandardSecurityAlgoRefG.class
2026-09-17 16:34:24 file in jar found:com/daimler/security/generated/
2026-09-17 16:34:24 file in jar found:com/daimler/security/generated/HLI_Fx247_16_03_03_20181310091344.class
2026-09-17 16:34:24 plugin with interface com.daimler.security.interfaces.ISeedKey and implementation com.daimler.security.generated.HLI_Fx247_16_03_03_20181310091344 used
2026-09-17 16:34:24 ISeedKey plugin successfully loaded
2026-09-17 16:34:24 requesting seed for sa
2026-09-17 16:34:24 HexService [27 11]
2026-09-17 16:34:24 Positive Response from ECU [67 11 9F B7 00 7C 6A BA EE 65] (3 ms)
2026-09-17 16:34:24 Security Access - Calculating Key from Seed
2026-09-17 16:34:24 file in jar found:com/daimler/security/generated/ParameterProvider_HLI_Fx247_16_03_03_20181310091344.class
2026-09-17 16:34:24 GenerateKeyExOpt returned: KGRE_Ok
2026-09-17 16:34:24 HexService [27 12 B1 58 8A B6]
2026-09-17 16:34:24 Positive Response from ECU [67 12] (1 ms)
2026-09-17 16:34:24 Security Access Successful
2026-09-17 16:34:24 Block size and STmin parameter not set.
2026-09-17 16:34:24 >>>>> JobPosition: WriteFingerPrint writing date and tester information {
2026-09-17 16:34:24 Programming Date: Thu Sep 17 16:34:24 MSK 2026 used BlockId: 0
2026-09-17 16:34:24 HexService [2E F1 5A 00 04 1A 09 11 00 00 00 01]
2026-09-17 16:34:24 Positive Response from ECU [6E F1 5A] (2 ms)
2026-09-17 16:34:24 Baudrate parameter not set
2026-09-17 16:34:24 >>>>> JobPosition: ProgrammingState getting programmingstate of logical block {
2026-09-17 16:34:24 HexService [22 F1 5B]
2026-09-17 16:34:24 Positive Response from ECU [62 F1 5B 56 00 04 1A 09 11 00 00 00 01] (3 ms)
2026-09-17 16:34:24 blockstate of block 0 is Memorycheckunsuccessful
2026-09-17 16:34:24 >>>>> JobPosition: DownloadSwil1 download of swil1 {
2026-09-17 16:34:24 com.daimler.odxjobs.flash.Swil@1be41e6
2026-09-17 16:34:24 >>>>> JobPosition: DownloadSwilBlockStartTransfer start transfer of swil data {
2026-09-17 16:34:24 HexService [34 00 44 FE DF 80 00 00 00 20 00]
2026-09-17 16:34:24 Positive Response from ECU [74 20 0F 02] (3 ms)
2026-09-17 16:34:24 maxNumberOfBlockLength: 3840 bytes:8192
2026-09-17 16:34:24 >>>>> JobPosition: DownloadSwilBlockTransfer transfering swill data {
2026-09-17 16:34:24 Will download: 8192 bytes
2026-09-17 16:34:24 >>>>> JobPosition: DownloadSwilBlockTransferExit ending swil data transfer {
2026-09-17 16:34:24 HexService [37]
2026-09-17 16:34:24 Positive Response from ECU [77] (2 ms)
2026-09-17 16:34:24 >>>>> JobPosition: CheckMemSwil1 checkmemory of swil1 {
2026-09-17 16:34:24 HexService [31 01 02 02 00 04 31 EF 3F 53 00 80 44 74 39 DD BD 01 83 69 38 C2 53 28 7D FC 8C E4 0E F3 00 9D EC 00 91 E9 38 49 D2 37 6F 89 19 A3 C1 95 6B D5 3B 0A 43 A3 0D 90 12 85 73 E7 96 58 0A 55 44 79 5A 93 DA 89 30 81 77 B2 1D 38 4D E1 91 69 03 54 86 B4 42 3B E0 A6 86 AA 7F 7B 49 2D 42 71 82 67 3D F1 08 17 DE D2 E9 BD 6D D7 DD 85 F4 F2 A2 8B 38 F1 CE 90 6A 89 7F DB 87 3E C3 23 D2 14 4E 65 76 50 63 B0 A3 26 FA D0 49 A6 E2 13]
2026-09-17 16:34:24 Positive Response from ECU [71 01 02 02 00 00] (130 ms)
2026-09-17 16:34:24 >>>>> JobPosition: Erase erase of the flash memory {
2026-09-17 16:34:24 HexService [31 01 FF 00 01 00]
2026-09-17 16:34:28 Positive Response from ECU [71 01 FF 00 00 00] (3715 ms)
2026-09-17 16:34:28 }
2026-09-17 16:34:28 >>>>> JobPosition: DownloadDataBlock Download of application data {
2026-09-17 16:34:28 Flashing DataBlock _2479023401_001_173900_SW_HLI
2026-09-17 16:34:28 DataBlockType: CODE
2026-09-17 16:34:28 Partnumber: 2479023401_001
2026-09-17 16:34:28 Available number of Flash Segments: 1
2026-09-17 16:34:28 Will download totalNoBytes: 999424
2026-09-17 16:34:28 start segment: 0 block offset:0
2026-09-17 16:34:28 Downloading segment 0
2026-09-17 16:34:28 Segment_0x00004000_0x000F7FFF Size uncompressed:999424 start:16384
2026-09-17 16:34:28 >>>>> JobPosition: DownloadDataBlockStartTransfer initiating data transfer of application {
2026-09-17 16:34:28 HexService [34 00 44 00 00 40 00 00 0F 40 00]
2026-09-17 16:34:28 Positive Response from ECU [74 20 0F 02] (4 ms)
2026-09-17 16:34:28 maxNumberOfBlockLength: 3840 bytes:999424
2026-09-17 16:34:28 >>>>> JobPosition: DownloadDataBlockTransfer transfering data of application {
2026-09-17 16:35:18 }
2026-09-17 16:35:18 >>>>> JobPosition: DownloadDataBlockTransferExit ending data transfer of application {
2026-09-17 16:35:18 HexService [37]
2026-09-17 16:35:18 Positive Response from ECU [77] (1 ms)
2026-09-17 16:35:18 Download of data block finished in 49s
2026-09-17 16:35:18 >>>>> JobPosition: CheckMemData checkmemory of data or applikation {
2026-09-17 16:35:18 HexService [31 01 02 02 00 04 21 25 AA DB 00 80 2A 20 CF 11 C3 AF 38 1B 0A F2 82 8B C3 52 A0 3C 0A 1C 3C F3 3F 2B 0C 59 FF C3 6B 62 1E 7E 1D 97 AA 0D 33 76 F1 1D 9D BF B2 0B B7 34 0D CB CB 38 B6 E2 FA CA EF 97 BB 02 B8 3F 06 8D 3B 27 10 E6 59 EF 72 75 CC 9E 17 0B 70 DD 3F A0 EA E7 3F 95 5C D3 5B F1 49 90 B0 41 3B 60 5F 24 C2 97 58 F6 18 F6 08 E2 2D 10 85 E9 33 BB C3 4C 33 95 56 A1 CF 33 1F CC B3 64 E7 C0 2B B3 FC 5A EB 27 10 7C]
2026-09-17 16:35:18 Positive Response from ECU [71 01 02 02 00 04] (132 ms)
2026-09-17 16:35:18 SEVERE
2026-09-17 16:35:18 SEVERE >>>>> com.daimler.odxjobs.exception.InternalJobException {
2026-09-17 16:35:18 SEVERE A Signature error occured while checking the just flashed block
2026-09-17 16:35:18 SEVERE com.daimler.odxjobs.exception.InternalJobException: A Signature error occured while checking the just flashed block
2026-09-17 16:35:18 SEVERE at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.checkMemoryRoutine(AbstractUdsFlashJob.java:2473)
2026-09-17 16:35:18 SEVERE at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.downloadFlashData(AbstractUdsFlashJob.java:1863)
2026-09-17 16:35:18 SEVERE at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.startMajorProgrammingSequence(AbstractUdsFlashJob.java:699)
2026-09-17 16:35:18 SEVERE at com.daimler.odxjobs.flash.uds.AbstractUdsFlashJob.executeJobTask(AbstractUdsFlashJob.java:317)
2026-09-17 16:35:18 SEVERE at com.daimler.odxjobs.flash.uds.MCD3_GenericUdsFlashjob.executeJobTask(MCD3_GenericUdsFlashjob.java:76)
2026-09-17 16:35:18 SEVERE at com.daimler.odxjobs.common.AbstractSingleEcuJob.execute(AbstractSingleEcuJob.java:280)
2026-09-17 16:35:18 SEVERE at com.daimler.odxjobs.flash.AbstractFlashJob.execute(AbstractFlashJob.java:129)
2026-09-17 16:35:18 SEVERE at JobProcessor.JobThread.run(Unknown Source)
2026-09-17 16:35:18 SEVERE }
2026-09-17 16:35:18 SEVERE Job error:
2026-09-17 16:35:18 SEVERE Severity: eERROR
2026-09-17 16:35:18 SEVERE Code: 51717
2026-09-17 16:35:18 SEVERE CodeDescription: Unknown error code
2026-09-17 16:35:18 SEVERE VendorCode: 21781
2026-09-17 16:35:18 SEVERE VendorCodeDescription: JobError occured .21781 Position: CheckMemData > A Signature error occured while checking the just flashed block logId: 1A0AF935576
2026-09-17 16:35:18 SEVERE Execution State = eALL_FAILED
2026-09-17 16:35:18 SEVERE Error occurred during job execution!
2026-09-17 16:35:18 Job duration: 0h 0m 54s 983ms
2026-09-17 16:35:18 Total number of bytes transferred: 1 007 616
2026-09-17 16:35:18 Transfer rate: 20072byte/s
2026-09-17 16:35:18 Transfer time: 50 s
2026-09-17 16:35:18 Uncompressed transfer Time: 49 s
2026-09-17 16:35:18 Erase time: 3s
2026-09-17 16:35:18 Checkmemory time: 0s
2026-09-17 16:35:18 Checkdependency time: 0s
2026-09-17 16:35:18 WARNING Erasetime differs significantly from Tested time, expected time:9
2026-09-17 16:35:18 WARNING Uncompressed transfer time differs significantly from tested time, expected time:136
2026-09-17 16:35:18 Flash process stopped due to error!
из разных источников: коротких тестов других машин, из изначальных данных блока до программирования и т.д.с чего вы взяли, что п.о которое вы льёте подходит?
обновление ПО чистым с целью дальнейшей работы с блоком и авто.зачем вы полезли шить?
именно это и пытаюсь сделатьЗАЧЕМ ВЫ ПОЛЕЗЛИ ШИТЬ? зашейте то, что там было.
вы льёте самое старое и самое первое ПО
Прошивка тут ни при чем.Программировал поверх (не работал ближний свет
ну, это классическая причина всех подобных вопросов)Ну, и проблемы с п.о. С вирусными отломами. Выбирайте любой пункт.
А почему этим софтом не шьете?SW 247 902 36 00
Не факт.в той теме закончилось заменой блока - блок дефектный.
