EWA на чистой WIN10 не устанавливается EWA из комплекта 2018 EPC
романофф
блестящий...
Т.е. запускаем инсталлятор EWA если без администратора
Код:
In action "Create Log Dir [Run script]" (screen "Pre Installation [Installation]"), property "Script":
java.nio.file.AccessDeniedException: C:\Program Files (x86)\EWA\install\log\log.00
    at sun.nio.fs.WindowsException.translateToIOException(Unknown Source)
    at sun.nio.fs.WindowsException.rethrowAsIOException(Unknown Source)
    at sun.nio.fs.WindowsFileSystemProvider.implDelete(Unknown Source)
    at sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(Unknown Source)
    at java.nio.file.Files.deleteIfExists(Unknown Source)
    at com.dxc.ewa.installer.commons.IMLogger.updateLoggingFolder(IMLogger.java:285)
    at com.install4j.script.I4jScript_Internal_16.eval(I4jScript_Internal_16.java:6)
    at com.install4j.script.I4jScript_Internal_16.evaluate(I4jScript_Internal_16.java:23)
    at com.install4j.runtime.installer.helper.Script.evaluate(Script.java:33)
    at com.install4j.runtime.installer.ContextImpl.runScript(ContextImpl.java:201)
    at com.install4j.runtime.installer.ContextImpl.runScript(ContextImpl.java:195)
    at com.install4j.runtime.beans.actions.control.RunScriptAction.execute(RunScriptAction.java:34)
    at com.install4j.runtime.beans.actions.SystemInstallOrUninstallAction.install(SystemInstallOrUninstallAction.java:29)
    at com.install4j.runtime.installer.ContextImpl$9.executeAction(ContextImpl.java:1701)
    at com.install4j.runtime.installer.ContextImpl$9.fetchValue(ContextImpl.java:1692)
    at com.install4j.runtime.installer.ContextImpl$9.fetchValue(ContextImpl.java:1689)
    at com.install4j.runtime.installer.helper.comm.actions.FetchObjectAction.execute(FetchObjectAction.java:14)
    at com.install4j.runtime.installer.helper.comm.HelperCommunication.executeActionDirect(HelperCommunication.java:271)
    at com.install4j.runtime.installer.helper.comm.HelperCommunication.executeActionInt(HelperCommunication.java:246)
    at com.install4j.runtime.installer.helper.comm.HelperCommunication.executeActionChecked(HelperCommunication.java:184)
    at com.install4j.runtime.installer.helper.comm.HelperCommunication.fetchObjectChecked(HelperCommunication.java:167)
    at com.install4j.runtime.installer.ContextImpl.performActionIntStatic(ContextImpl.java:1689)
    at com.install4j.runtime.installer.InstallerContextImpl.performActionInt(InstallerContextImpl.java:159)
    at com.install4j.runtime.installer.ContextImpl.performAction(ContextImpl.java:1114)
    at com.install4j.runtime.installer.controller.Controller.executeAction(Controller.java:380)
    at com.install4j.runtime.installer.controller.Controller.executeActions(Controller.java:346)
    at com.install4j.runtime.installer.controller.Controller.handleCommand(Controller.java:207)
    at com.install4j.runtime.installer.controller.Controller.start(Controller.java:106)
    at com.install4j.runtime.installer.Installer.runInProcess(Installer.java:58)
    at com.install4j.runtime.installer.Installer.main(Installer.java:45)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:85)
    at com.exe4j.runtime.WinLauncher.main(WinLauncher.java:94)
    at com.install4j.runtime.launcher.WinLauncher.main(WinLauncher.java:25)
если с администратором
уходит чуть дальше, но результат тот-же , как и в логе.
с WIS 2020 ewa устанавливается, но она кастрированная без EPC. (перенос ewaadmintool с EPC не открывает его в самом серваке).
первый раз такое встречаю.
Прав пользователя не хватает, если вин последний, изменена политика безопасности. Поставь разрешения на всю папку а потом уже стартуй от админа.
Wis 2020 ничем не кастрирован. Что значит не открывает на серваке? Все открывает если права выставлены корректно.
в каком месте и кому эти права задать? На папку Ева в програм файл? и какие права надо? Я такое не трогал ни разу.
На носителе где лежит каталог, он же установочный файл, свойства, безопасность, изменить.... Выбрать текущего пользователя, назначить полные права.
Раньше не делал потому что запуск под админом решал, теперь пользователь в Винде это админ но не полностью. Винда становится похожа на Линукс, где sudo для каждого файла надо задавать руками.
Если конкретно, Ева не может получить полные права на установку туда, куда ей надо запихать свои файлы, винда отсекает.
у всех одинаково выставил - добавил только full xontrol, специал пермиссион не ставится. то-же самое.
